[外掛] Message Can 1.0.5
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
bu
文章: 443
註冊時間: 2003-02-23 12:46
來自: 25° 4′N 121° 29′E
文章 由 bu »
## MOD Title: Message Can
## MOD Author: buweichiu < mods@xpoo.net > (Buwei Chiu) http://bws.xpoo.net
## MOD Description: This MOD allows you prepare some message for users to use when they're posting or sending private messages.
## MOD Version: 1.0.5
## Installation Level: Easy
## Files To Edit: 	6
##			posting.php
##			privmsg.php
##			includes/constants.php
##			language/lang_english/lang_main.php
##			language/lang_english/lang_admin.php
##			templates/subSilver/posting_body.tpl
## Included Files: 6
##			messagecan_install.php
##			admin/admin_messagecan.php
##			templates/subSilver/admin/messagecan_add.tpl
##			templates/subSilver/admin/messagecan_body.tpl
##			templates/subSilver/admin/messagecan_delConfirm.tpl
##			templates/subSilver/admin/messagecan_edit.tpl
## License: http://opensource.org/licenses/gpl-license.php GNU Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
##		Thanks to StickyKid at phpbb-tw.net, he brought me this idea.
##		Remember to change the table prefix used on your database or
##		you can execute the file "messagecan_install.php" ;)
## MOD History:
##	2005-06-05 - Version 1.0.0
##		- Inititla release
##	2005-06-16 - Version 1.0.1
##		- Security update
##	2005-06-25 - Version 1.0.2
##		- Separate files into a separate sub-folder
##		- Fix <br> to <br />
##		- Add sql_freeresult after sql execute
##	2005-07-12 - Version 1.0.3
##		- Fix " to ' in Language Files
##		- Fix template files
##		- Sprintf instead str_replace
##		- and etc...
##	2005-07-23 - Version 1.0.4
##		- Fix stripslashes
##		- XHTML-style coding
##	2005-07-27 - Version 1.0.5
##		- More detail about this MOD
##		- Replace finding place of language file
Link: http://www.phpbb.com/phpBB/viewtopic.php?t=310532
謝謝 Mac 和在官方的 TerraFrost
下次我會注意的 =.=||...
*譯文資料在phpBB 技術文件
*bu.femto-size
*和我聯絡,請寄 or Google Talk 圖檔
回到「官方認證外掛」
