雖然這可能跟phpBB無關,但是我是使用貴站的阿帕器整合版,所以不知道有人有人可以幫我看一下怎麼修復數據庫.....QQ
Query Error: SELECT * FROM cdb_mypetdata where 1 ORDER BY mypetexp DESC Limit 1
The URL Is:
http://timel2.no-ip.com/phpwind/petshop.php
MySQL Server Error:
Got error 127 from table handler ( 1030 )
You Can Get Help In:
http://www.phpwind.net
請有能力的大大們幫我一下,小弟無法解決阿.............
[求助]停電之後重新啟動伺服器就變成這樣子....
我使用後台的資料庫修復,還是一樣,以下是數據庫出現的資料
資料庫優化信息
資料庫表 操作 信息
phpwind.pw_actions check status:OK
phpwind.pw_actions optimize status:Table is already up to date
phpwind.pw_smiles check status:OK
phpwind.pw_smiles optimize status:Table is already up to date
phpwind.pw_adminset check status:OK
phpwind.pw_adminset optimize status:Table is already up to date
phpwind.pw_announce check status:OK
phpwind.pw_announce optimize status:Table is already up to date
phpwind.pw_bbsinfo check warning:2 clients is using or hasn't closed the table properly
phpwind.pw_bbsinfo check status:OK
phpwind.pw_bbsinfo optimize status:Table is already up to date
phpwind.pw_config check status:OK
phpwind.pw_config optimize status:Table is already up to date
phpwind.pw_hack check status:OK
phpwind.pw_hack optimize status:Table is already up to date
phpwind.pw_schcache check warning:1 clients is using or hasn't closed the table properly
phpwind.pw_schcache check status:OK
phpwind.pw_schcache optimize status:OK
phpwind.pw_sharelinks check status:OK
phpwind.pw_sharelinks optimize status:Table is already up to date
phpwind.pw_styles check status:OK
phpwind.pw_styles optimize status:Table is already up to date
phpwind.pw_usergroups check status:OK
phpwind.pw_usergroups optimize status:Table is already up to date
phpwind.pw_wordfb check status:OK
phpwind.pw_wordfb optimize status:Table is already up to date
phpwind.pw_credits check status:OK
phpwind.pw_credits optimize status:Table is already up to date
phpwind.pw_forums check warning:2 clients is using or hasn't closed the table properly
phpwind.pw_forums check status:OK
phpwind.pw_forums optimize status:Table is already up to date
phpwind.pw_favors check status:OK
phpwind.pw_favors optimize status:Table is already up to date
phpwind.pw_banuser check status:OK
phpwind.pw_banuser optimize status:Table is already up to date
phpwind.pw_membercredit check status:OK
phpwind.pw_membercredit optimize status:Table is already up to date
phpwind.pw_memberinfo check warning:1 clients is using or hasn't closed the table properly
phpwind.pw_memberinfo check status:OK
phpwind.pw_memberinfo optimize status:Table is already up to date
phpwind.pw_polls check status:OK
phpwind.pw_polls optimize status:Table is already up to date
phpwind.pw_attachs check status:OK
phpwind.pw_attachs optimize status:Table is already up to date
phpwind.pw_msg check warning:2 clients is using or hasn't closed the table properly
phpwind.pw_msg check status:OK
phpwind.pw_msg optimize status:OK
phpwind.pw_threads check warning:1 clients is using or hasn't closed the table properly
phpwind.pw_threads check status:OK
phpwind.pw_threads optimize status:Table is already up to date
phpwind.pw_tmsgs check warning:1 clients is using or hasn't closed the table properly
phpwind.pw_tmsgs check status:OK
phpwind.pw_tmsgs optimize status:Table is already up to date
phpwind.pw_members check warning:2 clients is using or hasn't closed the table properly
phpwind.pw_members check status:OK
phpwind.pw_members optimize status:OK
phpwind.pw_posts check status:OK
phpwind.pw_posts optimize status:OK
但是我看不懂這些,請問是否哪裡出問題了??
資料庫優化信息
資料庫表 操作 信息
哈,你用這套,問題很多,非常不穩定,之前在別地方也有人某明奇妙連不上資料庫,我也是叫它換Discuz不然就phpbb2
我只能說和你的架站機有關係,去換Discuz不然就phpbb2
另外去買台 UPS,之前我電腦也是跳電,靠造成主機版短路除了記憶體和CPU沒燒掉外,其它全換了花了1萬5
最後問了UPS不到2000元,真是因小失大
