[問題已解決]會員無法註冊的怪問題(爬文沒相關的問題)
阿瑞Arick
文章: 5
註冊時間: 2004-08-20 13:32
文章 阿瑞Arick »
●架設主機作業系統:Linux
●您安裝的程式:Apache + php + MySql
●您的 phpBB2 版本:phpBB 2.0.10
●您的 domain(網域名稱) :99oo.com
●您的 phpBB2 連結網址: http://99oo.com/phpbb2/
我的問題是這樣的,請各位 [按我] 連結。
在此先說明哦^^|| 我之前都可以註冊!!
目前只是在測試階段,所以我都安上MOD
可能是因為MOD的關係所以使這個功能消失了
註:我非使用藍大的sp而是套用他的style
而吉川大大提醒我應該是 includes\usercp_register.php 還有 templates\subSilver\agreement.tpl 之間的問題,因為他在忙所以我不想麻煩他囉 :-? 。那我把這兩個檔案PO上來
檔案:includes\usercp_register.php
<?php
if ( !defined('IN_PHPBB') )
	die("Hacking attempt");
	exit;
$unhtml_specialchars_match = array('#>#', '#<#', '#"#', '#&#');
$unhtml_specialchars_replace = array('>', '<', '"', '&');
// Load agreement template since user has not yet
// agreed to registration conditions/coppa
function show_coppa()
	global $userdata, $template, $lang, $phpbb_root_path, $phpEx;
		'body' => 'agreement.tpl')
	$template->assign_vars(array(
		'REGISTRATION' => $lang['Registration'],
		'AGREEMENT' => $lang['Reg_agreement'],
		"AGREE_OVER_13" => $lang['Agree_over_13'],
		"AGREE_UNDER_13" => $lang['Agree_under_13'],
		'DO_NOT_AGREE' => $lang['Agree_not'],
		"U_AGREE_OVER13" => append_sid("profile.$phpEx?mode=register&agreed=true"),
		"U_AGREE_UNDER13" => append_sid("profile.$phpEx?mode=register&agreed=true&coppa=true"))
	$template->pparse('body');
$error = FALSE;
$page_title = ( $mode == 'editprofile' ) ? $lang['Edit_profile'] : $lang['Register'];
if ( $mode == 'register' && !isset($HTTP_POST_VARS['agreed']) && !isset($HTTP_GET_VARS['agreed']) )
	show_coppa();
$coppa = ( empty($HTTP_POST_VARS['coppa']) && empty($HTTP_GET_VARS['coppa']) ) ? 0 : TRUE;\r
// Check and initialize some variables if needed
if (
	isset($HTTP_POST_VARS['submit']) ||
	isset($HTTP_POST_VARS['avatargallery']) ||
	isset($HTTP_POST_VARS['submitavatar']) ||
	isset($HTTP_POST_VARS['cancelavatar']) ||
	$mode == 'register' )
	include($phpbb_root_path . 'includes/functions_validate.'.$phpEx);
	include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
	include($phpbb_root_path . 'includes/functions_post.'.$phpEx);
	if ( $mode == 'editprofile' )
		$user_id = intval($HTTP_POST_VARS['user_id']);
		$current_email = trim(htmlspecialchars($HTTP_POST_VARS['current_email']));
	$strip_var_list = array('username' => 'username', 'email' => 'email', 'icq' => 'icq', 'aim' => 'aim', 'msn' => 'msn', 'yim' => 'yim', 'website' => 'website', 'location' => 'location', 'occupation' => 'occupation', 'interests' => 'interests');
	// Strip all tags from data ... may p**s some people off, bah, strip_tags is
	// doing the job but can still break HTML output ... have no choice, have
	// to use htmlspecialchars ... be prepared to be moaned at.
