[問題]在觀看文章出問題
御津闇慈
文章: 645
註冊時間: 2001-11-17 10:59
[問題]在觀看文章出問題
文章 御津闇慈 »
@@不知道速怎麼搞低~~
每回一次文章就多出一行~~
而且我也趙囉小竹說的方式去弄@@
還速一樣@@
那ㄟ安咧@@||
viewtopic.php
<?php
 *                               viewtopic.php
 *   $Id: viewtopic.php,v 1.186 2002/03/31 00:06:34 psotfx Exp $
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
// Start initial var setup
if ( isset($HTTP_GET_VARS[POST_TOPIC_URL]) )
	$topic_id = intval($HTTP_GET_VARS[POST_TOPIC_URL]);
else if ( isset($HTTP_GET_VARS['topic']) )
	$topic_id = intval($HTTP_GET_VARS['topic']);
if ( isset($HTTP_GET_VARS[POST_POST_URL]))
	$post_id = intval($HTTP_GET_VARS[POST_POST_URL]);
$start = ( isset($HTTP_GET_VARS['start']) ) ? intval($HTTP_GET_VARS['start']) : 0;
if ( !isset($topic_id) && !isset($post_id) )
	message_die(GENERAL_MESSAGE, 'Topic_post_not_exist');
// Find topic id if user requested a newer
// or older topic
if ( isset($HTTP_GET_VARS['view']) && empty($HTTP_GET_VARS[POST_POST_URL]) )
	if ( $HTTP_GET_VARS['view'] == 'newest' )
		$header_location = ( @preg_match('/Microsoft|WebSTAR|Xitami/', getenv('SERVER_SOFTWARE')) ) ? 'Refresh: 0; URL=' : 'Location: ';
		if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid']) )
			$session_id = $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid'];
			if ( $session_id )
				$sql = "SELECT p.post_id
					FROM " . POSTS_TABLE . " p, " . SESSIONS_TABLE . " s,  " . USERS_TABLE . " u
					WHERE s.session_id = '$session_id'
						AND u.user_id = s.session_user_id
						AND p.topic_id = $topic_id
						AND p.post_time >= u.user_lastvisit
					ORDER BY p.post_time ASC
					LIMIT 1";
					message_die(GENERAL_ERROR, 'Could not obtain newer/older topic information', '', __LINE__, __FILE__, $sql);
				if ( !($row = $db->sql_fetchrow($result)) )
					message_die(GENERAL_MESSAGE, 'No_new_posts_last_visit');
				$post_id = $row['post_id'];
				header($header_location . append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=$post_id#$post_id", true));
				exit;
		header($header_location . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id", true));
		exit;
	else if ( $HTTP_GET_VARS['view'] == 'next' || $HTTP_GET_VARS['view'] == 'previous' )
		$sql_condition = ( $HTTP_GET_VARS['view'] == 'next' ) ? '>' : '<';
		$sql_ordering = ( $HTTP_GET_VARS['view'] == 'next' ) ? 'ASC' : 'DESC';
		$sql = "SELECT t.topic_id
			FROM " . TOPICS_TABLE . " t, " . TOPICS_TABLE . " t2, " . POSTS_TABLE . " p, " . POSTS_TABLE . " p2
			WHERE t2.topic_id = $topic_id
				AND p2.post_id = t2.topic_last_post_id
				AND t.forum_id = t2.forum_id
				AND p.post_id = t.topic_last_post_id
				AND p.post_time $sql_condition p2.post_time
				AND p.topic_id = t.topic_id
			ORDER BY p.post_time $sql_ordering
			LIMIT 1";
			message_die(GENERAL_ERROR, "Could not obtain newer/older topic information", '', __LINE__, __FILE__, $sql);
			if( $HTTP_GET_VARS['view'] == 'next' )
				message_die(GENERAL_MESSAGE, 'No_newer_topics');
				message_die(GENERAL_MESSAGE, 'No_older_topics');
			$topic_id = $row['topic_id'];
// This rather complex gaggle of code handles querying for topics but
// also allows for direct linking to a post (and the calculation of which
// page the post is on and the correct display of viewtopic)
$join_sql_table = ( !isset($post_id) ) ? '' : ", " . POSTS_TABLE . " p, " . POSTS_TABLE . " p2 ";
$join_sql = ( !isset($post_id) ) ? "t.topic_id = $topic_id" : "p.post_id = $post_id AND t.topic_id = p.topic_id AND p2.topic_id = p.topic_id AND p2.post_id <= $post_id";
$count_sql = ( !isset($post_id) ) ? '' : ", COUNT(p2.post_id) AS prev_posts";
$order_sql = ( !isset($post_id) ) ? '' : "GROUP BY p.post_id, t.topic_id, t.topic_title, t.topic_status, t.topic_replies, t.topic_time, t.topic_type, t.topic_vote, f.forum_name, f.forum_status, f.forum_id, f.auth_view, f.auth_read, f.auth_post, f.auth_reply, f.auth_edit, f.auth_delete, f.auth_sticky, f.auth_announce, f.auth_pollcreate, f.auth_vote, f.auth_attachments ORDER BY p.post_id ASC";
$sql = "SELECT t.topic_id, t.topic_title, t.topic_status, t.topic_replies, t.topic_time, t.topic_type, t.topic_vote, f.forum_name, f.forum_status, f.forum_id, f.auth_view, f.auth_read, f.auth_post, f.auth_reply, f.auth_edit, f.auth_delete, f.auth_sticky, f.auth_announce, f.auth_pollcreate, f.auth_vote, f.auth_attachments" . $count_sql . "
	FROM " . TOPICS_TABLE . " t, " . FORUMS_TABLE . " f" . $join_sql_table . "
	WHERE $join_sql
		AND f.forum_id = t.forum_id
		$order_sql";
	message_die(GENERAL_ERROR, "Could not obtain topic information", '', __LINE__, __FILE__, $sql);
if ( !($forum_row = $db->sql_fetchrow($result)) )
$forum_id = $forum_row['forum_id'];
// Start session management
$userdata = session_pagestart($user_ip, $forum_id);
init_userprefs($userdata);
// End session management
// Start auth check
$is_auth = array();
$is_auth = auth(AUTH_ALL, $forum_id, $userdata, $forum_row);
if( !$is_auth['auth_view'] || !$is_auth['auth_read'] )
		$redirect = ( isset($post_id) ) ? POST_POST_URL . "=$post_id" : POST_TOPIC_URL . "=$topic_id";
		$redirect .= ( isset($start) ) ? "&start=$start" : '';
		$header_location = ( @preg_match("/Microsoft|WebSTAR|Xitami/", getenv("SERVER_SOFTWARE")) ) ? "Refresh: 0; URL=" : "Location: ";
		header($header_location . append_sid("login.$phpEx?redirect=viewtopic.$phpEx&$redirect", true));
	$message = ( !$is_auth['auth_view'] ) ? $lang['Topic_post_not_exist'] : sprintf($lang['Sorry_auth_read'], $is_auth['auth_read_type']);
// End auth check
$forum_name = $forum_row['forum_name'];
$topic_title = $forum_row['topic_title'];
$topic_id = $forum_row['topic_id'];
$topic_time = $forum_row['topic_time'];
if ( !empty($post_id) )
	$start = floor(($forum_row['prev_posts'] - 1) / $board_config['posts_per_page']) * $board_config['posts_per_page'];
// Is user watching this thread?
