各位大大,
救命啊!!!
我有個會員天天灌水...
我又沒有那麼多刪除他的文章,
我已給了警告牌,
我已發私人訊息,
但沒用的文章一天天地增加,
沒有足夠時間刪除......
我想問問各位有沒有mod是可以刪除或移動會員的所有文章嗎???
或是有更好的方法???
[問題]有沒有mod是可以刪除或移動會員的所有文章???
- benny777ex
- 星球公民
- 文章: 48
- 註冊時間: 2004-06-23 16:09
- 來自: HK
- 聯繫:
~benny777ex
Re: [問題] 救命啊!!!
砍了他帳號...= =benny777ex 寫:各位大大,
救命啊!!!
我有個會員天天灌水...
我又沒有那麼多刪除他的文章,
我已給了警告牌,
我已發私人訊息,
但沒用的文章一天天地增加,
沒有足夠時間刪除......
或是有更好的方法???
或是直接封她ip ...
也可以用"Prune User Posts刪除會員的文章"這個外掛
http://phpbb-tw.net/phpbb/viewtopic.php?p=156698#156698
這外掛可以刪除該會員的所有文章,也可以在個別版區刪除的。
我也正在使用中,也不錯耶~
我也正在使用中,也不錯耶~
●架設環境:付費空間 [Unix]
●上網方式:香港區網 [和記]
●phpBB2 版本:phpBB 2.0.16
●MySQL 版本 4.0.17
●phpMyAdmin 2.5.6
●PHP 版本: 4.3.10
●上網方式:香港區網 [和記]
●MySQL 版本 4.0.17
●phpMyAdmin 2.5.6
●PHP 版本: 4.3.10
fish206452
- 星球公民
- 文章: 42
- 註冊時間: 2005-02-22 03:45
有誰可以中文化呢,
小弟是英文白吃
看了霧煞煞
小弟是英文白吃
看了霧煞煞
<?php
$lang['Prune_user_posts'] = 'Prune User Posts';
$lang['Prune_explain'] = 'Welcome to the prune user posts Admin module addon for phpBB. This script allows you to prune posts
based on a wide range of criteria.';
$lang['Forums_to_prune'] = 'Forums to Prune';
$lang['Forums_to_prune_explain'] = 'Check the box to prune posts in that forum. You can check multiple forums. (Note for
large forums: You should only do a couple of forums at a time if you\'re pruning many posts)';
$lang['Users_to_prune'] = 'Users to Prune';
$lang['Username_explain'] = 'Prune posts made by this specific user';
$lang['All_users_explain'] = 'Prune posts by all users';
$lang['Banned_users'] = 'Banned users';
$lang['Banned_users_explain'] = 'Prune posts made by all users that have been banned (as per the banlist)';
$lang['Group'] = 'Group';
$lang['Group_explain'] = 'Prune posts made by users in this specific group';
$lang['IP_explain'] = 'Prune posts made by a specific ip address (xxx.xxx.xxx.xxx), wildcard (xxx.xxx.xxx.*) or range
(xxx.xxx.xxx.xxx-yyy.yyy.yyy.yyy). Note: the last quad .255 is considered the range of all the IPs in that quad. If you enter
10.0.0.255, it is just like entering 10.0.0.* (No IP is assigned .255 for that matter, it is reserved). Where you may
encounter this is in ranges, 10.0.0.5-10.0.0.255 is the same as "10.0.0.*" . You should really enter 10.0.0.5-10.0.0.254 .';
$lang['Banned_IPs'] = 'Banned IP Addresses';
$lang['Banned_IPs_explain'] = 'Prune posts made by all IPs in the banned list.';
$lang['Guest_posters'] = 'Guest Posters';
$lang['Guest_posters_explain'] = 'Prune posts made by guest posters only (Users not logged in).';
$lang['Date_criteria'] = 'Date Criteria';
$lang['Before'] = 'Before';
$lang['On'] = 'On';
$lang['After'] = 'After';
$lang['the_last'] = 'the last';
$lang['Seconds'] = 'Seconds';
$lang['Minutes'] = 'Minutes';
$lang['By_time_explain'] = 'Prune posts based on the above time. Please note only whole numbers are accepted, there is no
reason to use decimals. (If you need .5 days, input 12 and select hours).';
$lang['ddmmyyyy'] = '(dd/mm/yyyy)';
$lang['Date_explain'] = 'Prune posts on above date criteria. Note dates are limited to roughly 1970 - 2038 (4 Bit unix
timestamp limit)';
$lang['to'] = 'to';
$lang['Range_explain'] = 'Prune posts between both dates. Dates are subject to above limits.';
$lang['All_posts_explain'] = 'Prune all posts regardless of time.';
$lang['Pruning_options'] = 'Pruning Options';
$lang['Prune_remove_topics'] = 'Remove Topics by User(s)?';
$lang['Prune_remove_topics_explain'] = 'If the user(s) you selected started the topic and others have replied to the topic,
would you like the entire topic removed?';
$lang['Exempt_stickies'] = 'Exempt Stickies?';
$lang['Exempt_stickies_explain'] = 'Do not prune posts in stickied topics.';
$lang['Exempt_announcements'] = 'Exempt Announcements?';
$lang['Exempt_announcements_explain'] = 'Do not prune posts in Announcements.';
$lang['Exempt_open'] = 'Exempt Open Topics?';
