phpBB Gallery (相簿) (Update 1.1.6)
Officially Approved MODs
phpBB Gallery (相簿) (Update 1.0.5)
版本歷史:
敬請參閱 contrib/history.xml
外掛下載:
http://www.flying-bits.org/go/phpbb_gallery/download
http://www.phpbb.com/community/viewtopi ... &t=1825475
中文化分享:
http://www.flying-bits.org/viewtopic.php?f=78&t=1774
1.0.4 升級 1.0.5 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案.
  2. 依照升級安裝說明 (contrib/update_1_0_4_to_1_0_5/update.xml), 修改相關檔案.
  3. 中文化後,由瀏覽器 (http://YOUR_SITE/PHPBB_ROOT/install) 執行資料庫更新;
    執行成功後, 移除 /install/ 資料夾.
  4. 清除論壇快取.
  5. ACP > 風格 > 樣板/主題/圖檔組 > prosilver/subsilver2 > 重新整理.
常見問題:您必須是這個論壇的「創始者」!
當您在執行全新安裝或升級時,如果遇到您必須是這個論壇的「創始者」!的錯誤訊息,那麼可以試著以下修改:
install/install_install.php(全新安裝)或 install/install_update.php(升級)
--找到後,移除之--
      if ($user->data['user_type'] != USER_FOUNDER)
         trigger_error('FOUNDER_NEEDED', E_USER_ERROR);
--儲存與關閉--
修改後,重新執行資料庫更新動作。
http://www.phpbb.com/customise/db/mod/p ... /faq/f_361
phpBB Gallery (相簿) (Update 1.0.5.1)
版本歷史:
2010-11-23 - Version1.0.5.1
  • [Fix] Installation manual need to be changed for phpBB 3.0.8 (Bug #750)
  • [Fix] Issue in database updater from Version < 0.4.1
外掛下載:
http://www.phpbb.com/customise/db/mod/phpbb_gallery/
中文化分享:
1.0.5 升級 1.0.5.1 成功經驗:
已安裝 1.0.5 者,無須升級。
http://www.phpbb.com/customise/db/mod/p ... /faq/f_507
phpBB Gallery (相簿) (Update 1.0.6)
版本歷史:
2011-03-26 - Version1.0.6
  • [Fix] xHTML-Validation Error for new-line on comments. (Bug #787)
  • [Fix] Comment-links are invalid xHTML (Bug #783)
  • [Fix] prosilver UCP is not designed like the phpBB-UCP pages. (Bug #782)
  • [Fix] "Disallowed file-type" message in ACP does not have the error-background (Bug #765)
  • [Fix] xHTML-Validation Error when an image appears in multiple image-blocks (Bug #774)
  • [Fix] Correct some labels in ACP Import screen.
  • [Fix] Take filename as image name does not work correctly for non-ASCII-characters (Bug #745)
  • [Fix] Fix several SQL-Errors for PostgreSQL and MSSQL (Bug #723, #784)
  • [Change] Do not edit bidi.css but put the code in gallery.css
外掛下載:
http://www.flying-bits.org/download.php?mod_id=6
phpbb.com 官方主題:
中文化分享:(包含語言與圖示)
phpbb_gallery_zh_cmn_hant_1_0_6.zip
(33.21 KiB) 已下載 1699 次
1.0.5 升級 1.0.6 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案
  2. 依照升級安裝說明 (contrib/update_1_0_5_to_1_0_6/update.xml),修改相關檔案。
  3. 中文化後,由瀏覽器 (http://YOUR_SITE/PHPBB_ROOT/install) 執行資料庫更新;執行成功後,移除 /install/ 資料夾。
  4. 清除論壇快取。
  5. ACP > 風格 > 樣板/主題/圖檔組 > prosilver/subsilver2 > 重新整理。
  • 此 1.0.6 升級版尚未經官方核准。
  • 1.0.5 中文化語言檔仍可適用於 1.0.6。
phpBB Gallery (相簿) (Update 1.1.1)
版本歷史:
外掛下載:
phpbb.com 官方主題:
中文化分享:(包含語言與圖示)
http://www.flying-bits.org/viewtopic.ph ... 508#p14508
1.0.6 升級 1.1.1 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案
  2. 依照升級安裝說明 (contrib/update_1_0_6_to_1_1_1/update.xml),修改相關檔案。
  3. 上傳中文化語言檔後,由瀏覽器 (http://YOUR_SITE/PHPBB_ROOT/install) 執行資料庫更新;執行成功後,移除 /install/ 資料夾。
  4. 清除論壇快取。
phpBB Gallery (相簿) (Update 1.1.2)
版本歷史:
外掛下載:
phpbb.com 官方主題:
中文化分享:(包含語言與圖示)
http://www.flying-bits.org/viewtopic.ph ... 12&#p14812
1.1.1 升級 1.1.2 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案。
  2. 依照升級安裝說明 (contrib/update_1_1_1_to_1_1_2/update.xml),修改相關檔案。
  4. 清除論壇快取。
phpBB Gallery (相簿) (Update 1.1.3)
版本歷史:
外掛下載:
phpbb.com 官方主題:
中文化分享:(包含語言與圖示)
http://www.flying-bits.org/viewtopic.php?p=15151#p15151
1.1.2 升級 1.1.3 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案。
  2. 依照升級安裝說明 (contrib/update_1_1_2_to_1_1_3/update.xml),修改相關檔案。
  4. 清除論壇快取。
phpBB Gallery (相簿) (Update 1.1.4)
版本歷史:
外掛下載:
phpbb.com 官方主題:
中文化分享:(包含語言與圖示)
http://www.flying-bits.org/viewtopic.php?p=15339#p15339
1.1.3 升級 1.1.4 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案。
  2. 依照升級安裝說明 (contrib/update_1_1_3_to_1_1_4/update.xml),修改相關檔案。
  4. 清除論壇快取。
Re: phpBB Gallery (相簿) (Update 1.1.4)
這支外掛的 1.1.4 版已經獲得官方認證。 (:Y)
phpBB Gallery (相簿) (Update 1.1.5)
版本歷史:
外掛下載:
phpbb.com 官方主題:
中文化分享:(包含語言與圖示)
http://www.flying-bits.org/viewtopic.php?p=16897#p16897
1.1.4 升級 1.1.5 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案。
  2. 依照升級安裝說明 (contrib/update_1_1_4_to_1_1_5/update.xml),修改相關檔案。
  4. 清除論壇快取。
版本歷史:
外掛下載:
phpbb.com 官方主題:
中文化分享:(包含語言與圖示)
phpbb_gallery_1_1_6-zh_cmn_hant.zip
for phpBB Gallery v1.1.6
(33.25 KiB) 已下載 1389 次
1.1.5 升級 1.1.6 成功經驗:
  1. 上傳 (覆蓋) 所有附加檔案。
  2. 依照升級安裝說明 (contrib/update_1_1_5_to_1_1_6/update.xml),修改相關檔案。
  4. 清除論壇快取。
回到「[3.0.x] 官方認證外掛」
