找到\r
$filename = [color=red]phpbb_realpath[/color]($this->root . '/' . $filename);
$filename = ($rp_filename = [color=red]phpbb_realpath[/color]($this->root . '/' . $filename)) ? $rp_filename : $filename;但我的 template.php 中並無類似的字串,不知如何修改?請大家幫忙一下!
由於檔案很大,只貼出可能相關的程式碼.
我的 template.php 相關的程式碼如下:
// search if this file is part of a sub-template
$sub_tpl_file = '';
$sub_css_file = '';
$sub_img_file = '';
$sub_img_path = '';
$template_path = 'templates/';
$template_name = substr( $this->root, strpos($this->root, $template_path) + strlen($template_path) );
$real_root = $this->root;
if ( $board_config['version'] > '.0.5' )
$real_root = @[color=red]phpbb_realpath[/color]($this->root);
if (substr($filename, 0, 1) != '/')
$found = false;
$num_fids = count($fids);
for ($i = 0; !$found && ($i < $num_fids); $i++)
$key = $fids[$i];代碼: 選擇全部
// Check if sub_templates are defined for this theme
$sub_templates_cfg = @[color=red]phpbb_realpath[/color]($this->root . '/sub_templates.cfg');
$sub_templates_cfg = $this->root . '/sub_templates.cfg';
@include($sub_templates_cfg);
if ( isset($sub_templates) )