$lang['Exempt_open_explain'] = 'Do not prune posts in topics that are still open. (e.g. Select this as yes to prune locked
topics only)';
$lang['Exempt_polls'] = 'Exempt Polls?';
$lang['Exempt_polls_explain'] = 'Do not prune posts in topics with Polls.';
$lang['Adjust_post_counts'] = 'Adjust Post Counts?';
$lang['Adjust_post_counts_explain'] = 'Update user\'s post counts to reflect posts that were deleted.';
$lang['Update_search'] = 'Update Search Tables?';
$lang['Update_search_explain'] = 'Whether posts should be removed from the search tables. If you select No, you will need to
manually rebuild the search tables. You should only select No if you have a very large board on a very slow server pruning
many posts.';
$lang['Prune_invalid_mode'] = 'Unable to Prune - Invalid mode';
$lang['Prune_invalid_IP'] = 'Invalid IP Address entered';
$lang['Prune_invalid_date'] = 'Invalid date entered.';
$lang['Prune_invalid_range'] = 'Invalid IP Range entered';
$lang['No_banned_IPs'] = 'There are no banned IP Addresses';
$lang['No_forums_selected'] = 'Unable to start pruning - No forums were selected';
$lang['Prune_no_posts'] = 'Unable to start pruning - No posts were found to prune';
$lang['Prune_finished'] = 'Pruning successfully completed.<br /><br />Return to the <a href="%s">Prune User Posts</a>
page.<br /><br />Return to the <a href="%s">Admin Index</a>.';
?>台灣網路即將死亡
http://203.70.82.50/cht.txt
$lang['Prune_user_posts'] = '刪除會員的文章';
$lang['Prune_explain'] = '你可以使用這些工具來刪除特定使用者在所有版面的文章.';
$lang['Forums_to_prune'] = '指定版面';
$lang['Forums_to_prune_explain'] = '選取要刪除的文章發表在哪個版面? 你能選取多個版面. (刪除較大的版面時, 需要注意到: 同一時段, 你應該只一次刪除兩個版面的文章.)';
$lang['Users_to_prune'] = '指定會員';
$lang['Username_explain'] = '刪除某一個會員的文章';
$lang['All_users_explain'] = '刪除所有會員的文章';
$lang['Banned_users'] = '禁止會員';
$lang['Banned_users_explain'] = '刪除所有被禁止會員所發表的文章';
$lang['Group'] = '群組';
\n$lang['Group_explain'] = '刪除某一個群組的文章';
$lang['IP_explain'] = 'IP 位址有三種表示方法: 1.(xxx.xxx.xxx.xxx), 萬用字元(xxx.xxx.xxx.*), 或範圍(xxx.xxx.xxx.xxx-yyy.yyy.yyy.yyy).';
$lang['Banned_IPs'] = '禁止的 IP 位址';
$lang['Banned_IPs_explain'] = '刪除所有來自禁止的 IP 位址所發表的文章';
$lang['Guest_posters'] = '訪客的文章';
$lang['Guest_posters_explain'] = '刪除所有訪客(未註冊者)的文章';
$lang['Date_criteria'] = '日期標準';
$lang['Before'] = '之前';
$lang['On'] = '在';
$lang['After'] = '之後';
$lang['the_last'] = '最後';
$lang['Seconds'] = '秒';
$lang['Minutes'] = '分';
$lang['By_time_explain'] = '依照時間的設定刪除文章. 注意只有完整的數字才是被允許的. (假如你需要的時間只是半天, 那麼請輸入 12 小時.)';
$lang['Date_explain'] = '依照日期的設定刪除文章. 注意: 年代的有效範圍為 1970 - 2038.';
$lang['to'] = '到';
$lang['Range_explain'] = '依照日期的範圍內刪除文章.';
$lang['All_posts_explain'] = '不管時間的設定, 刪除所有的文章.';
$lang['Pruning_options'] = '刪除設定';
$lang['Prune_remove_topics'] = '刪除會員所發表的主題?';
$lang['Prune_remove_topics_explain'] = '是否刪除該會員所有發表以及回覆的文章?';
$lang['Exempt_stickies'] = '置頂的文章除外?';
$lang['Exempt_stickies_explain'] = '不要刪除置頂的文章.';
$lang['Exempt_announcements'] = '公告的文章除外?';
$lang['Exempt_announcements_explain'] = '不要刪除公告的文章.';
$lang['Exempt_open'] = '公開的文章除外?';
$lang['Exempt_open_explain'] = '不要刪除公開的文章. (也就是說: 只刪除被鎖定的文章.)';
$lang['Exempt_polls'] = '票選的文章除外?';
$lang['Exempt_polls_explain'] = '不要刪除含有票選活動的文章.';
$lang['Adjust_post_counts'] = '調整文章的數字?';
$lang['Adjust_post_counts_explain'] = '對應被刪除的文章, 更新會員文章的數字.';
$lang['Update_search'] = '更新搜尋的資料表?';
$lang['Update_search_explain'] = '是否從搜尋的資料表中移除文章? 假如你選擇否, 那麼你應該手動去更新搜尋資料表.';
$lang['Prune_invalid_mode'] = '不能刪除 - 無效的模式';
$lang['Prune_invalid_IP'] = '無效的 IP 位址';
$lang['Prune_invalid_date'] = '無效的日期';
$lang['Prune_invalid_range'] = '無效的 IP 範圍';
$lang['No_banned_IPs'] = '沒有被禁止的 IP 位址';
$lang['No_forums_selected'] = '不能開始刪除 - 沒有被選取的版面';
$lang['Prune_no_posts'] = '不能開始刪除 - 沒有被發現的文章';
$lang['Prune_finished'] = '刪除已經成功完成<br /><br />回到<a href="%s">刪除會員的文章</a><br /><br />回到<a href="%s">控制台首頁</a>';
PHPBB:2.0.20
OS:LINUX
風格: ICG
快速程式:無
上網方式:Hinet 8m/640
架設環境:竹貓空間
OS:LINUX
風格: ICG
快速程式:無
上網方式:Hinet 8m/640
架設環境:竹貓空間
