我的是AppServ 2.4.3必須在設定檔內設定 $cfg['PmaAbsoluteUri'] !
The mbstring PHP extension was not found and you seem to be using multibyte charset. Without mbstring extension phpMyAdmin is unable to split strings correctly and it may result in unexpected results.
Thanks