	while( list($var, $param) = @each($strip_var_list) )
		if ( !empty($HTTP_POST_VARS[$param]) )
			$$var = trim(htmlspecialchars($HTTP_POST_VARS[$param]));
	$trim_var_list = array('cur_password' => 'cur_password', 'new_password' => 'new_password', 'password_confirm' => 'password_confirm', 'signature' => 'signature');
	while( list($var, $param) = @each($trim_var_list) )
			$$var = trim($HTTP_POST_VARS[$param]);
	$signature = str_replace('<br />', "
", $signature);
	// Start add - Gender MOD
	$gender = ( isset($HTTP_POST_VARS['gender']) ) ? intval ($HTTP_POST_VARS['gender']) : 0;
	// End add - Gender MOD
	// Run some validation on the optional fields. These are pass-by-ref, so they'll be changed to
	// empty strings if they fail.
	validate_optional_fields($icq, $aim, $msn, $yim, $website, $location, $occupation, $interests, $signature);
	$viewemail = ( isset($HTTP_POST_VARS['viewemail']) ) ? ( ($HTTP_POST_VARS['viewemail']) ? TRUE : 0 ) : 0;
	$allowviewonline = ( isset($HTTP_POST_VARS['hideonline']) ) ? ( ($HTTP_POST_VARS['hideonline']) ? 0 : TRUE ) : TRUE;
	$notifyreply = ( isset($HTTP_POST_VARS['notifyreply']) ) ? ( ($HTTP_POST_VARS['notifyreply']) ? TRUE : 0 ) : 0;
	$notifypm = ( isset($HTTP_POST_VARS['notifypm']) ) ? ( ($HTTP_POST_VARS['notifypm']) ? TRUE : 0 ) : TRUE;
	$popup_pm = ( isset($HTTP_POST_VARS['popup_pm']) ) ? ( ($HTTP_POST_VARS['popup_pm']) ? TRUE : 0 ) : TRUE;
	if ( $mode == 'register' )
		$attachsig = ( isset($HTTP_POST_VARS['attachsig']) ) ? ( ($HTTP_POST_VARS['attachsig']) ? TRUE : 0 ) : $board_config['allow_sig'];
		$allowhtml = ( isset($HTTP_POST_VARS['allowhtml']) ) ? ( ($HTTP_POST_VARS['allowhtml']) ? TRUE : 0 ) : $board_config['allow_html'];
		$allowbbcode = ( isset($HTTP_POST_VARS['allowbbcode']) ) ? ( ($HTTP_POST_VARS['allowbbcode']) ? TRUE : 0 ) : $board_config['allow_bbcode'];
		$allowsmilies = ( isset($HTTP_POST_VARS['allowsmilies']) ) ? ( ($HTTP_POST_VARS['allowsmilies']) ? TRUE : 0 ) : $board_config['allow_smilies'];
		$attachsig = ( isset($HTTP_POST_VARS['attachsig']) ) ? ( ($HTTP_POST_VARS['attachsig']) ? TRUE : 0 ) : 0;
		$allowhtml = ( isset($HTTP_POST_VARS['allowhtml']) ) ? ( ($HTTP_POST_VARS['allowhtml']) ? TRUE : 0 ) : $userdata['user_allowhtml'];
		$allowbbcode = ( isset($HTTP_POST_VARS['allowbbcode']) ) ? ( ($HTTP_POST_VARS['allowbbcode']) ? TRUE : 0 ) : $userdata['user_allowbbcode'];
		$allowsmilies = ( isset($HTTP_POST_VARS['allowsmilies']) ) ? ( ($HTTP_POST_VARS['allowsmilies']) ? TRUE : 0 ) : $userdata['user_allowsmile'];
	$user_style = ( isset($HTTP_POST_VARS['style']) ) ? intval($HTTP_POST_VARS['style']) : $board_config['default_style'];
	if ( !empty($HTTP_POST_VARS['language']) )
		if ( preg_match('/^[a-z_]+$/i', $HTTP_POST_VARS['language']) )
			$user_lang = htmlspecialchars($HTTP_POST_VARS['language']);
			$error = true;
			$error_msg = $lang['Fields_empty'];
		$user_lang = $board_config['default_lang'];
	$user_timezone = ( isset($HTTP_POST_VARS['timezone']) ) ? doubleval($HTTP_POST_VARS['timezone']) : $board_config['board_timezone'];
	$sql = "SELECT config_value
		FROM " . CONFIG_TABLE . "
		WHERE config_name = 'default_dateformat'";
		message_die(GENERAL_ERROR, 'Could not select default dateformat', '', __LINE__, __FILE__, $sql);
	$board_config['default_dateformat'] = $row['config_value'];
