[問題]登入不到??
garyng818
文章: 6
註冊時間: 2004-09-08 17:11
[問題]登入不到??
文章 由 garyng818 »
主機: window xp
程式: phpbb2.0.10+ apache + php + mysql.
web: http://subaru.myvnc.com
mod installed: cash_mod2.2.1, gender_mod
problem:
當我在phpbb 裡的config set domain 是 localhost, 運作正常, 但當domain 是 http://subaru.myvnc.com 時, 當login或是logout時就會出現"page not found" 不知道是那裡出了問題呢? 因為當"page not found"出現時, 只要張網址"http://subar.myvnc.com/phpBB2/login.php" 改為"http://subaru.myvnc.com/phpBB2/index.php", 那就會去到 index.php 和會登入了.........不知道是那裡出了問題呢?
login code:
<?php
 *                                login.php
 *   email                : support@phpbb.com\r
 *   $Id: login.php,v 1.47.2.16 2004/07/17 13:48:32 acydburn Exp $
// Allow people to reach login page if
// board is shut down
define("IN_LOGIN", true);
define('IN_PHPBB', true);
$phpbb_root_path = './';
// Set page ID for session management
$userdata = session_pagestart($user_ip, PAGE_LOGIN);
init_userprefs($userdata);
// End session management
// session id check
if (!empty($HTTP_POST_VARS['sid']) || !empty($HTTP_GET_VARS['sid']))
	$sid = (!empty($HTTP_POST_VARS['sid'])) ? $HTTP_POST_VARS['sid'] : $HTTP_GET_VARS['sid'];
	$sid = '';
if( isset($HTTP_POST_VARS['login']) || isset($HTTP_GET_VARS['login']) || isset($HTTP_POST_VARS['logout']) || isset($HTTP_GET_VARS['logout']) )
	if( ( isset($HTTP_POST_VARS['login']) || isset($HTTP_GET_VARS['login']) ) && !$userdata['session_logged_in'] )
		$username = isset($HTTP_POST_VARS['username']) ? trim(htmlspecialchars($HTTP_POST_VARS['username'])) : '';
		$username = substr(str_replace("\\\'", "'", $username), 0, 25);
		$username = str_replace("'", "\\\'", $username);
		$password = isset($HTTP_POST_VARS['password']) ? $HTTP_POST_VARS['password'] : '';
		$sql = "SELECT user_id, username, user_password, user_active, user_level
			FROM " . USERS_TABLE . "
			WHERE username = '" . str_replace("\\\'", "''", $username) . "'";
			message_die(GENERAL_ERROR, 'Error in obtaining userdata', '', __LINE__, __FILE__, $sql);
		if( $row = $db->sql_fetchrow($result) )
			if( $row['user_level'] != ADMIN && $board_config['board_disable'] )
				redirect(append_sid("index.$phpEx", true));
				if( md5($password) == $row['user_password'] && $row['user_active'] )
					$autologin = ( isset($HTTP_POST_VARS['autologin']) ) ? TRUE : 0;
					$session_id = session_begin($row['user_id'], $user_ip, PAGE_INDEX, FALSE, $autologin);
					if( $session_id )
						$url = ( !empty($HTTP_POST_VARS['redirect']) ) ? str_replace('&', '&', htmlspecialchars($HTTP_POST_VARS['redirect'])) : "index.$phpEx";
						redirect(append_sid($url, true));
						message_die(CRITICAL_ERROR, "Couldn't start session : login", "", __LINE__, __FILE__);
					$redirect = ( !empty($HTTP_POST_VARS['redirect']) ) ? str_replace('&', '&', htmlspecialchars($HTTP_POST_VARS['redirect'])) : '';
					$redirect = str_replace('?', '&', $redirect);
					if (strstr(urldecode($redirect), "
") || strstr(urldecode($redirect), "
