[教學] Categories hierarchy - 2.1.0
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
streitleak
文章: 261
註冊時間: 2003-07-26 04:44
來自: 龍潭
文章 streitleak »
lang_extend_auth_center.php
<?php
 *						lang_extend_auth_center.php [English]
 *	begin				: 26/10/2004
 *	copyright			: Ptirhiik
 *	email				: ptirhiik@clanmckeen.com
 *	version				: 0.0.6 - 12/02/2005
 *						lang_extend_auth_center.php [CHT]
 *	begin				: 2005/04/26
 *	copyright			: Streit
 *	email				: streit@bezel.com.hk
 *	version				: 0.0.1 - 2005/04/26
if ( !defined('IN_PHPBB') )
	die('Hacking attempt');
// group selection
$lang['Click_return_select_groups'] = '按 %s這裡%s 回到群組選單。';
$lang['Select_groups'] = '選擇一個群組或使用者';
// special groups
$lang['Group_own'] = '擁有者';
$lang['Group_own_desc'] = '使用者可以修改個人資料';
// system groups
$lang['Board_founder'] = '系統管理員';
$lang['Board_founder_desc'] = '系統管理員';
$lang['Group_admin'] = '站務管理員';
$lang['Group_admin_desc'] = '使用者已經可以管理此版面';
$lang['Group_anonymous'] = '訪客';
$lang['Group_anonymous_desc'] = '未註冊使用者';
$lang['Group_registered'] = '已註冊使用者';
$lang['Group_registered_desc'] = '所以註冊使用者';
$lang['No_such_group'] = '這個群組不存在';
$lang['Change_sysgroup_type_denied'] = '這個群組已被關閉';
$lang['Manage_group_denied'] = '您無法通過此群組預設授權。';
// admin part
if ( $lang_extend_admin )
	$lang['Lang_extend_auth_center'] = '權限設定';
	// complementary for group management
	$lang['Board_founder_explain'] = '注意 : 系統管理員群組不需要任何權限設定,預設是全部授權。';
	$lang['Delete_sysgroup_denied'] = '您無法刪除系統群組。';
	$lang['Change_sysgroup_denied'] = '您無法改變此群組的系統狀態。';
	$lang['Unknown_group_sysstatus'] = '未知的系統狀態。';
	$lang['System_group'] = '系統群組';
	// main panel name
	$lang['Panels_index'] = '面版索引';
	$lang['phpbb_acp'] = 'phpBB 管理面版';
	// direct entry for the menu
	$lang['Auths_Center'] = '認證中心';
	$lang['Control_panels'] = '控制台';
	$lang['10_Permissions_manager'] = '權限/管理';
	$lang['11_Permissions_managed'] = '權限/修改';
	// auth values
	$lang['Auth_not_authorised'] = ' -- ';
	$lang['Auth_authorised'] = '已授權';
	$lang['Auth_denied'] = '否決,即使已授權。';
	$lang['Auth_forced'] = '授權,即使已拒絕。';
	// forums auths list
	$lang['auth_view'] = '預覽版面';
	$lang['auth_read'] = '閱讀文章';
	$lang['auth_post'] = '發新主題';
	$lang['auth_reply'] = '回覆文章';
	$lang['auth_edit'] = '修改文章';
	$lang['auth_delete'] = '刪除文章';
	$lang['auth_sticky'] = '設定精華文章';
	$lang['auth_announce'] = '發新公告';
	$lang['auth_global_announce'] = '發全站公告';
	$lang['auth_vote'] = '投票';
	$lang['auth_pollcreate'] = '開新的投票';
	$lang['auth_mod'] = '可以管理此版面Can moderate the forum';
	$lang['auth_mod_display'] = '是否以版面管理方式顯示?';
	$lang['auth_attachments'] = '貼上檔案';
	$lang['auth_download'] = '下載檔案';
	$lang['auth_manage'] = '認證管理';
	// panels auths list
	$lang['Access'] = '權限管理';
	// groups auths list
	$lang['ucp_edit_profile'] = '可修改個人資料';
	$lang['ucp_edit_privacy'] = '各修改個人訊息';
	$lang['ucp_edit_i18n'] = '可修改一般設定選項Can edit internationalisation options';
	$lang['ucp_edit_posting'] = '可修改發文選項';
	$lang['ucp_edit_topicread'] = '可修改文章閱讀選項Can edit topic read options';
	$lang['ucp_edit_layout'] = '可修改版面配置設定選項';
	// presets
	$lang['Auths_presets'] = '預設授權';