	$user_dateformat = ( !empty($HTTP_POST_VARS['dateformat']) ) ? trim(htmlspecialchars($HTTP_POST_VARS['dateformat'])) : $board_config['default_dateformat'];
	$user_avatar_local = ( isset($HTTP_POST_VARS['avatarselect']) && !empty($HTTP_POST_VARS['submitavatar']) && $board_config['allow_avatar_local'] ) ? htmlspecialchars($HTTP_POST_VARS['avatarselect']) : ( ( isset($HTTP_POST_VARS['avatarlocal'])  ) ? htmlspecialchars($HTTP_POST_VARS['avatarlocal']) : '' );
	$user_avatar_remoteurl = ( !empty($HTTP_POST_VARS['avatarremoteurl']) ) ? trim(htmlspecialchars($HTTP_POST_VARS['avatarremoteurl'])) : '';
	$user_avatar_upload = ( !empty($HTTP_POST_VARS['avatarurl']) ) ? trim($HTTP_POST_VARS['avatarurl']) : ( ( $HTTP_POST_FILES['avatar']['tmp_name'] != "none") ? $HTTP_POST_FILES['avatar']['tmp_name'] : '' );
	$user_avatar_name = ( !empty($HTTP_POST_FILES['avatar']['name']) ) ? $HTTP_POST_FILES['avatar']['name'] : '';
	$user_avatar_size = ( !empty($HTTP_POST_FILES['avatar']['size']) ) ? $HTTP_POST_FILES['avatar']['size'] : 0;
	$user_avatar_filetype = ( !empty($HTTP_POST_FILES['avatar']['type']) ) ? $HTTP_POST_FILES['avatar']['type'] : '';
	$user_avatar = ( empty($user_avatar_loc) && $mode == 'editprofile' ) ? $userdata['user_avatar'] : '';
	$user_avatar_type = ( empty($user_avatar_loc) && $mode == 'editprofile' ) ? $userdata['user_avatar_type'] : '';
	if ( (isset($HTTP_POST_VARS['avatargallery']) || isset($HTTP_POST_VARS['submitavatar']) || isset($HTTP_POST_VARS['cancelavatar'])) && (!isset($HTTP_POST_VARS['submit'])) )
		$username = stripslashes($username);
		$email = stripslashes($email);
		$cur_password = htmlspecialchars(stripslashes($cur_password));
		$new_password = htmlspecialchars(stripslashes($new_password));
		$password_confirm = htmlspecialchars(stripslashes($password_confirm));
		$icq = stripslashes($icq);
		$aim = stripslashes($aim);
		$msn = stripslashes($msn);
		$yim = stripslashes($yim);
		$website = stripslashes($website);
		$location = stripslashes($location);
		$occupation = stripslashes($occupation);
		$interests = stripslashes($interests);
		$signature = stripslashes($signature);
		$user_lang = stripslashes($user_lang);
		$user_dateformat = stripslashes($user_dateformat);
		if ( !isset($HTTP_POST_VARS['cancelavatar']))
			$user_avatar = $user_avatar_local;
			$user_avatar_type = USER_AVATAR_GALLERY;
// Let's make sure the user isn't logged in while registering,
// and ensure that they were trying to register a second time
// (Prevents double registrations)
if ($mode == 'register' && ($userdata['session_logged_in'] || $username == $userdata['username']))
	message_die(GENERAL_MESSAGE, $lang['Username_taken'], '', __LINE__, __FILE__);
// Did the user submit? In this case build a query to update the users profile in the DB
if ( isset($HTTP_POST_VARS['submit']) )
	include($phpbb_root_path . 'includes/usercp_avatar.'.$phpEx);
	$passwd_sql = '';
		if ( $user_id != $userdata['user_id'] )
			$error = TRUE;
			$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Wrong_Profile'];
	else if ( $mode == 'register' )
		if ( empty($username) || empty($new_password) || empty($password_confirm) || empty($email) )
			$error = TRUE;
			$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Fields_empty'];
