版本:1.0.0
作者:billytcf
簡介:將 phpBB 預設的 iso-8859-1 編碼轉為 UTF-8
網頁: http://www.phpbb.com/phpBB/viewtopic.php?t=246070
下載: http://www.phpbb.com/phpBB/catdb.php?mo ... id=1346685
## MOD Title: Default Encoding
## MOD Author: billytcf <billytcf@hotmail.com> (N/A) N/A
## MOD Description: This mode changes the default encoding of phpBB2 to utf-8
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: 2 Minutes
## Files To Edit:
## language/lang_english/lang_main.php
## Included Files: n/a
## Author Notes: The default encoding of phpBB2 is iso-8859-1, this causes problem when displaying chinese characters, this mode changes the default behaviour.
## MOD History:
## 2004-12-11 - Version 1.0.0
## - The initial release, support phpBB 2.0.11, not tested on others