	$can_watch_topic = TRUE;
	$sql = "SELECT notify_status
		FROM " . TOPICS_WATCH_TABLE . "
		WHERE topic_id = $topic_id
			AND user_id = " . $userdata['user_id'];
		message_die(GENERAL_ERROR, "Could not obtain topic watch information", '', __LINE__, __FILE__, $sql);
		if ( isset($HTTP_GET_VARS['unwatch']) )
			if ( $HTTP_GET_VARS['unwatch'] == 'topic' )
				$is_watching_topic = 0;
				$sql_priority = (SQL_LAYER == "mysql") ? "LOW_PRIORITY" : '';
				$sql = "DELETE $sql_priority FROM " . TOPICS_WATCH_TABLE . "
					message_die(GENERAL_ERROR, "Could not delete topic watch information", '', __LINE__, __FILE__, $sql);
			$template->assign_vars(array(
				'META' => '<meta http-equiv="refresh" content="3;url=' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">')
			$message = $lang['No_longer_watching'] . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">', '</a>');
			$is_watching_topic = TRUE;
			if ( $row['notify_status'] )
				$sql = "UPDATE $sql_priority " . TOPICS_WATCH_TABLE . "
					SET notify_status = 0
					message_die(GENERAL_ERROR, "Could not update topic watch information", '', __LINE__, __FILE__, $sql);
		if ( isset($HTTP_GET_VARS['watch']) )
			if ( $HTTP_GET_VARS['watch'] == 'topic' )
				$sql = "INSERT $sql_priority INTO " . TOPICS_WATCH_TABLE . " (user_id, topic_id, notify_status)
					VALUES (" . $userdata['user_id'] . ", $topic_id, 0)";
					message_die(GENERAL_ERROR, "Could not insert topic watch information", '', __LINE__, __FILE__, $sql);
			$message = $lang['You_are_watching'] . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">', '</a>');
\n		}
			header($header_location . append_sid("login.$phpEx?redirect=viewtopic.$phpEx&" . POST_TOPIC_URL . "=$topic_id&unwatch=topic", true));
		$can_watch_topic = 0;
// Generate a 'Show posts in previous x days' select box. If the postdays var is POSTed
// then get it's value, find the number of topics with dates newer than it (to properly
// handle pagination) and alter the main query
$previous_days = array(0, 1, 7, 14, 30, 90, 180, 364);
$previous_days_text = array($lang['All_Posts'], $lang['1_Day'], $lang['7_Days'], $lang['2_Weeks'], $lang['1_Month'], $lang['3_Months'], $lang['6_Months'], $lang['1_Year']);
if( !empty($HTTP_POST_VARS['postdays']) || !empty($HTTP_GET_VARS['postdays']) )
	$post_days = ( !empty($HTTP_POST_VARS['postdays']) ) ? $HTTP_POST_VARS['postdays'] : $HTTP_GET_VARS['postdays'];
	$min_post_time = time() - ($post_days * 86400);
	$sql = "SELECT COUNT(post_id) AS num_posts
			AND post_time >= $min_post_time";
		message_die(GENERAL_ERROR, "Could not obtain limited topics count information", '', __LINE__, __FILE__, $sql);
	$total_replies = ( $row = $db->sql_fetchrow($result) ) ? $row['num_posts'] : 0;
	$limit_posts_time = "AND p.post_time >= $min_post_time ";
	if ( !empty($HTTP_POST_VARS['postdays']))
		$start = 0;
	$total_replies = $forum_row['topic_replies'] + 1;
	$limit_posts_time = '';
	$post_days = 0;
$select_post_days = '<select name="postdays">';
for($i = 0; $i < count($previous_days); $i++)
	$selected = ($post_days == $previous_days[$i]) ? ' selected="selected"' : '';
	$select_post_days .= '<option value="' . $previous_days[$i] . '"' . $selected . '>' . $previous_days_text[$i] . '</option>';
$select_post_days .= '</select>';
// Decide how to order the post display
if ( !empty($HTTP_POST_VARS['postorder']) || !empty($HTTP_GET_VARS['postorder']) )
	$post_order = (!empty($HTTP_POST_VARS['postorder'])) ? $HTTP_POST_VARS['postorder'] : $HTTP_GET_VARS['postorder'];
	$post_time_order = ($post_order == "asc") ? "ASC" : "DESC";
	$post_order = 'asc';
	$post_time_order = 'ASC';
$select_post_order = '<select name="postorder">';
if ( $post_time_order == 'ASC' )
	$select_post_order .= '<option value="asc" selected="selected">' . $lang['Oldest_First'] . '</option><option value="desc">' . $lang['Newest_First'] . '</option>';
	$select_post_order .= '<option value="asc">' . $lang['Oldest_First'] . '</option><option value="desc" selected="selected">' . $lang['Newest_First'] . '</option>';
$select_post_order .= '</select>';
// Go ahead and pull all data for this topic
$sql = "SELECT u.username, u.user_id, u.user_posts, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile,u.user_allow_viewonline, u.user_session_time, u.user_money, p.*,  pt.post_text, pt.post_subject, pt.bbcode_uid
	FROM " . POSTS_TABLE . " p, " . USERS_TABLE . " u, " . POSTS_TEXT_TABLE . " pt
	WHERE p.topic_id = $topic_id
		$limit_posts_time
		AND pt.post_id = p.post_id
		AND u.user_id = p.poster_id
	ORDER BY p.post_time $post_time_order
	LIMIT $start, ".$board_config['posts_per_page'];
	message_die(GENERAL_ERROR, "Could not obtain post/user information.", '', __LINE__, __FILE__, $sql);
	$postrow = array();
	do
		$postrow[] = $row;
	$db->sql_freeresult($result);
	$total_posts = count($postrow);
	message_die(GENERAL_MESSAGE, $lang['No_posts_topic']);
$sql = "SELECT *
	FROM " . RANKS_TABLE . "
	ORDER BY rank_special, rank_min";
\n{
	message_die(GENERAL_ERROR, "Could not obtain ranks information.", '', __LINE__, __FILE__, $sql);
$ranksrow = array();
	$ranksrow[] = $row;
// Define censored word matches
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
// Censor topic title
if ( count($orig_word) )
	$topic_title = preg_replace($orig_word, $replacement_word, $topic_title);
// Was a highlight request part of the URI? Yes, this idea was
// taken from vB but we did already have a highlighter in place
// in search itself ... it's just been extended a bit!