	$passwd_sql = '';
	if ( !empty($new_password) && !empty($password_confirm) )
		if ( $new_password != $password_confirm )
			$error = TRUE;
			$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Password_mismatch'];
		else if ( strlen($new_password) > 32 )
			$error = TRUE;
			$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Password_long'];
				$sql = "SELECT user_password
					FROM " . USERS_TABLE . "
					WHERE user_id = $user_id";
					message_die(GENERAL_ERROR, 'Could not obtain user_password information', '', __LINE__, __FILE__, $sql);
				if ( $row['user_password'] != md5($cur_password) )
					$error = TRUE;
					$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Current_password_mismatch'];
			if ( !$error )
				$new_password = md5($new_password);
				$passwd_sql = "user_password = '$new_password', ";
	else if ( ( empty($new_password) && !empty($password_confirm) ) || ( !empty($new_password) && empty($password_confirm) ) )
		$error = TRUE;
	// Do a ban check on this email address
	if ( $email != $userdata['user_email'] || $mode == 'register' )
		$result = validate_email($email);
		if ( $result['error'] )
			$email = $userdata['user_email'];
			$error = TRUE;
			$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $result['error_msg'];
				$error = TRUE;
	$username_sql = '';
	if ( $board_config['allow_namechange'] || $mode == 'register' )
		if ( empty($username) )
			// Error is already triggered, since one field is empty.
			$error = TRUE;
		else if ( $username != $userdata['username'] || $mode == 'register' )
			if (strtolower($username) != strtolower($userdata['username']))
				$result = validate_username($username);
					$error = TRUE;
			if (!$error)
				$username_sql = "username = '" . str_replace("\'", "''", $username) . "', ";
	if ( $signature != '' )
		if ( strlen($signature) > $board_config['max_sig_chars'] )
			$error = TRUE;
			$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Signature_too_long'];
		if ( $signature_bbcode_uid == '' )
			$signature_bbcode_uid = ( $allowbbcode ) ? make_bbcode_uid() : '';
		$signature = prepare_message($signature, $allowhtml, $allowbbcode, $allowsmilies, $signature_bbcode_uid);
	if ( $website != '' )
		rawurlencode($website);
	$avatar_sql = '';
	if ( isset($HTTP_POST_VARS['avatardel']) && $mode == 'editprofile' )
		$avatar_sql = user_avatar_delete($userdata['user_avatar_type'], $userdata['user_avatar']);
	if ( ( !empty($user_avatar_upload) || !empty($user_avatar_name) ) && $board_config['allow_avatar_upload'] )
		if ( !empty($user_avatar_upload) )
			$avatar_mode = ( !empty($user_avatar_name) ) ? 'local' : 'remote';
			$avatar_sql = user_avatar_upload($mode, $avatar_mode, $userdata['user_avatar'], $userdata['user_avatar_type'], $error, $error_msg, $user_avatar_upload, $user_avatar_name, $user_avatar_size, $user_avatar_filetype);
		else if ( !empty($user_avatar_name) )
			$l_avatar_size = sprintf($lang['Avatar_filesize'], round($board_config['avatar_filesize'] / 1024));
			$error = true;
			$error_msg .= ( ( !empty($error_msg) ) ? '<br />' : '' ) . $l_avatar_size;
	else if ( $user_avatar_remoteurl != '' && $board_config['allow_avatar_remote'] )
		if ( @file_exists(@phpbb_realpath('./' . $board_config['avatar_path'] . '/' . $userdata['user_avatar'])) )
