[外掛] 代碼中允許輸入顏色
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
i-Ray
文章: 5
註冊時間: 2005-09-25 19:53
來自: 台灣-台北
[外掛] 代碼中允許輸入顏色
文章 由 i-Ray »
## MOD Title: BBcode Colours in Code
## MOD Author: BrotherTank < brothertank@sympatico.ca > (Greg)
## MOD Description: Allows one to use the [color] and [/color]
##   					  commands inside of a [code] section. This allows
##                  greater flexibility when posting code segments
##                  WITHOUT loosing the formatting!
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: ~10 Minutes
## Files To Edit: bbcode.php
## Included Files: N/A
## MOD History:
## Mar 17, 2004 - Version 1.0.0
##  - Initial Release - only one needed!
## Author Notes:
##  Thanks to those that didn't want to help out.  I have no real php programming knowledge
##  and I achieved this mod with only 4 lines of code!  I hope everyone finds this
##  modification usefull as the members do in my forums!
##  All 4 additions go inside the "function bbencode_first_pass_pda($text, $uid, $open_tag, $close_tag, $close_tag_new, $mark_lowest_level, $func, $open_regexp_replace = false)"
下載點: http://www.phpbb.com/phpBB/catdb.php?mo ... id=1011830
功能: po代碼時,加入想要的顏色
回到「官方認證外掛」