if ( isset($HTTP_GET_VARS['highlight']) )
	$highlight_match = array();
	// Split words and phrases
	$words = explode(' ', trim(urldecode($HTTP_GET_VARS['highlight'])));
	for($i = 0; $i < count($words); $i++)
		if ( trim($words[$i]) != '' )
			$highlight_match[] = '#\b(' . str_replace("*", "([\w]+)?", $words[$i]) . ')\b#is';
	$highlight_active = ( count($highlight_match) ) ? true : false;
	$highlight_active = false;
// Post, reply and other URL generation for
// templating vars
$new_topic_url = append_sid("posting.$phpEx?mode=newtopic&" . POST_FORUM_URL . "=$forum_id");
$reply_topic_url = append_sid("posting.$phpEx?mode=reply&" . POST_TOPIC_URL . "=$topic_id");
$view_forum_url = append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id");
$view_prev_topic_url = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&view=previous");
$view_next_topic_url = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&view=next");
\r
// Mozilla navigation bar
$nav_links['prev'] = array(
	'url' => $view_prev_topic_url,
	'title' => $lang['View_previous_topic']
$nav_links['next'] = array(
	'url' => $view_next_topic_url,
	'title' => $lang['View_next_topic']
$nav_links['up'] = array(
	'url' => $view_forum_url,
	'title' => $forum_name
$reply_img = ( $forum_row['forum_status'] == FORUM_LOCKED || $forum_row['topic_status'] == TOPIC_LOCKED ) ? $images['reply_locked'] : $images['reply_new'];
$reply_alt = ( $forum_row['forum_status'] == FORUM_LOCKED || $forum_row['topic_status'] == TOPIC_LOCKED ) ? $lang['Topic_locked'] : $lang['Reply_to_topic'];
$post_img = ( $forum_row['forum_status'] == FORUM_LOCKED ) ? $images['post_locked'] : $images['post_new'];
$post_alt = ( $forum_row['forum_status'] == FORUM_LOCKED ) ? $lang['Forum_locked'] : $lang['Post_new_topic'];
$quick_reply_img = ( $forum_row['forum_status'] == FORUM_LOCKED || $forum_row['topic_status'] == TOPIC_LOCKED ) ? $images['reply_locked'] : $images['quick_reply']; // Quick_Reply_MOD
$quick_reply_alt = ( $forum_row['forum_status'] == FORUM_LOCKED || $forum_row['topic_status'] == TOPIC_LOCKED ) ? $lang['Topic_locked'] : $lang['Quick_Reply_to_topic']; // Quick_Reply_MOD
// Set a cookie for this topic
	$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) : array();
	$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) : array();
	if ( !empty($tracking_topics[$topic_id]) && !empty($tracking_forums[$forum_id]) )
		$topic_last_read = ( $tracking_topics[$topic_id] > $tracking_forums[$forum_id] ) ? $tracking_topics[$topic_id] : $tracking_forums[$forum_id];
	else if ( !empty($tracking_topics[$topic_id]) || !empty($tracking_forums[$forum_id]) )
		$topic_last_read = ( !empty($tracking_topics[$topic_id]) ) ? $tracking_topics[$topic_id] : $tracking_forums[$forum_id];
		$topic_last_read = $userdata['user_lastvisit'];
	if ( count($tracking_topics) >= 150 && empty($tracking_topics[$topic_id]) )
		asort($tracking_topics);
		unset($tracking_topics[key($tracking_topics)]);
	$tracking_topics[$topic_id] = time();
	setcookie($board_config['cookie_name'] . '_t', serialize($tracking_topics), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
// Load templates
	'body' => 'viewtopic_body.tpl')
make_jumpbox('viewforum.'.$phpEx, $forum_id);
// Output page header
$page_title = $lang['View_topic'] .' - ' . $topic_title;
// User authorisation levels output
$s_auth_can = ( ( $is_auth['auth_post'] ) ? $lang['Rules_post_can'] : $lang['Rules_post_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_reply'] ) ? $lang['Rules_reply_can'] : $lang['Rules_reply_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_edit'] ) ? $lang['Rules_edit_can'] : $lang['Rules_edit_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_delete'] ) ? $lang['Rules_delete_can'] : $lang['Rules_delete_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_vote'] ) ? $lang['Rules_vote_can'] : $lang['Rules_vote_cannot'] ) . '<br />';
if ( $is_auth['auth_mod'] )
	$s_auth_can .= sprintf($lang['Rules_moderate'], '<a href="' . append_sid("modcp.$phpEx?" . POST_FORUM_URL . "=$forum_id") . '">', '</a>');
\n
	$topic_mod = '<a href="' . append_sid("modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=delete") . '"><img src="' . $images['topic_mod_delete'] . '" alt="' . $lang['Delete_topic'] . '" title="' . $lang['Delete_topic'] . '" border="0" /></a> ';
	$topic_mod .= '<a href="' . append_sid("modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=move"). '"><img src="' . $images['topic_mod_move'] . '" alt="' . $lang['Move_topic'] . '" title="' . $lang['Move_topic'] . '" border="0" /></a> ';
	$topic_mod .= ( $forum_row['topic_status'] == TOPIC_UNLOCKED ) ? '<a href="' . append_sid("modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=lock") . '"><img src="' . $images['topic_mod_lock'] . '" alt="' . $lang['Lock_topic'] . '" title="' . $lang['Lock_topic'] . '" border="0" /></a> ' : '<a href="' . append_sid("modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=unlock") . '"><img src="' . $images['topic_mod_unlock'] . '" alt="' . $lang['Unlock_topic'] . '" title="' . $lang['Unlock_topic'] . '" border="0" /></a> ';
	$topic_mod .= '<a href="' . append_sid("modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=split") . '"><img src="' . $images['topic_mod_split'] . '" alt="' . $lang['Split_topic'] . '" title="' . $lang['Split_topic'] . '" border="0" /></a> ';
// Topic watch information
$s_watching_topic = '';
if ( $can_watch_topic )
	if ( $is_watching_topic )
		$s_watching_topic = '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&unwatch=topic&start=$start") . '">' . $lang['Stop_watching_topic'] . '</a>';
		$s_watching_topic_img = ( isset($images['Topic_un_watch']) ) ? '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&unwatch=topic&start=$start") . '"><img src="' . $images['Topic_un_watch'] . '" alt="' . $lang['Stop_watching_topic'] . '" title="' . $lang['Stop_watching_topic'] . '" border="0"></a>' : '';
		$s_watching_topic = '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&watch=topic&start=$start") . '">' . $lang['Start_watching_topic'] . '</a>';
		$s_watching_topic_img = ( isset($images['Topic_watch']) ) ? '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&watch=topic&start=$start") . '"><img src="' . $images['Topic_watch'] . '" alt="' . $lang['Stop_watching_topic'] . '" title="' . $lang['Start_watching_topic'] . '" border="0"></a>' : '';
// If we've got a hightlight set pass it on to pagination,
// I get annoyed when I lose my highlight after the first page.
$pagination = ( $highlight_active ) ? generate_pagination("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order&highlight=" . $HTTP_GET_VARS['highlight'], $total_replies, $board_config['posts_per_page'], $start) : generate_pagination("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order", $total_replies, $board_config['posts_per_page'], $start);
// Send vars to template
	'FORUM_ID' => $forum_id,
    'FORUM_NAME' => $forum_name,
    'TOPIC_ID' => $topic_id,
    'TOPIC_TITLE' => $topic_title,
	'PAGINATION' => $pagination,
	'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / $board_config['posts_per_page'] ) + 1 ), ceil( $total_replies / $board_config['posts_per_page'] )),
	'POST_IMG' => $post_img,
	'REPLY_IMG' => $reply_img,
 	'QUICK_REPLY_IMG' => $quick_reply_img, // Quick_Reply_MOD
   	'L_QUICK_REPLY_TOPIC' => $quick_reply_alt, // Quick_Reply_MOD
   	'L_EMPTY_MESSAGE' => $lang['Empty_message'], // Quick_Reply_MOD
   	'U_QUICK_REPLY' => "posting.$phpEx", // Quick_Reply_MOD
   	'U_HIDDEN_FORM_FIELDS' => ( ($userdata['user_attachsig'] ? '<input type="hidden" name="attach_sig" value="1" />' : "") . ($userdata['user_notify'] ? '<input type="hidden" name="notify" value="1" />' : "") . '<input type="hidden" name="mode" value="reply" /><input type="hidden" name="post" value="1"><input type="hidden" name="' . POST_TOPIC_URL . '" value="' . $topic_id . '" />' ), // Quick_Reply_MOD
	'L_AUTHOR' => $lang['Author'],
	'L_MESSAGE' => $lang['Message'],
	'L_POSTED' => $lang['Posted'],
	'L_POST_SUBJECT' => $lang['Post_subject'],
	'L_VIEW_NEXT_TOPIC' => $lang['View_next_topic'],
	'L_VIEW_PREVIOUS_TOPIC' => $lang['View_previous_topic'],
	'L_POST_NEW_TOPIC' => $post_alt,
	'L_POST_REPLY_TOPIC' => $reply_alt,
	'L_BACK_TO_TOP' => $lang['Back_to_top'],
	'L_DISPLAY_POSTS' => $lang['Display_posts'],
	'L_LOCK_TOPIC' => $lang['Lock_topic'],
	'L_UNLOCK_TOPIC' => $lang['Unlock_topic'],
	'L_MOVE_TOPIC' => $lang['Move_topic'],
	'L_SPLIT_TOPIC' => $lang['Split_topic'],
	'L_DELETE_TOPIC' => $lang['Delete_topic'],
	'L_GOTO_PAGE' => $lang['Goto_page'],
	'S_TOPIC_LINK' => POST_TOPIC_URL,
	'S_SELECT_POST_DAYS' => $select_post_days,
	'S_SELECT_POST_ORDER' => $select_post_order,
	'S_POST_DAYS_ACTION' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . '=' . $topic_id . "&start=$start"),
	'S_AUTH_LIST' => $s_auth_can,
	'S_TOPIC_ADMIN' => $topic_mod,
	'S_WATCH_TOPIC' => $s_watching_topic,
	'U_VIEW_TOPIC' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start&postdays=$post_days&postorder=$post_order&highlight=" . $HTTP_GET_VARS['highlight']),
	'U_VIEW_FORUM' => $view_forum_url,
	'U_VIEW_OLDER_TOPIC' => $view_prev_topic_url,
	'U_VIEW_NEWER_TOPIC' => $view_next_topic_url,
	'U_POST_NEW_TOPIC' => $new_topic_url,
	'U_POST_REPLY_TOPIC' => $reply_topic_url)
// Does this topic contain a poll?
if ( !empty($forum_row['topic_vote']) )
	$sql = "SELECT vd.vote_id, vd.vote_text, vd.vote_start, vd.vote_length, vr.vote_option_id, vr.vote_option_text, vr.vote_result
		FROM " . VOTE_DESC_TABLE . " vd, " . VOTE_RESULTS_TABLE . " vr
		WHERE vd.topic_id = $topic_id
			AND vr.vote_id = vd.vote_id
		ORDER BY vr.vote_option_id ASC";
		message_die(GENERAL_ERROR, "Could not obtain vote data for this topic", '', __LINE__, __FILE__, $sql);
	if ( $vote_info = $db->sql_fetchrowset($result) )
		$vote_options = count($vote_info);
		$vote_id = $vote_info[0]['vote_id'];
		$vote_title = $vote_info[0]['vote_text'];
		$sql = "SELECT vote_id
			FROM " . VOTE_USERS_TABLE . "
			WHERE vote_id = $vote_id
				AND vote_user_id = " . $userdata['user_id'];
			message_die(GENERAL_ERROR, "Could not obtain user vote data for this topic", '', __LINE__, __FILE__, $sql);
		$user_voted = ( $row = $db->sql_fetchrow($result) ) ? TRUE : 0;
		if ( isset($HTTP_GET_VARS['vote']) || isset($HTTP_POST_VARS['vote']) )
			$view_result = ( ( ( isset($HTTP_GET_VARS['vote']) ) ? $HTTP_GET_VARS['vote'] : $HTTP_POST_VARS['vote'] ) == 'viewresult' ) ? TRUE : 0;
			$view_result = 0;
		$poll_expired = ( $vote_info[0]['vote_length'] ) ? ( ( $vote_info[0]['vote_start'] + $vote_info[0]['vote_length'] < time() ) ? TRUE : 0 ) : 0;
		if ( $user_voted || $view_result || $poll_expired || !$is_auth['auth_vote'] || $forum_row['topic_status'] == TOPIC_LOCKED )
				'pollbox' => 'viewtopic_poll_result.tpl')
			$vote_results_sum = 0;
			for($i = 0; $i < $vote_options; $i++)
				$vote_results_sum += $vote_info[$i]['vote_result'];
			$vote_graphic = 0;
			$vote_graphic_max = count($images['voting_graphic']);
				$vote_percent = ( $vote_results_sum > 0 ) ? $vote_info[$i]['vote_result'] / $vote_results_sum : 0;
				$vote_graphic_length = round($vote_percent * $board_config['vote_graphic_length']);
				$vote_graphic_img = $images['voting_graphic'][$vote_graphic];
				$vote_graphic = ($vote_graphic < $vote_graphic_max - 1) ? $vote_graphic + 1 : 0;
					$vote_info[$i]['vote_option_text'] = preg_replace($orig_word, $replacement_word, $vote_info[$i]['vote_option_text']);
				$template->assign_block_vars("poll_option", array(
					'POLL_OPTION_CAPTION' => $vote_info[$i]['vote_option_text'],
					'POLL_OPTION_RESULT' => $vote_info[$i]['vote_result'],
					'POLL_OPTION_PERCENT' => sprintf("%.1d%%", ($vote_percent * 100)),
					'POLL_OPTION_IMG' => $vote_graphic_img,
					'POLL_OPTION_IMG_WIDTH' => $vote_graphic_length)
				'L_TOTAL_VOTES' => $lang['Total_votes'],
				'TOTAL_VOTES' => $vote_results_sum)
				'pollbox' => 'viewtopic_poll_ballot.tpl')
					'POLL_OPTION_ID' => $vote_info[$i]['vote_option_id'],
					'POLL_OPTION_CAPTION' => $vote_info[$i]['vote_option_text'])
				'L_SUBMIT_VOTE' => $lang['Submit_vote'],
				'L_VIEW_RESULTS' => $lang['View_results'],
				'U_VIEW_RESULTS' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order&vote=viewresult"))
			$s_hidden_fields = '<input type="hidden" name="topic_id" value="' . $topic_id . '"><input type="hidden" name="mode" value="vote">';
			$vote_title = preg_replace($orig_word, $replacement_word, $vote_title);
			'POLL_QUESTION' => $vote_title,
			'S_HIDDEN_FIELDS' => ( !empty($s_hidden_fields) ) ? $s_hidden_fields : '',
			'S_POLL_ACTION' => append_sid("posting.$phpEx?" . POST_TOPIC_URL . "=$topic_id"))
		$template->assign_var_from_handle('POLL_DISPLAY', 'pollbox');
// Update the topic view counter
$sql = "UPDATE " . TOPICS_TABLE . "
	SET topic_views = topic_views + 1
	WHERE topic_id = $topic_id";
if ( !$db->sql_query($sql) )
	message_die(GENERAL_ERROR, "Could not update topic views.", '', __LINE__, __FILE__, $sql);
// Okay, let's do the loop, yeah come on baby let's do the loop
// and it goes like this ...
for($i = 0; $i < $total_posts; $i++)
	$poster_id = $postrow[$i]['user_id'];
	$poster = ( $poster_id == ANONYMOUS ) ? $lang['Guest'] : $postrow[$i]['username'];
	$post_date = create_date($board_config['default_dateformat'], $postrow[$i]['post_time'], $board_config['board_timezone']);
	$poster_posts = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Posts'] . ': ' . $postrow[$i]['user_posts'] : '';
	$poster_from = ( $postrow[$i]['user_from'] && $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Location'] . ': ' . $postrow[$i]['user_from'] : '';
	$poster_joined = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Joined'] . ': ' . create_date($lang['DATE_FORMAT'], $postrow[$i]['user_regdate'], $board_config['board_timezone']) : '';
	$poster_money = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? ("純鐵礦: " . $postrow[$i]['user_money']) : ""; // Virtual_Money_MOD by OOHOO
	$poster_avatar = '';
	if ( $postrow[$i]['user_avatar_type'] && $poster_id != ANONYMOUS && $postrow[$i]['user_allowavatar'] )
		switch( $postrow[$i]['user_avatar_type'] )
			case USER_AVATAR_UPLOAD:
				$poster_avatar = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
				break;
			case USER_AVATAR_REMOTE:
				$poster_avatar = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
				break;
			case USER_AVATAR_GALLERY:
				$poster_avatar = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
				break;
	// Define the little post icon
	if ( $userdata['session_logged_in'] && $postrow[$i]['post_time'] > $userdata['user_lastvisit'] && $postrow[$i]['post_time'] > $topic_last_read )
		$mini_post_img = $images['icon_minipost_new'];
		$mini_post_alt = $lang['New_post'];
		$mini_post_img = $images['icon_minipost'];
		$mini_post_alt = $lang['Post'];
	$mini_post_url = append_sid("viewtopic.$phpEx?" . POST_POST_URL . '=' . $postrow[$i]['post_id']) . '#' . $postrow[$i]['post_id'];
	// Generate ranks, set them to empty string initially.
	$poster_rank = '';
	$rank_image = '';
	if ( $postrow[$i]['user_id'] == ANONYMOUS )
	else if ( $postrow[$i]['user_rank'] )
		for($j = 0; $j < count($ranksrow); $j++)
			if ( $postrow[$i]['user_rank'] == $ranksrow[$j]['rank_id'] && $ranksrow[$j]['rank_special'] )
				$poster_rank = $ranksrow[$j]['rank_title'];
				$rank_image = ( $ranksrow[$j]['rank_image'] ) ? '<img src="' . $ranksrow[$j]['rank_image'] . '" alt="' . $poster_rank . '" title="' . $poster_rank . '" border="0" /><br />' : '';
			if ( $postrow[$i]['user_posts'] >= $ranksrow[$j]['rank_min'] && !$ranksrow[$j]['rank_special'] )
	// Handle anon users posting with usernames
	if ( $poster_id == ANONYMOUS && $postrow[$i]['post_username'] != '' )
		$poster = $postrow[$i]['post_username'];
		$poster_rank = $lang['Guest'];
	$temp_url = '';
	if ( $poster_id != ANONYMOUS )
		$temp_url = append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$poster_id");
		$profile_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_profile'] . '" alt="' . $lang['Read_profile'] . '" title="' . $lang['Read_profile'] . '" border="0" /></a>';
		$profile = '<a href="' . $temp_url . '">' . $lang['Read_profile'] . '</a>';
		$temp_url = append_sid("privmsg.$phpEx?mode=post&" . POST_USERS_URL . "=$poster_id");
		$pm_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_pm'] . '" alt="' . $lang['Send_private_message'] . '" title="' . $lang['Send_private_message'] . '" border="0" /></a>';
		$pm = '<a href="' . $temp_url . '">' . $lang['Send_private_message'] . '</a>';
		if ( !empty($postrow[$i]['user_viewemail']) || $is_auth['auth_mod'] )
			$email_uri = ( $board_config['board_email_form'] ) ? append_sid("profile.$phpEx?mode=email&" . POST_USERS_URL .'=' . $poster_id) : 'mailto:' . $postrow[$i]['user_email'];
			$email_img = '<a href="' . $email_uri . '"><img src="' . $images['icon_email'] . '" alt="' . $lang['Send_email'] . '" title="' . $lang['Send_email'] . '" border="0" /></a>';
			$email = '<a href="' . $email_uri . '">' . $lang['Send_email'] . '</a>';
			$email_img = '';
			$email = '';
		$www_img = ( $postrow[$i]['user_website'] ) ? '<a href="' . $postrow[$i]['user_website'] . '" target="_userwww"><img src="' . $images['icon_www'] . '" alt="' . $lang['Visit_website'] . '" title="' . $lang['Visit_website'] . '" border="0" /></a>' : '';
		$www = ( $postrow[$i]['user_website'] ) ? '<a href="' . $postrow[$i]['user_website'] . '" target="_userwww">' . $lang['Visit_website'] . '</a>' : '';
		if ( !empty($postrow[$i]['user_icq']) )
			$icq_status_img = '<a href="http://wwp.icq.com/' . $postrow[$i]['user_icq'] . '#pager"><img src="http://web.icq.com/whitepages/online?icq=' . $postrow[$i]['user_icq'] . '&img=5" width="18" height="18" border="0" /></a>';
			$icq_img = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $postrow[$i]['user_icq'] . '"><img src="' . $images['icon_icq'] . '" alt="' . $lang['ICQ'] . '" title="' . $lang['ICQ'] . '" border="0" /></a>';
			$icq =  '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $postrow[$i]['user_icq'] . '">' . $lang['ICQ'] . '</a>';
			$icq_status_img = '';
			$icq_img = '';
			$icq = '';
		$aim_img = ( $postrow[$i]['user_aim'] ) ? '<a href="aim:goim?screenname=' . $postrow[$i]['user_aim'] . '&message=Hello+Are+you+there?"><img src="' . $images['icon_aim'] . '" alt="' . $lang['AIM'] . '" title="' . $lang['AIM'] . '" border="0" /></a>' : '';
		$aim = ( $postrow[$i]['user_aim'] ) ? '<a href="aim:goim?screenname=' . $postrow[$i]['user_aim'] . '&message=Hello+Are+you+there?">' . $lang['AIM'] . '</a>' : '';