			@unlink(@phpbb_realpath('./' . $board_config['avatar_path'] . '/' . $userdata['user_avatar']));
		$avatar_sql = user_avatar_url($mode, $error, $error_msg, $user_avatar_remoteurl);
	else if ( $user_avatar_local != '' && $board_config['allow_avatar_local'] )
		$avatar_sql = user_avatar_gallery($mode, $error, $error_msg, $user_avatar_local);
	if ( !$error )
		if ( $avatar_sql == '' )
			$avatar_sql = ( $mode == 'editprofile' ) ? '' : "'', " . USER_AVATAR_NONE;
			if ( $email != $userdata['user_email'] && $board_config['require_activation'] != USER_ACTIVATION_NONE && $userdata['user_level'] != ADMIN )
				$user_active = 0;
				$user_actkey = gen_rand_string(true);
				$key_len = 54 - ( strlen($server_url) );
				$key_len = ( $key_len > 6 ) ? $key_len : 6;
				$user_actkey = substr($user_actkey, 0, $key_len);
					session_end($userdata['session_id'], $userdata['user_id']);
				$user_active = 1;
				$user_actkey = '';
				SET " . $username_sql . $passwd_sql . "user_email = '" . str_replace("\'", "''", $email) ."', user_icq = '" . str_replace("\'", "''", $icq) . "', user_website = '" . str_replace("\'", "''", $website) . "', user_occ = '" . str_replace("\'", "''", $occupation) . "', user_from = '" . str_replace("\'", "''", $location) . "', user_interests = '" . str_replace("\'", "''", $interests) . "', user_sig = '" . str_replace("\'", "''", $signature) . "', user_sig_bbcode_uid = '$signature_bbcode_uid', user_viewemail = $viewemail, user_aim = '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', user_yim = '" . str_replace("\'", "''", $yim) . "', user_msnm = '" . str_replace("\'", "''", $msn) . "', user_attachsig = $attachsig, user_allowsmile = $allowsmilies, user_allowhtml = $allowhtml, user_allowbbcode = $allowbbcode, user_allow_viewonline = $allowviewonline, user_notify = $notifyreply, user_notify_pm = $notifypm, user_popup_pm = $popup_pm, user_timezone = $user_timezone, user_dateformat = '" . str_replace("\'", "''", $user_dateformat) . "', user_lang = '" . str_replace("\'", "''", $user_lang) . "', user_style = $user_style, user_active = $user_active, user_actkey = '" . str_replace("\'", "''", $user_actkey) . "'" . $avatar_sql . ", user_gender = '$gender'
				message_die(GENERAL_ERROR, 'Could not update users table', '', __LINE__, __FILE__, $sql);
			if ( !$user_active )
				// The users account has been deactivated, send them an email with a new activation key
				include($phpbb_root_path . 'includes/emailer.'.$phpEx);
				$emailer = new emailer($board_config['smtp_delivery']);
				$emailer->from($board_config['board_email']);
				$emailer->replyto($board_config['board_email']);
				$emailer->use_template('user_activate', stripslashes($user_lang));
				$emailer->email_address($email);
				$emailer->set_subject($lang['Reactivate']);
				$emailer->assign_vars(array(
					'SITENAME' => $board_config['sitename'],
					'USERNAME' => preg_replace($unhtml_specialchars_match, $unhtml_specialchars_replace, substr(str_replace("\'", "'", $username), 0, 25)),
					'EMAIL_SIG' => (!empty($board_config['board_email_sig'])) ? str_replace('<br />', "
" . $board_config['board_email_sig']) : '',
					'U_ACTIVATE' => $server_url . '?mode=activate&' . POST_USERS_URL . '=' . $user_id . '&act_key=' . $user_actkey)
