nein 寫:phpBB : 重大錯誤
Bad field id, must be in the form 'user_word'
SELECT * FROM xoops_pbb_config
Line : 291
File : c:\appserv\www\\\modules\pbboard\admin\admin_cash_currencies.php
[外掛]Cash mod中文化
Re: [外掛]如何是好???
超人感謝你,我剛剛已經發現問題了,我只要將viewtopic_body.tpl動感超人 寫:請檢查一下viewtopic_body.tpl有沒有改錯,
有的話請將修改前的被份檔還原回去,再改一次。
置換成<td width="150" align="left" valign="top" class="{postrow.ROW_CLASS}"><span class="name"><a name="{postrow.U_POST_ID}"></a><b>{postrow.POSTER_NAME}</b></span><br /><span class="postdetails">{postrow.POSTER_RANK}<br />{postrow.RANK_IMAGE}{postrow.POSTER_AVATAR}<br /><br />{postrow.POSTER_JOINED}<br />{postrow.POSTER_POSTS}<br />{postrow.POSTER_FROM}</span><br /></td>
所以我現在只把{postrow.cashrow.CASH_NAME}: {postrow.cashrow.CASH_AMOUNT}這一段拷貝下來貼到<br />{postrow.POSTER_FROM}之前畫面就正常了,但是幣值我控制台那都設定好了也發表文章了還是顯現不出來說。只有出現 : 現在我還在找原因~<td width="150" align="left" valign="top" class="{postrow.ROW_CLASS}"><span class="name"><a name="{postrow.U_POST_ID}"></a><b>{postrow.POSTER_NAME}</b></span><br /><span class="postdetails">{postrow.POSTER_RANK}<br />{postrow.RANK_IMAGE}{postrow.POSTER_AVATAR}<br /><br />{postrow.POSTER_JOINED}<br />{postrow.POSTER_POSTS}<br />{postrow.POSTER_FROM}
<!-- BEGIN cashrow -->
<br />{postrow.cashrow.CASH_NAME}: {postrow.cashrow.CASH_AMOUNT}
<!-- END cashrow -->
</span><br /></td>
別人不給你的,學著自己先給別人
分享會加速學習也是快樂的動力~
分享會加速學習也是快樂的動力~
bobocwc 寫:對不起歐s0324004 寫:各位大大們
我安裝了好幾次\r
還是沒辦法成功呀
出現了這可能是我哪沒設定好嗎?phpBB : Critical Error
SELECT * FROM phpbb_config
Line : 291
File : c:\appserv\www\phpbb \admin\admin_cash_currencies.php
有人可以幫幫我呀....感恩喔
*******已解決***
我也又相同的問題ㄋ~
有人能幫我ㄇ
http://www.phpbb.com/phpBB/viewtopic.ph ... 885#684885
The error is a bit misleading ( i need to fix that )
Basically, it's telling you that your database field needs to start with 'user_' and end with any set of letters.
Acceptable:
user_points, user_cats, user_dollars, user_adfgajnadfgaadf
Unacceptable:
points, user_(4+z, user_72423, user_EG#$er34gfq3
Hope that helps to clarify
littlehoiyi
- 星球普通子民
- 文章: 6
- 註冊時間: 2003-10-07 00:18
我是個新初學架phpbb...看這個cash mod很有趣嘗試去架\r
但當我在控制台選項時
便會有很多類似的error出現...
請問可以如何解決?
Could not query config information in cash_config
SQL Error : 1146 Table 'kingdom2.cash_table' doesn't exist
SELECT * FROM CASH_TABLE ORDER BY cash_order ASC
Line : 50
File : C:\apache\htdocs\kingdom2\admin\admin_cash_settings.php
但當我在控制台選項時
便會有很多類似的error出現...
請問可以如何解決?
Line : 50
依照官方站的說明,在SQL裡面進行:weipuo 寫: 看了之前的文章 事不是說 裝好cash mod裡面創造一個虛擬貨幣 然後就跟以前一樣了???
如果你之前安裝的是(發表在竹貓的)虛擬貨幣,請不要刪除原來的user_bank,執行以下SQL
INSERT INTO phpbb_cash (cash_dbfield, cash_name) VALUES ('user_money', 'Money')代碼: 選擇全部
INSERT INTO phpbb_cash (cash_dbfield, cash_name) VALUES ('user_points', 'Points')-
dhsh_1128a
- 星球普通子民
- 文章: 29
- 註冊時間: 2003-08-25 15:15
- 來自: 地球
- 聯繫:
