[問題] 使用PHPADMIN出現這段...
faithdata
文章: 37
註冊時間: 2005-02-01 16:52
文章 faithdata »
The mbstring PHP extension was not found and you seem to be using multibyte charset. Without mbstring extension phpMyAdmin is unable to split strings correctly and it may result in unexpected results.
一連進去 底下會有這段 請問是哪裡有問題呢
faithdata
文章: 37
文章 faithdata »
沒人知道問題出在哪嗎..