				$emailer->send();
				$emailer->reset();
				$message = $lang['Profile_updated_inactive'] . '<br /><br />' . sprintf($lang['Click_return_index'],  '<a href="' . append_sid("index.$phpEx") . '">', '</a>');
				$message = $lang['Profile_updated'] . '<br /><br />' . sprintf($lang['Click_return_index'],  '<a href="' . append_sid("index.$phpEx") . '">', '</a>');
				"META" => '<meta http-equiv="refresh" content="5;url=' . append_sid("index.$phpEx") . '">')
			$sql = "SELECT MAX(user_id) AS total
				FROM " . USERS_TABLE;
				message_die(GENERAL_ERROR, 'Could not obtain next user_id information', '', __LINE__, __FILE__, $sql);
			if ( !($row = $db->sql_fetchrow($result)) )
			$user_id = $row['total'] + 1;
			// Get current date
			$sql = "INSERT INTO " . USERS_TABLE . "	(user_id, username, user_regdate, user_password, user_email, user_icq, user_website, user_occ, user_from, user_interests, user_sig, user_sig_bbcode_uid, user_avatar, user_avatar_type, user_viewemail, user_aim, user_yim, user_msnm, user_attachsig, user_allowsmile, user_allowhtml, user_allowbbcode, user_allow_viewonline, user_notify, user_notify_pm, user_popup_pm, user_timezone, user_dateformat, user_lang, user_style, user_gender, user_level, user_allow_pm, user_active, user_actkey)
				VALUES ($user_id, '" . str_replace("\'", "''", $username) . "', " . time() . ", '" . str_replace("\'", "''", $new_password) . "', '" . str_replace("\'", "''", $email) . "', '" . str_replace("\'", "''", $icq) . "', '" . str_replace("\'", "''", $website) . "', '" . str_replace("\'", "''", $occupation) . "', '" . str_replace("\'", "''", $location) . "', '" . str_replace("\'", "''", $interests) . "', '" . str_replace("\'", "''", $signature) . "', '$signature_bbcode_uid', $avatar_sql, $viewemail, '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', '" . str_replace("\'", "''", $yim) . "', '" . str_replace("\'", "''", $msn) . "', $attachsig, $allowsmilies, $allowhtml, $allowbbcode, $allowviewonline, $notifyreply, $notifypm, $popup_pm, $user_timezone, '" . str_replace("\'", "''", $user_dateformat) . "', '" . str_replace("\'", "''", $user_lang) . "', $user_style, '$gender', 0, 1, ";
			if ( $board_config['require_activation'] == USER_ACTIVATION_SELF || $board_config['require_activation'] == USER_ACTIVATION_ADMIN || $coppa )
				$key_len = 54 - (strlen($server_url));
				$sql .= "0, '" . str_replace("\'", "''", $user_actkey) . "')";
				$sql .= "1, '')";
			if ( !($result = $db->sql_query($sql, BEGIN_TRANSACTION)) )
				message_die(GENERAL_ERROR, 'Could not insert data into users table', '', __LINE__, __FILE__, $sql);
			$sql = "INSERT INTO " . GROUPS_TABLE . " (group_name, group_description, group_single_user, group_moderator)
				VALUES ('', 'Personal User', 1, 0)";
				message_die(GENERAL_ERROR, 'Could not insert data into groups table', '', __LINE__, __FILE__, $sql);
			$group_id = $db->sql_nextid();
			$sql = "INSERT INTO " . USER_GROUP_TABLE . " (user_id, group_id, user_pending)
				VALUES ($user_id, $group_id, 0)";
			if( !($result = $db->sql_query($sql, END_TRANSACTION)) )
				message_die(GENERAL_ERROR, 'Could not insert data into user_group table', '', __LINE__, __FILE__, $sql);
			if ( $coppa )
				$message = $lang['COPPA'];
				$email_template = 'coppa_welcome_inactive';
