[php]##############################################################
## MOD Title: Stop Author View Increase
## MOD Author: DanielT < savi.mods@danielt.com > (Daniel Taylor) http://www.danielt.com
## MOD Description: Does not increase viewed count when author is viewing his/her own topic
## MOD Version: 1.0.1
## Installation Level: easy
## Installation Time: ~1 Minutes
## Files To Edit: viewtopic.php
## Included Files: n/a
## Author Notes: n/a
viewtopic.php
$sql = "UPDATE " . TOPICS_TABLE . "
SET topic_views = topic_views + 1
WHERE topic_id = $topic_id";
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, "Could not update topic views.", '', __LINE__, __FILE__, $sql);
if (!($postrow[0]['user_id'] == $userdata['user_id'])) {
# EoM[/php]
來源:phpbb 官方網站
翻譯:不需要
功能:當作者檢視自己發表的文章時不增加文章的觀看次數
[外掛]Stop Author View Increase
- 文章: 1086
- 註冊時間: 2003-10-28 14:50
再也不當爛好人...
好人是小白轉型成大白的墊腳石...
好人是小白轉型成大白的墊腳石...
