這個MODS的功用是在於允許論壇使用者建立自己最喜歡的主題的清單,方便使用者得以迅速的回覆自己關注的文章或是重點
PhpBB官方網站的下載區在:
http://www.phpbb.com/phpBB/catdb.php?cat=9
PhpBB官方網站的討論區在:
http://www.phpbb.com/phpBB/viewtopic.php?t=73503
作者的資料在:
http://www.phpbb.com/phpBB/profile.php? ... le&u=24004
http://www.danielt.com
PhpBB官方下載點:
http://www.phpbb.com/phpBB/catdb.php?mo ... &id=431370
[php]<?php
## MOD Title: Favorites Mod
## MOD Author: DanielT < mods@danielt.com > (Daniel Taylor) http://www.danielt.com
## MOD Description: Allows users the build a favorite topics list
## 允許論壇使用者建立最喜歡的主題列表清單\r
## MOD Version: 1.0.2
## Installation Level: moderate
## Files To Edit: viewtopic.php
## includes/page_header.php
## templates/subSilver/overall_header.tpl
## templates/subSilver/viewtopic_body.tpl
## language/lang_english/lang_main.php
## Included Files: favorites.php, fav_body.tpl
## For Security Purposes, Please Check: http://www.phpbb.com/mods/downloads/ for the
## in our MOD-Database, located at: http://www.phpbb.com/mods/downloads/
## Author Notes: Updates From 1.0.1:
## Added Simple Post Icon
## Added 'Views and 'Replies'
## Stoped double 'fav adding'
## How to update from 101 to 102:
## Re-upload:
## favorites.php
## fav_body.tpl
#Where 'phpbb_' is your table prefix
CREATE TABLE `phpbb_favorites` (
`fav_id` int(11) NOT NULL auto_increment,
`user_id` int(11) NOT NULL default '0',
`topic_id` int(11) NOT NULL default '0',
PRIMARY KEY (`fav_id`)
copy favorites.php TO favorites.php
copy fav_body.tpl TO templates/subSilver/fav_body.tpl
// That's all, Folks!
//Fav Mod
$lang['remove_fav_data'] = 'Could not remove data from favorites table';
$lang['insert_fav_data'] = 'Could not insert data into favorites table';
$lang['no_fav_topic'] = 'No topic to set as favorite was set';
$lang['favorites'] = 'Favorites';
$lang['add_fav'] = 'Add To Favorites';
//Fav Mod
$lang['remove_fav_data'] = '不能從最愛主題清單中移除資料';
$lang['insert_fav_data'] = 'ㄒ能新增資料在最愛主題清單';
$lang['no_fav_topic'] = '最愛清單中的主題未被設置';
$lang['favorites'] = '我的最愛';
$lang['add_fav'] = '增加到最愛清單中';
viewtopic.php
'S_WATCH_TOPIC_IMG' => $s_watching_topic_img,
'U_FAV' => append_sid("favorites.$phpEx?t=" . $topic_id . "&mode=add"),
'L_FAV' => $lang['add_fav'],
'L_WHOSONLINE_MOD' => sprintf($lang['Mod_online_color'], '<span style="color:#' . $theme['fontcolor2'] . '">', '</span>'),
'L_FAV' => $lang['favorites'],
'U_GROUP_CP' => append_sid('groupcp.'.$phpEx),
'U_FAV' => append_sid('favorites.'.$phpEx),
<img src="templates/subSilver/images/icon_mini_groups.gif" width="12" height="13" border="0" alt="{L_USERGROUPS}" hspace="3" />{L_USERGROUPS}</a>
<a href="{U_FAV}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_groups.gif" width="12" height="13" border="0" alt="{L_FAV}" hspace="3" />{L_FAV}</a>
{S_WATCH_TOPIC}
<br><a href="{U_FAV}">{L_FAV}</a>
# EoM
?>[/php]
正體中文化語系:
[php]<?php
//Fav Mod
?>[/php]
losswing提供的增強模組:
http://phpbb-tw.net/phpbb/viewtopic.php?t=16393
[2.0.4]Favorite Topics MOD
外掛問題區發問格式就在這裡,請務必一定照著格式來~!
你不照著規則來,就算是神也搞不清楚你的問題在哪裡!
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
嗯... 我已經忘記是從哪裡看到的了,還是我自己找到的!@$#@!
反正我的lang檔就多了一個字串\r
(在favorites.php搜尋 $lang['exist_fav'])
就是重複加入主題時,可以自訂錯誤訊息\r
另一個重點
"Topic you choosed has been set"是我自己翻的
可能是不正確的英文!! 請注意~
反正我的lang檔就多了一個字串\r
lang_main.php
#-----[ ADD AFTER ]-------------------
$lang['exist_fav'] = 'Topic you choosed has been set';
#-----[ DONE ]-------------------
可能是不正確的英文!! 請注意~
這裡怪怪的
mod 裝好的時候,如果在未登入狀態下,直接點我的最愛做登入動作,會變成找不到網頁...
在網址列會顯示
/phpbb/login.php?redirect=/phpbb/favorites.php
紅色的部分似乎是路徑錯誤
不知道有沒有人發現??
還是說只有我遇到
favorites.php
header("Location: " . append_sid($phpbb_script_path . "login." . $phpEx . "?redirect=" . $PHP_SELF));
在網址列會顯示
紅色的部分似乎是路徑錯誤
不知道有沒有人發現??
還是說只有我遇到
我廢,故我在...
數位板服役中,同步率 -200%
右手仆街中,同步殘廢率深不可測...
數位板服役中,同步率 -200%
右手仆街中,同步殘廢率深不可測...
我改了一下~就可以正常登入了hinablue 寫:這裡怪怪的
mod 裝好的時候,如果在未登入狀態下,直接點我的最愛做登入動作,會變成找不到網頁...代碼: 選擇全部
# #-----[ OPEN ]-------------------------- # favorites.php # #-----[ FIND ]-------------------------- # header("Location: " . append_sid($phpbb_script_path . "login." . $phpEx . "?redirect=" . $PHP_SELF));
在網址列會顯示
紅色的部分似乎是路徑錯誤
\r
不知道有沒有人發現??
還是說只有我遇到
#-----[OPEN]--------------------------
favorites.php
#-----[FIND]--------------------------
#-----[REPLACE]--------------------------
$redirect = "favorites.$phpEx";
$redirect .= ( isset($user_id) ) ? '&user_id=' . $user_id : '';
header('Location: ' . append_sid("login.$phpEx?redirect=$redirect", true));
## MOD Version: 1.0.4
1.04版釋出了 for phpBB 2.0.6 正常喔
下載位址
下載位址
~初學者啦~
請多多指教
請多多指教