			else if ( $board_config['require_activation'] == USER_ACTIVATION_SELF )
				$message = $lang['Account_inactive'];
				$email_template = 'user_welcome_inactive';
			else if ( $board_config['require_activation'] == USER_ACTIVATION_ADMIN )
				$message = $lang['Account_inactive_admin'];
				$email_template = 'admin_welcome_inactive';
				$message = $lang['Account_added'];
				$email_template = 'user_welcome';
			$emailer->use_template($email_template, stripslashes($user_lang));
			$emailer->set_subject(sprintf($lang['Welcome_subject'], $board_config['sitename']));
			if( $coppa )
					'WELCOME_MSG' => sprintf($lang['Welcome_subject'], $board_config['sitename']),
					'PASSWORD' => $password_confirm,
					'EMAIL_SIG' => str_replace('<br />', "
" . $board_config['board_email_sig']),
					'FAX_INFO' => $board_config['coppa_fax'],
					'MAIL_INFO' => $board_config['coppa_mail'],
					'EMAIL_ADDRESS' => $email,
					'ICQ' => $icq,
					'AIM' => $aim,
					'YIM' => $yim,
					'MSN' => $msn,
					'WEB_SITE' => $website,
					'FROM' => $location,
					'OCC' => $occupation,
					'INTERESTS' => $interests,
					'SITENAME' => $board_config['sitename']));
			$emailer->send();
			$emailer->reset();
				$sql = "SELECT user_email, user_lang
					WHERE user_level = " . ADMIN;
					message_die(GENERAL_ERROR, 'Could not select Administrators', '', __LINE__, __FILE__, $sql);
					$emailer->email_address(trim($row['user_email']));
					$emailer->use_template("admin_activate", $row['user_lang']);
					$emailer->set_subject($lang['New_account_subject']);
					$emailer->send();
					$emailer->reset();
				$db->sql_freeresult($result);
			$message = $message . '<br /><br />' . sprintf($lang['Click_return_index'],  '<a href="' . append_sid("index.$phpEx") . '">', '</a>');
		} // if mode == register
} // End of submit
if ( $error )
	// If an error occured we need to stripslashes on returned data
	$new_password = '';
	$password_confirm = '';
	$aim = str_replace('+', ' ', stripslashes($aim));
	$signature = ($signature_bbcode_uid != '') ? preg_replace("/:(([a-z0-9]+:)?)$signature_bbcode_uid(=|\])/si", '\\\3', $signature) : $signature;
else if ( $mode == 'editprofile' && !isset($HTTP_POST_VARS['avatargallery']) && !isset($HTTP_POST_VARS['submitavatar']) && !isset($HTTP_POST_VARS['cancelavatar']) )
	$user_id = $userdata['user_id'];
	$username = $userdata['username'];
	$new_password = '';
	$icq = $userdata['user_icq'];
	$aim = str_replace('+', ' ', $userdata['user_aim']);
	$msn = $userdata['user_msnm'];
	$yim = $userdata['user_yim'];
	$website = $userdata['user_website'];
	$location = $userdata['user_from'];
	$occupation = $userdata['user_occ'];
	$interests = $userdata['user_interests'];
	$gender=$userdata['user_gender'];
	$signature_bbcode_uid = $userdata['user_sig_bbcode_uid'];
	$signature = ($signature_bbcode_uid != '') ? preg_replace("/:(([a-z0-9]+:)?)$signature_bbcode_uid(=|\])/si", '\\\3', $userdata['user_sig']) : $userdata['user_sig'];
	$viewemail = $userdata['user_viewemail'];
	$notifypm = $userdata['user_notify_pm'];
	$popup_pm = $userdata['user_popup_pm'];
	$notifyreply = $userdata['user_notify'];
	$attachsig = $userdata['user_attachsig'];
	$allowhtml = $userdata['user_allowhtml'];
	$allowbbcode = $userdata['user_allowbbcode'];
