請教各位大大,
小弟第一次裝phpbbs2,論壇現屬測試階段,若用若用簡體發表主體,主題變亂碼,還有用簡體註冊帳號,帳號出來也是亂碼。但是文章內容和版面卻都可以用簡體,請問該如何處理,在竹貓的測試版試過,發現在竹貓是正常。
http://phpbb-tw.net/phpbb/viewtopic.php?t=30172
●架設主機作業系統:Linux(RedHat)
●您的上網方式:CABLE (http://www.lsc.net.tw)。
●您安裝的程式:Apache + php + MySql
●phpBB2 版本:phpBB (2.0.11 正体中文)。
●domain(網域名稱) :www.posart.com
●phpBB2 連結網址: http://www.potsart.com/forum/
[問題]若用簡體發表主體,主題變亂碼
[Windows]
樓上打錯了,是phpbb2,抱歉。
試過下面的方式,但是還是沒有成功
試過下面的方式,但是還是沒有成功
## MOD Title: Multi-Language Fix
## MOD Author: Scorpion <formosa@ms20.url.com.tw> http://ibf.myweb.hinet.net/
## Update to 2.0.10: WeiChou
## Conflation: William Leung <admin@ke5475.net> http://ke5475.net
## MOD Description: Fix the display problems on multi-language
## MOD Version: 2.0.10
## Installation Level: Easy
## Installation Time: 10 Minutes
## Files To Edit: 7
## login.php
## posting.php
## includes/functions.php
## includes/functions_post.php
## includes/usercp_register.php
## includes/bbcode.php
## admin/admin_users.php
login.php
$username = isset($HTTP_POST_VARS['username']) ? trim(htmlspecialchars($HTTP_POST_VARS['username'])) : '';
#-----[ REPLACE WITH ]----------------------------------
$username = isset($HTTP_POST_VARS['username']) ? str_replace("&","&",trim(htmlspecialchars($HTTP_POST_VARS['username']))) : '';
posting.php
$poll_options = array();
if ( !empty($HTTP_POST_VARS['poll_option_text']) )
#-----[ BEFORE, ADD ]-----------------------------------
$subject = ereg_replace("&","&",$subject);
$message = ereg_replace("&","&",$message);
$poll_title = ereg_replace("&","&",$poll_title);
$poll_options[$option_id] = htmlspecialchars(trim(stripslashes($option_text)));
$poll_options[$option_id] = ereg_replace("&","&",htmlspecialchars(trim(stripslashes($option_text))));
$poll_options[] = htmlspecialchars(trim(stripslashes($HTTP_POST_VARS['add_poll_option_text'])));
$poll_options[] = ereg_replace("&","&",htmlspecialchars(trim(stripslashes($HTTP_POST_VARS['add_poll_option_text']))));
$user = trim(htmlspecialchars($user));
$user = str_replace("&","&",trim(htmlspecialchars($user)));
請問2.0.13的版本適用這個多國語言修正嗎?
http://phpbb-tw.net/phpbb/viewtopic.php?t=7987