						message_die(GENERAL_ERROR, 'Tried to redirect to potentially insecure url.');
					$template->assign_vars(array(
						'META' => "<meta http-equiv=\"refresh\" content=\"3;url=login.$phpEx?redirect=$redirect\">")
					$message = $lang['Error_login'] . '<br /><br />' . sprintf($lang['Click_return_login'], "<a href=\"login.$phpEx?redirect=$redirect\">", '</a>') . '<br /><br />' .  sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a>');
			$redirect = ( !empty($HTTP_POST_VARS['redirect']) ) ? str_replace('&', '&', htmlspecialchars($HTTP_POST_VARS['redirect'])) : "";
			$redirect = str_replace("?", "&", $redirect);
	else if( ( isset($HTTP_GET_VARS['logout']) || isset($HTTP_POST_VARS['logout']) ) && $userdata['session_logged_in'] )
			session_end($userdata['session_id'], $userdata['user_id']);
		if (!empty($HTTP_POST_VARS['redirect']) || !empty($HTTP_GET_VARS['redirect']))
			$url = (!empty($HTTP_POST_VARS['redirect'])) ? htmlspecialchars($HTTP_POST_VARS['redirect']) : htmlspecialchars($HTTP_GET_VARS['redirect']);
			$url = str_replace('&', '&', $url);
		}\r
	// Do a full login page dohickey if
	// user not already logged in
	if( !$userdata['session_logged_in'] )
		$page_title = $lang['Login'];
			'body' => 'login_body.tpl')
		if( isset($HTTP_POST_VARS['redirect']) || isset($HTTP_GET_VARS['redirect']) )
			$forward_to = $HTTP_SERVER_VARS['QUERY_STRING'];
			if( preg_match("/^redirect=([a-z0-9\.#\/\?&=\+\-_]+)/si", $forward_to, $forward_matches) )
				$forward_to = ( !empty($forward_matches[3]) ) ? $forward_matches[3] : $forward_matches[1];
				$forward_match = explode('&', $forward_to);
				if(count($forward_match) > 1)
					$forward_page = '';
					for($i = 1; $i < count($forward_match); $i++)
						if( !ereg("sid=", $forward_match[$i]) )
							if( $forward_page != '' )
								$forward_page .= '&';
							$forward_page .= $forward_match[$i];
					$forward_page = $forward_match[0] . '?' . $forward_page;
					$forward_page = $forward_match[0];
			$forward_page = '';
		$username = ( $userdata['user_id'] != ANONYMOUS ) ? $userdata['username'] : '';
		$s_hidden_fields = '<input type="hidden" name="redirect" value="' . $forward_page . '" />';
		make_jumpbox('viewforum.'.$phpEx, $forum_id);
			'USERNAME' => $username,
			'L_ENTER_PASSWORD' => $lang['Enter_password'],
			'L_SEND_PASSWORD' => $lang['Forgotten_password'],
			'U_SEND_PASSWORD' => append_sid("profile.$phpEx?mode=sendpassword"),
			'S_HIDDEN_FIELDS' => $s_hidden_fields)
		$template->pparse('body');
haw
文章: 65
註冊時間: 2004-03-02 21:14
文章 由 haw »
你忘記進去後台設定你的domain name囉!
請進入後台\r
點選基本組態
第一跟第二個選項就是了
garyng818
文章: 6
文章 由 garyng818 »
我已經設定了domain name.. 但結果是一樣.......
haw
文章: 65
文章 由 haw »
你可以把你實際情形跟後台設定都po出來給大家看一下嗎?
這樣或許會比較清楚一點
hotsend
文章: 39
註冊時間: 2004-08-15 11:45
來自: 高雄
文章 由 hotsend »
你的domain name可能設錯囉~~
簡訊其實可以有很多用法!!
http://hotsend.us 熱線傳訊網
商務簡訊幫您成就您的事業!!
●架設主機作業系統:Linux版本不知
●您的上網方式:GIGA ADSL
●您的 phpBB2 版本:phpBB2010
●您的 domain(網域名稱) :post-in.net
●您的 phpBB2 連結網址: http://post-in.net