		$msn_img = ( $postrow[$i]['user_msnm'] ) ? '<a href="' . $temp_url . '"><img src="' . $images['icon_msnm'] . '" alt="' . $lang['MSNM'] . '" title="' . $lang['MSNM'] . '" border="0" /></a>' : '';
		$msn = ( $postrow[$i]['user_msnm'] ) ? '<a href="' . $temp_url . '">' . $lang['MSNM'] . '</a>' : '';
		$yim_img = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
		$yim = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg">' . $lang['YIM'] . '</a>' : '';
		$profile_img = '';
		$profile = '';
		$pm_img = '';
		$pm = '';
		$email_img = '';
		$email = '';
		$www_img = '';
		$www = '';
		$icq_img = '';
		$icq = '';
		$aim_img = '';
		$aim = '';
		$msn_img = '';
		$msn = '';
		$yim_img = '';
		$yim = '';
	$temp_url = append_sid("posting.$phpEx?mode=quote&" . POST_POST_URL . "=" . $postrow[$i]['post_id']);
	$quote_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_quote'] . '" alt="' . $lang['Reply_with_quote'] . '" title="' . $lang['Reply_with_quote'] . '" border="0" /></a>';
	$quote = '<a href="' . $temp_url . '">' . $lang['Reply_with_quote'] . '</a>';
	$temp_url = append_sid("search.$phpEx?search_author=" . urlencode($postrow[$i]['username']) . "&showresults=posts");
	$search_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_search'] . '" alt="' . $lang['Search_user_posts'] . '" title="' . $lang['Search_user_posts'] . '" border="0" /></a>';
	$search = '<a href="' . $temp_url . '">' . $lang['Search_user_posts'] . '</a>';
	if ( ( $userdata['user_id'] == $poster_id && $is_auth['auth_edit'] ) || $is_auth['auth_mod'] )
		$temp_url = append_sid("posting.$phpEx?mode=editpost&" . POST_POST_URL . "=" . $postrow[$i]['post_id']);
		$edit_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_edit'] . '" alt="' . $lang['Edit_delete_post'] . '" title="' . $lang['Edit_delete_post'] . '" border="0" /></a>';
		$edit = '<a href="' . $temp_url . '">' . $lang['Edit_delete_post'] . '</a>';
		$edit_img = '';
		$edit = '';
		$temp_url = append_sid("modcp.$phpEx?mode=ip&" . POST_POST_URL . "=" . $postrow[$i]['post_id'] . "&" . POST_TOPIC_URL . "=" . $topic_id);
		$ip_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_ip'] . '" alt="' . $lang['View_IP'] . '" title="' . $lang['View_IP'] . '" border="0" /></a>';
		$ip = '<a href="' . $temp_url . '">' . $lang['View_IP'] . '</a>';
		$temp_url = append_sid("posting.$phpEx?mode=delete&" . POST_POST_URL . "=" . $postrow[$i]['post_id']);
		$delpost_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_delpost'] . '" alt="' . $lang['Delete_post'] . '" title="' . $lang['Delete_post'] . '" border="0" /></a>';
		$delpost = '<a href="' . $temp_url . '">' . $lang['Delete_post'] . '</a>';
		$ip_img = '';
		$ip = '';
		if ( $userdata['user_id'] == $poster_id && $is_auth['auth_delete'] && $i == $total_replies - 1 )
			$delpost_img = '<a href="' . $temp_url . '">' . $lang['Delete_post'] . '</a>';
			$delpost_img = '';
			$delpost = '';
	$post_subject = ( $postrow[$i]['post_subject'] != '' ) ? $postrow[$i]['post_subject'] : '';
	$message = $postrow[$i]['post_text'];
	$bbcode_uid = $postrow[$i]['bbcode_uid'];
	$user_sig = ( $postrow[$i]['enable_sig'] && $postrow[$i]['user_sig'] != '' && $board_config['allow_sig'] ) ? $postrow[$i]['user_sig'] : '';
	$user_sig_bbcode_uid = $postrow[$i]['user_sig_bbcode_uid'];
	// Note! The order used for parsing the message _is_ important, moving things around could break any
	// output
	// If the board has HTML off but the post has HTML
	// on then we process it, else leave it alone
	if ( !$board_config['allow_html'] )
		if ( $user_sig != '' && $userdata['user_allowhtml'] )
			$user_sig = preg_replace('#(<)([\/]?.*?)(>)#is', "<\\\2>", $user_sig);
		if ( $postrow[$i]['enable_html'] )
			$message = preg_replace('#(<)([\/]?.*?)(>)#is', "<\\\2>", $message);
	// Parse message and/or sig for BBCode if reqd
	if ( $board_config['allow_bbcode'] )
		if ( $user_sig != '' && $user_sig_bbcode_uid != '' )
			$user_sig = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($user_sig, $user_sig_bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $user_sig);
		if ( $bbcode_uid != '' )
			$message = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($message, $bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $message);
	if ( $user_sig != '' && $board_config['allow_sig'] )
		$user_sig = make_clickable($user_sig);
	$message = make_clickable($message);
	// Highlight active words (primarily for search)
	if ( $highlight_active )
		if ( preg_match('/<.*>/', $message) )
			$message = preg_replace($highlight_match, '<!-- #sh -->\1<!-- #eh -->', $message);
			$end_html = 0;
			$start_html = 1;
			$temp_message = '';
			$message = ' ' . $message . ' ';
			while( $start_html = strpos($message, '<', $start_html) )
				$grab_length = $start_html - $end_html - 1;
				$temp_message .= substr($message, $end_html + 1, $grab_length);
				if ( $end_html = strpos($message, '>', $start_html) )
					$length = $end_html - $start_html + 1;
					$hold_string = substr($message, $start_html, $length);
					if ( strrpos(' ' . $hold_string, '<') != 1 )
						$end_html = $start_html + 1;
						$end_counter = 1;
						while ( $end_counter && $end_html < strlen($message) )
							if ( substr($message, $end_html, 1) == '>' )
								$end_counter--;
							else if ( substr($message, $end_html, 1) == '<' )
								$end_counter++;
							$end_html++;
						$hold_string = str_replace('<!-- #sh -->', '', $hold_string);
