## MOD Title: Admin Configurable SMTP Port
## MOD Author: AdamR < adam@pylonhosting.com > (Adam Reyher) http://www.adamreyher.com
## MOD Description: This MOD adds a field on the Admin Panel Configuration
## page which allows you to define the SMTP port.
## MOD Version: 1.0.2
## Installation Level: Intermediate
## Installation Time: 10 Minutes
## Files To Edit: (4) admin_board.php, smtp.php, lang_admin.php, board_config_body.tpl
## Included Files: n/a
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes: In the SQL, remember to change "phpbb_" to your table prefix.
## MOD History:
## 2005-08-22 - Version 1.0.2
## - Updated to be complient with latest phpBB version and phpBB.com MOD requirements
## 2004-09-05 - Version 1.0.1
## - Fixed small validation bug
## 2004-08-21 - Version 1.0.0
## - First FINAL release
## 2004-08-20 - Version 0.0.1
## - First BETA release
############################################################## 另還不支援Gmail
版本: 1.0.2 (Updated 08/27/05)
下載: admin_configurable_smtp_port_v102.mod
大小: 4554 Bytes
