(不知有否post 過…不過這mod 很好用喔~~)
## MOD Title: Author Hyperlink
## MOD Author: tosspot <tosspot@markf.mailshell.com> Mark Fyvie http://www.fyvie.net
## MOD Description: By default the author name in a message is not a hyperlink. This mod makes
## it a URL to the poster's profile. This might be more intuitive for some users compared to the profile button.
## MOD Version: 1.0.1
## Installation Level: easy
## Installation Time: 1 Minute
## Files To Edit: viewtopic.php
## Included Files: n/a
## Author Notes:
## The default colour for the author before applying this mod is black. After applying the mod it will be blue, since it
## is following the "genmed" class. Feel free to modify this part to another class, or to add an additional class if you don't
## like the colour. You will find a discussion on this here:
## http://www.phpbb.com/phpBB/viewtopic.php?t=102833
## MOD History:
## 2003-05-19 - Version 1.0.0
## - Initial version
## 2003.09.13 - Version 1.0.1
## - Tested for phpBB v2.06
viewtopic.php
$poster = ( $poster_id == ANONYMOUS ) ? $lang['Guest'] : $postrow[$i]['username'];
$poster = ( $poster_id != ANONYMOUS ) ? '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '=' . $poster_id) . '" class="genmed">' : '';
$poster .= ( $poster_id != ANONYMOUS ) ? $postrow[$i]['username'] : ( ( $postrow[$i]['post_username'] != '' ) ? $postrow[$i]['post_username'] : $lang['Guest'] );
$poster .= ( $poster_id != ANONYMOUS ) ? '</a>' : '';
# EoM 代碼: 選擇全部