						$hold_string = str_replace('<!-- #eh -->', '', $hold_string);
					else if ( $hold_string == '<!-- #sh -->' )
						$hold_string = str_replace('<!-- #sh -->', '<span style="color:#' . $theme['fontcolor3'] . '"><b>', $hold_string);
					else if ( $hold_string == '<!-- #eh -->' )
						$hold_string = str_replace('<!-- #eh -->', '</b></span>', $hold_string);
					$temp_message .= $hold_string;
					$start_html += $length;
					$start_html = strlen($message);
			$grab_length = strlen($message) - $end_html - 1;
			$message = trim($temp_message);
			$message = preg_replace($highlight_match, '<span style="color:#' . $theme['fontcolor3'] . '"><b>\1</b></span>', $message);
	// Replace naughty words
		if ( $user_sig != '' )
			$user_sig = preg_replace($orig_word, $replacement_word, $user_sig);
		$post_subject = preg_replace($orig_word, $replacement_word, $post_subject);
		$message = preg_replace($orig_word, $replacement_word, $message);
	// Parse smilies
	if ( $board_config['allow_smilies'] )
		if ( $postrow[$i]['user_allowsmile'] && $user_sig != '' )
			$user_sig = smilies_pass($user_sig);
		if ( $postrow[$i]['enable_smilies'] )
			$message = smilies_pass($message);
	// Replace newlines (we use this rather than nl2br because
	// till recently it wasn't XHTML compliant)
		$user_sig = '<br />_________________<br />' . str_replace("
<br />
", $user_sig);
	$message = str_replace("
<br />
", $message);
	// Editing information
	if ( $postrow[$i]['post_edit_count'] )
		$l_edit_time_total = ( $postrow[$i]['post_edit_count'] == 1 ) ? $lang['Edited_time_total'] : $lang['Edited_times_total'];
		$l_edited_by = '<br /><br />' . sprintf($l_edit_time_total, $poster, create_date($board_config['default_dateformat'], $postrow[$i]['post_edit_time'], $board_config['board_timezone']), $postrow[$i]['post_edit_count']);
		$l_edited_by = '';
	// Again this will be handled by the templating
	// code at some point
// RPG Ranking Hack
   if($postrow[$i]['user_id'] != ANONYMOUS )
      $sql = "SELECT COUNT(topic_id) AS count_topics, " .
             "SUM(topic_replies) AS sum_topic_replies, " .
             "SUM(topic_views) AS sum_topic_views " .
             "FROM " . TOPICS_TABLE . " " .
             "WHERE topic_poster = " . $postrow[$i]['user_id'];
                $rr_row = $db->sql_fetchrow($result);
                // 發表的主題總數
                $count_topics = $rr_row['count_topics'];
                // 所有主題的回應總數
                $sum_topic_replies = $rr_row['sum_topic_replies'];
                // 主題人氣(觀看數)
                $sum_topic_views = $rr_row['sum_topic_views'];
		$profiledata = get_userdata;
                // 發文總數
                $sum_posts = $profiledata['user_posts'];
                // 回應文章總數 = 發文總數 - 發表的主題總數
                $count_replies = $sum_posts - $count_topics;
                                // 魅力值 = (發表的主題總數*100 + 所有主題的回應總數*5 + 回應文章總數*100 + 主題人氣(觀看數)) / ((發文總數+1)*100)
      $rr_hack = ($count_topics * 100 + $sum_topic_replies * 5 + $count_replies * 100 + $sum_topic_views) / (($sum_posts+1)*100);
                // 取小數點後一位
                $rr_hack = "魅力值: " . sprintf("%01.2f", $rr_hack);
      $rr_hack = "";
	$template->assign_block_vars('postrow', array(
		'ROW_CLASS' => $row_class,
		'POSTER_NAME' => $poster,
		'POSTER_RANK' => $poster_rank,
		'RANK_IMAGE' => $rank_image,
		'POSTER_JOINED' => $poster_joined,
		'POSTER_POSTS' => $poster_posts,
		'POSTER_FROM' => $poster_from,
		'POSTER_AVATAR' => $poster_avatar,
		'POSTER_ONLINE' => (($postrow[$i]['user_session_time'] >= ( time() - 300 )) && ($postrow[$i]['user_allow_viewonline'])) ? '<span <td><img src="templates/subSilver/images/Online.gif" alt="上線中...." width="26" height="18" border="0" /></td></span>' : '<span <td><img src="templates/subSilver/images/Offline.gif" alt="離線中...." width="26" height="18" border="0" /></td></span>',
		'POSTER_MONEY' => $poster_money, // Virtual_Money_MOD by OOHOO
		'POST_DATE' => $post_date,
		'POST_SUBJECT' => $post_subject,
		'MESSAGE' => $message,
		'SIGNATURE' => $user_sig,
		'EDITED_MESSAGE' => $l_edited_by,
		'MINI_POST_IMG' => $mini_post_img,
		'PROFILE_IMG' => $profile_img,
		'PROFILE' => $profile,
		'SEARCH_IMG' => $search_img,
		'SEARCH' => $search,
		'PM_IMG' => $pm_img,
		'PM' => $pm,
		'EMAIL_IMG' => $email_img,
		'EMAIL' => $email,
		'WWW_IMG' => $www_img,
		'WWW' => $www,
		'ICQ_STATUS_IMG' => $icq_status_img,
		'ICQ_IMG' => $icq_img,
		'ICQ' => $icq,
		'AIM_IMG' => $aim_img,
		'AIM' => $aim,
		'MSN_IMG' => $msn_img,
		'MSN' => $msn,
		'YIM_IMG' => $yim_img,
		'YIM' => $yim,
		'EDIT_IMG' => $edit_img,
		'EDIT' => $edit,
		'QUOTE_IMG' => $quote_img,
		'QUOTE' => $quote,
		'IP_IMG' => $ip_img,
		'IP' => $ip,
		'DELETE_IMG' => $delpost_img,
		'DELETE' => $delpost,
		'L_MINI_POST_ALT' => $mini_post_alt,
		'RR_HACK' => $rr_hack,
		'U_MINI_POST' => $mini_post_url,
		'U_POST_ID' => $postrow[$i]['post_id'])
$template->pparse('body');
viewtopic_body.tpl
<table width="100%" cellspacing="2" cellpadding="2" border="0">
	<td align="left" valign="bottom" colspan="2"><a class="maintitle" href="{U_VIEW_TOPIC}">{TOPIC_TITLE}</a><br />
	  <span class="gensmall"><b>{PAGINATION}</b><br />
	    </span></td>
</table>
	<td align="left" valign="bottom" nowrap="nowrap"><span class="nav"><a href="{U_POST_NEW_TOPIC}"><img src="{POST_IMG}" border="0" alt="{L_POST_NEW_TOPIC}" align="middle" /></a>   <a href="{U_POST_REPLY_TOPIC}"><img src="{REPLY_IMG}" border="0" alt="{L_POST_REPLY_TOPIC}" align="middle" /></a></span></td>
