[問題]登入後才能觀看該網頁
死狐狸
文章: 144
註冊時間: 2004-05-12 17:34
來自: 江狐....
[問題]登入後才能觀看該網頁
文章 死狐狸 »
請問如在在將首頁上的A連結必須要先登入後才能看到內容~~(就算是直接打網址也是要先登入),剛剛搜尋了一下好像沒什麼答案,所以參考了一下個人資料的連結,依我的猜想,應該是紅色的這段吧(現在正開始起步學PHP~)
<?php
 *                                profile.php
 *   $Id: profile.php,v 1.193.2.3 2003/03/02 23:16:17 acydburn Exp $
define('IN_PHPBB', true);
if ( (isset($HTTP_GET_VARS['mode']) && ($HTTP_GET_VARS['mode'] == 'viewprofile')) || (isset($HTTP_POST_VARS['mode']) && ($HTTP_POST_VARS['mode'] == 'viewprofile')) )
	define('IN_CASHMOD', true);
	define('CM_VIEWPROFILE',true);
$phpbb_root_path = './';
// Start session management
$userdata = session_pagestart($user_ip, PAGE_PROFILE);
init_userprefs($userdata);
// End session management
// session id check
if (!empty($HTTP_POST_VARS['sid']) || !empty($HTTP_GET_VARS['sid']))
	$sid = (!empty($HTTP_POST_VARS['sid'])) ? $HTTP_POST_VARS['sid'] : $HTTP_GET_VARS['sid'];
	$sid = '';
// Set default email variables
$script_name = preg_replace('/^\/?(.*?)\/?$/', '\1', trim($board_config['script_path']));
$script_name = ( $script_name != '' ) ? $script_name . '/profile.'.$phpEx : 'profile.'.$phpEx;
$server_name = trim($board_config['server_name']);
$server_protocol = ( $board_config['cookie_secure'] ) ? 'https://' : 'http://';
$server_port = ( $board_config['server_port'] <> 80 ) ? ':' . trim($board_config['server_port']) . '/' : '/';
$server_url = $server_protocol . $server_name . $server_port . $script_name;
// Page specific functions
function gen_rand_string($hash)
	$chars = array( 'a', 'A', 'b', 'B', 'c', 'C', 'd', 'D', 'e', 'E', 'f', 'F', 'g', 'G', 'h', 'H', 'i', 'I', 'j', 'J',  'k', 'K', 'l', 'L', 'm', 'M', 'n', 'N', 'o', 'O', 'p', 'P', 'q', 'Q', 'r', 'R', 's', 'S', 't', 'T',  'u', 'U', 'v', 'V', 'w', 'W', 'x', 'X', 'y', 'Y', 'z', 'Z', '1', '2', '3', '4', '5', '6', '7', '8', '9', '0');
	$max_chars = count($chars) - 1;
	srand( (double) microtime()*1000000);
	$rand_str = '';
	for($i = 0; $i < 8; $i++)
		$rand_str = ( $i == 0 ) ? $chars[rand(0, $max_chars)] : $rand_str . $chars[rand(0, $max_chars)];
	return ( $hash ) ? md5($rand_str) : $rand_str;
// End page specific functions
// Start of program proper
[color=red]if ( isset($HTTP_GET_VARS['mode']) || isset($HTTP_POST_VARS['mode']) )
	$mode = ( isset($HTTP_GET_VARS['mode']) ) ? $HTTP_GET_VARS['mode'] : $HTTP_POST_VARS['mode'];
	if ( $mode == 'viewprofile' )
		     if ( !$userdata['session_logged_in'] && $mode == 'viewprofile' )
         redirect(append_sid("login.$phpEx?redirect=profile.$phpEx&mode=viewprofile", true));
      } [/color]
		include($phpbb_root_path . 'includes/usercp_viewprofile.'.$phpEx);
		exit;
	else if ( $mode == 'editprofile' || $mode == 'register' )
		if ( !$userdata['session_logged_in'] && $mode == 'editprofile' )
			redirect(append_sid("login.$phpEx?redirect=profile.$phpEx&mode=editprofile", true));
		include($phpbb_root_path . 'includes/usercp_register.'.$phpEx);
		exit;
	else if ( $mode == 'sendpassword' )
		include($phpbb_root_path . 'includes/usercp_sendpasswd.'.$phpEx);
		exit;
	else if ( $mode == 'activate' )
		include($phpbb_root_path . 'includes/usercp_activate.'.$phpEx);
		exit;
	else if ( $mode == 'email' )
		include($phpbb_root_path . 'includes/usercp_email.'.$phpEx);
		exit;
redirect(append_sid("index.$phpEx", true));
希望大大能指導小第一下 :-D
感激不盡!!
●架設主機作業系統:Xp Pro
●快速架站程式:Appserv2.4.4a
●我的網站 : 1. http://foxbbs.24cc.com 2.建造中\r
●免費空間連結: http://members.lycos.co.uk/
●您的 phpBB2 版本:1. 2.08 2. 2.0.17
您在使用電腦上有任何問題嗎?歡迎來江狐論壇跟大家一起解決喔!!
P.S 直接叫我"死狐狸"沒關係啦!! :mrgreen:
死狐狸
文章: 144
來自: 江狐....
文章 死狐狸 »
補充一下~上面說的A網頁就是此頁,請問要如何修改呢??
[php]<?php
<?php
* usercp_show_agreement.php
* $Id: usercp_register.php,v 1.20 2002/04/03 23:24:59 psotfx Exp $
global $template, $lang, $phpbb_root_path, $phpEx;
include($phpbb_root_path . 'virinfocenter.'.$phpEx);
'body' => 'virinfocenter_demo.tpl')
$template->assign_vars(array(
'SITE_ABOUT_TITLE' => '江狐病毒資訊中心')
$error = FALSE;
$page_title = "江狐病毒資訊中心";
$template->pparse('body');
?>[/php]
●架設主機作業系統:Xp Pro
死狐狸
文章: 144
來自: 江狐....
文章 死狐狸 »
剛剛在上面那個檔案中加入這段截自profile.php的語法(其中紅色的部份不知要如何更改),不過卻發生錯誤,希望大大們能只到小弟正確滴方法
if ( isset($HTTP_GET_VARS['mode']) || isset($HTTP_POST_VARS['[color=red]mode[/color]']) )
	$mode = ( isset($HTTP_GET_VARS['[color=red]mode[/color]']) ) ? $HTTP_GET_VARS['[color=red]mode[/color]'] : $HTTP_POST_VARS['[color=red]mode[/color]'];
	if ( $mode == '[color=red]viewprofile[/color]' )
		     if ( !$userdata['session_logged_in'] && $mode == '[color=red]viewprofile[/color]' )
         redirect(append_sid("login.$phpEx?redirect=[color=red]profile.$phpEx&mode=viewprofile[/color]", true));
●架設主機作業系統:Xp Pro
死狐狸
文章: 144
來自: 江狐....
文章 死狐狸 »
剛剛參考這篇,終於茲幾幫自己解決問題囉!!
●架設主機作業系統:Xp Pro
神川小羽
調皮の小羽
調皮の小羽
文章: 1461
註冊時間: 2004-05-01 05:55
來自: 謎樣之筱語
文章 神川小羽 »
我是這樣子寫耶...
[php]
if ($userdata['user_id']==ANONYMOUS)
header("Location:login.".$phpEx);
[/php]