	$lang['Presets_not_found'] = '無預設授權';
	$lang['Preset_name'] = '預設名稱';
	$lang['Preset_name_explain'] = '點選輸出 : 若使用已存在的名稱,此名稱預設將被更新;若有符合存在的名稱,符合的名稱將更新 ; 否則的話預設將會被建立。';
	$lang['Export_preset'] = '輸出預設';
	$lang['Delete_preset'] = '刪除預設';
	$lang['Preset_changed'] = '此授權設定符合其他預設 : 請確認預設名稱並確認。';
	$lang['Preset_name_empty'] = '您必須為此動作輸入預設名稱。';
	$lang['Preset_name_exists'] = '此預設名稱已被其他預設使用。';
	$lang['Preset_created'] = '預設已創造';
	$lang['Preset_updated'] = '預設已更新';
	$lang['Preset_deleted'] = '預設已刪除';
	$lang['Submit_presets'] = '送出預設';
	// presets name
	$lang['Custom'] = '自訂';
	$lang['None'] = ' -- none -- ';
	// forums
	$lang['Preset_read_post_vote'] = '讀取, 發文及投票';
	$lang['Preset_read_only'] = '唯讀';
	$lang['Preset_moderator'] = '版主';
	$lang['Preset_moderator_hidden'] = '版主 (隱藏)';
	$lang['Preset_admin'] = '系統管理';
	// panels
	$lang['Preset_access'] = '權限';
	// groups
	$lang['Preset_view'] = '察看';
	// generic return message
	$lang['Click_return_auths'] = '按 %s這裡%s 回到權限中心';
	$lang['No_objects'] = '無物件可管理';
	// group selection
	$lang['Select_source_groups'] = '選擇一個管理(使用者或是群組)';
	$lang['Select_source_groups_explain'] = '選擇一個您希望給予權限的群組或是使用者。';
	$lang['Select_target_groups'] = '選擇一個使用者或是群來管理';
	$lang['Select_target_groups_explain'] = '選擇一個您希望設定權限的使用者或是群組。';
	// forum selection
	$lang['Click_return_select_forums'] = '按 %s這裡%s 回到版面設定。';
	$lang['Select_target_forums'] = '選擇一個版面';
	$lang['Select_target_forums_explain'] = '選擇一個您希望給予權限的版面。';
	// panel selection
	$lang['Select_panels'] = '選擇一個控制台';
	$lang['Click_return_select_panels'] = '按 %s這裡%s 回到控制台選擇。';
	$lang['Select_target_panels'] = '選擇一個控制台';
	$lang['Select_target_panels_explain'] = '選擇一個您希望給予權限的控制台。';
	$lang['Panel_name'] = '名稱';
	$lang['Panel_shortcut'] = '捷徑';
	// auth type & direction selection
	$lang['Auth_center'] = '權限中心';
	$lang['Auth_center_explain'] = '您可以在這裡修改使用此版面的權限。';
	$lang['Click_return_auth_center'] = '按 %s這裡%s 回權限中心。';
	$lang['Select_auth_type_dir'] = '選擇權限種類及行為。';
	$lang['Auth_type'] = '權限種類';
	$lang['Forum_auth_type'] = '版面';
	$lang['Panel_auth_type'] = '控制台';
	$lang['Group_auth_type'] = '使用者或群組';
	$lang['Auth_direction'] = '察看每個權限';
	$lang['Manager'] = '管理(使用者或群組)';
	$lang['Object_managed'] = '已管理物件 (%s)';
	// overviews
	$lang['Panels_managed'] = '已管理控制台';
	$lang['Forums_managed'] = '已管理版面';
	$lang['Group_managed'] = '以管理使用者或群組';
	$lang['Group_manager'] = '使用者及群組管理';
	$lang['No_groups'] = '沒有群組或使用者被選取。請按這裡新增。';
	$lang['Add_group'] = '新增一個群組或使用者。';
	$lang['Usergroup_members_legend'] = '<b>說明:</b>&nbsp;<b>name</b> = 此群組已有權限';
	$lang['Group_members_legend'] = '<b>說明:</b>&nbsp;<b>name</b> = 此群組已有自訂權限';
	// forums overview
	$lang['Click_return_overviewforums'] = '按 %s這裡%s 回到版面預覽。';
	$lang['Overview_forums'] = '版面預覽(每個使用者或是群組管理)';
	$lang['Overview_forums_explain'] = '您可以在這裡設定版面權限。';
	$lang['Please_confirm'] = '請確認輸入是否無誤,然後送出資料。';
	// panels overview
	$lang['Click_return_overviewpanels'] = '按 %s這裡%s 回到控制台預覽。';
	$lang['Overview_panels'] = '控制台預覽(每個使用者或是群組管理)';
	$lang['Overview_panels_explain'] = '您可以在這裡設定控制台權限。';
	// groups overview
	$lang['Click_return_overviewgroups'] = '按 %s這裡%s 回到群組預覽。';
	$lang['Overview_groups'] = '群組預覽(每個使用者或是群組管理)';
	$lang['Overview_groups_explain'] = '您可以在這裡設定群組權限。';
	// forums reversed overviewed
	$lang['Click_return_overviewforums_rev'] = '按 %s這裡%s 回到版面反相預覽。';
	$lang['Overview_rev_forums'] = '版面反相預覽(每個已管理版面)';
	$lang['Overview_rev_forums_explain'] = '您可以管理您所有您選擇的管理群組。';
	// panels reversed overviewed
	$lang['Click_return_overviewpanels_rev'] = '按 %s這裡%s 回到控制台反相預覽。';
	$lang['Overview_rev_panels'] = '控制台反相預覽(每個已管理版面)';
	$lang['Overview_rev_panels_explain'] = '您可以管理您所有您選擇的管理控制台。';
	// groups reversed overviewed
	$lang['Click_return_overviewgroups_rev'] = '按 %s這裡%s 回到群組反相預覽。';
	$lang['Overview_rev_groups'] = '群組反相預覽(每個已管理版面)';
	$lang['Overview_rev_groups_explain'] = '您可以管理您所有您選擇的管理群組。';
	// edit forum auths details
	$lang['Click_return_edit_auth_forums'] = '按 %s這裡%s 回到版面權限管理。';
	$lang['Edit_forums_auth'] = '版面管理詳細';
	$lang['Edit_forums_auth_explain'] = '您可以在這裡定義版面權限並建立、更新或刪除預設。';
	// edit panel auths details
	$lang['Click_return_edit_auth_panels'] = '按 %s這裡%s 回到控制台管理。';
	$lang['Edit_panels_auth'] = '控制台管理詳細';
	$lang['Edit_panels_auth_explain'] = '您可以在這裡定義控制台權限並建立、更新或刪除預設。';
	$lang['No_such_panel'] = '沒有此控制台';
	// edit group auths details
	$lang['Click_return_edit_auth_groups'] = '按 %s這裡%s 回到群組管理。';
	$lang['Edit_groups_auth'] = '群組管理詳細';
	$lang['Edit_groups_auth_explain'] = '您可以在這裡定義群組權限並建立、更新或刪除預設。';
	// auths definitions
	$lang['Definition'] = '定義';
	$lang['Auths_definition'] = '權限定義';
	$lang['Auths_definition_explain'] = '您可以在此新增、修改或移除權限欄為。';
	$lang['Click_return_auths_def'] = '按 %s這裡%s 回到權限定義';
	$lang['Create_auths_def'] = '建立新的權限欄位';
	$lang['Create_auths_def_explain'] = '您可以在此建立新的權限定義。';
	$lang['Edit_auths_def'] = '修改權限定義';
	$lang['Edit_auths_def_explain'] = '您可以在此修改權限定義。';
	$lang['Delete_auths_def'] = '刪除權限定義';
	$lang['Delete_auths_def_explain'] = '您可以在此刪除權限定義。';
	$lang['Import_auths_def'] = '輸入權限定義';
	$lang['Select_auth_type'] = '選擇權限種類';
	$lang['No_auths_def'] = '目前尚無任何權限設定。 <br />請點選 "Create" 建立新的權限設定, <br />"Regen" 輸入存在的設定。';
	$lang['No_such_auth_type'] = '您要求的權限種類不存在。';
	// importing auths defs and forums auths
	$lang['Forums_auths_def_imported'] = '版面權限定義已輸入。';
	$lang['Forums_auths_def_done'] = '這裡無任何新的版面權限定義被輸入。';
	$lang['Forums_auths_imported'] = '版面權限已被輸入。';
	$lang['Panels_auths_def_imported'] = '控制台權限定義已輸入。';
	$lang['Panels_auths_def_done'] = '這裡無任何新的控制台權限定義被輸入。';
	$lang['Groups_auths_def_imported'] = '群組權限定義已輸入。';
	$lang['Groups_auths_def_done'] = '這裡無任何新的群組權限定義被輸入。';
	// auths def detail
	$lang['No_such_auth_id'] = '您選擇的權限不存在。';
	$lang['Auth_name'] = '權限名稱';
	$lang['Auth_name_explain'] = '這個連結名稱已被授權使用來測試此語法.';
	$lang['Auth_desc'] = '權限描述';
	$lang['Auth_title'] = '主題';
	$lang['Auth_title_explain'] = '設定此欄位為YES將可以在權限列表中顯示。';
	$lang['Auth_order'] = '設定此權限位置於';
	// update messages
	$lang['Auths_def_created'] = '此權限定義已加入';
	$lang['Auths_def_updated'] = '此權限定義已更新';
	$lang['Auths_def_deleted'] = '此權限定義已刪除';
另外一個找時間再貼.....
台灣動漫論壇
http://ACGFan.twbbs.org
星
汝命短眷族望聞
我望 
汝本將末看取
-------------《人類帝國國歌一節
回到「官方認證外掛」