	<td align="left" valign="middle" width="100%"><span class="nav">   <a href="{U_INDEX}" class="nav">{L_INDEX}</a>
	  -> <a href="{U_VIEW_FORUM}" class="nav">{FORUM_NAME}</a></span></td>
</table>
<table class="forumline" width="100%" cellspacing="1" cellpadding="3" border="0">
	<tr align="right">
		<td class="catHead" colspan="2" height="28"><span class="nav"><a href="{U_VIEW_OLDER_TOPIC}" class="nav">{L_VIEW_PREVIOUS_TOPIC}</a> :: <a href="{U_VIEW_NEWER_TOPIC}" class="nav">{L_VIEW_NEXT_TOPIC}</a>  </span></td>
	{POLL_DISPLAY}
		<th class="thLeft" width="150" height="26" nowrap="nowrap">{L_AUTHOR}</th>
		<th class="thRight" nowrap="nowrap">{L_MESSAGE}</th>
	<!-- BEGIN postrow -->
		<td width="150" align="left" valign="top" class="{postrow.ROW_CLASS}"><span class="name"><a name="{postrow.U_POST_ID}"></a><b>{postrow.POSTER_NAME}</b></span><br /><span class="postdetails">{postrow.POSTER_RANK}<br />{postrow.RANK_IMAGE}{postrow.POSTER_AVATAR}<br /><br />{postrow.POSTER_JOINED}<br />{postrow.POSTER_POSTS}<br />{postrow.POSTER_FROM}<br />{postrow.POSTER_MONEY}<br />{postrow.RR_HACK}<br />{postrow.POSTER_ONLINE}</span><br /></td>
		<td class="{postrow.ROW_CLASS}" width="100%" height="28" valign="top"><table width="100%" border="0" cellspacing="0" cellpadding="0">
				<td width="100%"><a href="{postrow.U_MINI_POST}"><img src="{postrow.MINI_POST_IMG}" width="12" height="9" alt="{postrow.L_MINI_POST_ALT}" title="{postrow.L_MINI_POST_ALT}" border="0" /></a><span class="postdetails">{L_POSTED}: {postrow.POST_DATE}<span class="gen"> </span>   {L_POST_SUBJECT}: {postrow.POST_SUBJECT}</span></td>
				<td valign="top" align="right" nowrap="nowrap">{postrow.QUOTE_IMG} {postrow.EDIT_IMG} {postrow.DELETE_IMG} {postrow.IP_IMG}</td>
				<td colspan="2"><hr /></td>
				<td colspan="2"><span class="postbody">{postrow.MESSAGE}{postrow.SIGNATURE}</span><span class="gensmall">{postrow.EDITED_MESSAGE}</span></td>
		</table></td>
		<td class="{postrow.ROW_CLASS}" width="150" align="left" valign="middle"><span class="nav"><a href="#top" class="nav">{L_BACK_TO_TOP}</a></span></td>
		<td class="{postrow.ROW_CLASS}" width="100%" height="28" valign="bottom" nowrap="nowrap"><table cellspacing="0" cellpadding="0" border="0" height="18" width="18">
				<td valign="middle" nowrap="nowrap">{postrow.PROFILE_IMG} {postrow.PM_IMG} {postrow.EMAIL_IMG} {postrow.WWW_IMG} {postrow.AIM_IMG} {postrow.YIM_IMG} {postrow.MSN_IMG}<script language="JavaScript" type="text/javascript"><!--
	if ( navigator.userAgent.toLowerCase().indexOf('mozilla') != -1 && navigator.userAgent.indexOf('5.') == -1 )
		document.write(' {postrow.ICQ_IMG}');
		document.write('</td><td> </td><td valign="top" nowrap="nowrap"><div style="position:relative"><div style="position:absolute">{postrow.ICQ_IMG}</div><div style="position:absolute;left:3px;top:-1px">{postrow.ICQ_STATUS_IMG}</div></div>');
				//--></script><noscript>{postrow.ICQ_IMG}</noscript></td>
		</table></td>
		<td class="spaceRow" colspan="2" height="1"><img src="templates/subSilver/images/spacer.gif" alt="" width="1" height="1" /></td>
	<!-- END postrow -->
	<tr align="center">
		<td class="catBottom" colspan="2" height="28"><table cellspacing="0" cellpadding="0" border="0">
			<tr><form method="post" action="{S_POST_DAYS_ACTION}">
				<td align="center"><span class="gensmall">{L_DISPLAY_POSTS}: {S_SELECT_POST_DAYS} {S_SELECT_POST_ORDER} <input type="submit" value="{L_GO}" class="liteoption" name="submit" /></span></td>
			</form></tr>
		</table></td>
</table>
<table width="100%" cellspacing="2" cellpadding="2" border="0" align="center">
	<td align="left" valign="middle" nowrap="nowrap"><span class="nav"><a href="{U_POST_NEW_TOPIC}"><img src="{POST_IMG}" border="0" alt="{L_POST_NEW_TOPIC}" align="middle" /></a>   <a href="{U_POST_REPLY_TOPIC}"><img src="{REPLY_IMG}" border="0" alt="{L_POST_REPLY_TOPIC}" align="middle" /></a></span></td>
	<td align="right" valign="top" nowrap="nowrap"><span class="gensmall">{S_TIMEZONE}</span><br /><span class="nav">{PAGINATION}</span>
	  </td>
	<td align="left" colspan="3"><span class="nav">{PAGE_NUMBER}</span></td>
</table>
<table width="100%" cellspacing="2" border="0" align="center">
   <td width="40%" valign="top" nowrap="nowrap" align="left">
     <span class="gensmall">{S_WATCH_TOPIC}</span><br /> <br />{S_TOPIC_ADMIN}
   </td>
</table>
   <td valign="top" align="left">
     <form name="quick_reply" action="{U_QUICK_REPLY}" method="post"><!-- Quick_Reply_MOD -->
      <!-- BEGIN quick_reply_anonymous -->
      <span class="gensmall"><b>{L_USERNAME}</b></span><br />
      <span class="genmed"><input type="text" class="post" tabindex="1" name="username" size="25" maxlength="25" value="" /></span><br />
      <!-- END quick_reply_anonymous -->
      <textarea name="message" rows="7" cols="35" wrap="virtual" style="width:500px" class="post" onclick="{if(document.quick_reply.message.value=='{L_QUICK_REPLY_TOPIC}') document.quick_reply.message.value=''}">{L_QUICK_REPLY_TOPIC}</textarea><br />
      {U_HIDDEN_FORM_FIELDS}
      <input type="image" src="{QUICK_REPLY_IMG}" border="0" alt="{L_QUICK_REPLY_TOPIC}" onClick="if(document.quick_reply.message.value == '{L_QUICK_REPLY_TOPIC}' || document.quick_reply.message.value == ''){ alert('{L_EMPTY_MESSAGE}'); return false;}else{ return true;}" />
     </form>
   </td>
   <td align="right" valign="top" nowrap="nowrap">{JUMPBOX}<span class="gensmall">{S_AUTH_LIST}</span></td>
</table>
文章 小竹子 »
那個不是 無聊阿 那篇同樣的嗎
