[2.0.6] 圖片最左或最右(BBcode)
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
eMax
文章: 61
註冊時間: 2005-08-22 11:23
來自: 大臺北
文章 由 eMax »
## MOD Title:   Left and Right IMG tags
## MOD Author:  Nuttzy < pktoolkit@blizzhackers.com > (n/a) http://www.blizzhackers.com
## MOD Author, Secondary:  Xore < mods@xore.ca > (Robert Hetzler) http://www.xore.ca
## MOD Description:  This MOD will allow you to better format
##    you posts by aligning images left and right instead of
##    just in-line as with the standard [img][/img] tag. Text
##    will also neatly wrap around the images.
## MOD Version: 1.6.0
## Installation Level:  EASY
## Installation Time:   4-5 Minutes
## Files To Edit:       6
##                   - includes/bbcode.php
##                   - templates/subSilver/bbcode.tpl
##                   - language/lang_english/lang_main.php
##                   - language/lang_english/lang_bbcode.php
## Included Files:     n/a
## Author Notes:
##     Works with phpBB 2.0.4 thru 2.0.6
##     IMPORTANT: you MUST first have already installed the Multi Quick BBCode MOD
## Usage:
##     [img=left]url of image[/img] to left justify image
##     [img=right]url of image[/img] to right justify image
## (used to be [left][/left] and [right][/right] -- this frees up more hotkeys)
## MOD History:
##    2003-11-02 - Version 1.6.0
##         + Changed to img=left and img=right
##    2003-09-25 - Version 1.5.2
##         + improved MOD Template compliance
##    02/05/03 - bug fix: changed instance in bbcode.tpl where
##                 left should have been right - DanielT
##    02/04/03 - updated for 2.0.4
##             - added BBCode FAQ entry
##    08/31/02 - fixed interference with font color/size problem
##             - made compliant with EasyMod alpha 2
##    06/28/02 - fixed a bbcode problem - thanks to
##               desean84 for discovering the problem!
##    04/21/02 - updated for phpBB 2.0.0 final
##             - quick BBcode added by Christi
##             - made EasyMod compliant
##    03/18/02 - initial releae for phpBB 2.0 RC3
使用說明:
[img=right]url[/img] , [/img=left]url[/img]
請先安裝Mutiple Mod:
:arrow: http://www.phpbb.com/phpBB/catdb.php?mo ... &id=821728
錯誤小修改:
安裝說明中的----------------
  • 該段尋找的說明可能會出現某部份無法找到\r
    請自行補上找不到的代碼 ;-)
#-----[ FIND ]---------------------------------
# NOTE: the full line to look for is:
# $faq[] = array("Adding an image to a post", "phpBB BBCode [..SNIP..] <br />");
回到「官方認證外掛」