	$allowsmilies = $userdata['user_allowsmile'];
	$allowviewonline = $userdata['user_allow_viewonline'];
	$user_avatar = ( $userdata['user_allowavatar'] ) ? $userdata['user_avatar'] : '';
	$user_avatar_type = ( $userdata['user_allowavatar'] ) ? $userdata['user_avatar_type'] : USER_AVATAR_NONE;
	$user_style = $userdata['user_style'];
	$user_lang = $userdata['user_lang'];
	$user_timezone = $userdata['user_timezone'];
	$user_dateformat = $userdata['user_dateformat'];
// Default pages
make_jumpbox('viewforum.'.$phpEx);
		$error = TRUE;
		$error_msg = $lang['Wrong_Profile'];
if( isset($HTTP_POST_VARS['avatargallery']) && !$error )
	$avatar_category = ( !empty($HTTP_POST_VARS['avatarcategory']) ) ? htmlspecialchars($HTTP_POST_VARS['avatarcategory']) : '';
		'body' => 'profile_avatar_gallery.tpl')
	$allowviewonline = !$allowviewonline;
	display_avatar_gallery($mode, $avatar_category, $user_id, $email, $current_email, $coppa, $username, $email, &$new_password, &$cur_password, $password_confirm, $icq, $aim, $msn, $yim, $website, $location, $occupation, $interests, $signature, $viewemail, $notifypm, $popup_pm, $notifyreply, $attachsig, $allowhtml, $allowbbcode, $allowsmilies, $allowviewonline, $user_style, $user_lang, $user_timezone, $user_dateformat, $userdata['session_id'], $gender);
	include($phpbb_root_path . 'includes/functions_selects.'.$phpEx);
	if ( !isset($coppa) )
		$coppa = FALSE;
	if ( !isset($user_template) )
		$selected_template = $board_config['system_template'];
	$avatar_img = '';
	if ( $user_avatar_type )
		switch( $user_avatar_type )
			case USER_AVATAR_UPLOAD:
				$avatar_img = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $user_avatar . '" alt="" />' : '';
				break;
			case USER_AVATAR_REMOTE:
				$avatar_img = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $user_avatar . '" alt="" />' : '';
				break;
			case USER_AVATAR_GALLERY:
				$avatar_img = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $user_avatar . '" alt="" />' : '';
				break;
	$s_hidden_fields = '<input type="hidden" name="mode" value="' . $mode . '" /><input type="hidden" name="agreed" value="true" /><input type="hidden" name="coppa" value="' . $coppa . '" />';
	if( $mode == 'editprofile' )
		$s_hidden_fields .= '<input type="hidden" name="user_id" value="' . $userdata['user_id'] . '" />';
		// Send the users current email address. If they change it, and account activation is turned on
		// the user account will be disabled and the user will have to reactivate their account.
		$s_hidden_fields .= '<input type="hidden" name="current_email" value="' . $userdata['user_email'] . '" />';
	if ( !empty($user_avatar_local) )
		$s_hidden_fields .= '<input type="hidden" name="avatarlocal" value="' . $user_avatar_local . '" />';
	$html_status =  ( $userdata['user_allowhtml'] && $board_config['allow_html'] ) ? $lang['HTML_is_ON'] : $lang['HTML_is_OFF'];
	$bbcode_status = ( $userdata['user_allowbbcode'] && $board_config['allow_bbcode']  ) ? $lang['BBCode_is_ON'] : $lang['BBCode_is_OFF'];
	$smilies_status = ( $userdata['user_allowsmile'] && $board_config['allow_smilies']  ) ? $lang['Smilies_are_ON'] : $lang['Smilies_are_OFF'];
	switch ($gender)
	   case 1: $gender_male_checked="checked=\"checked\"";break;
	   case 2: $gender_female_checked="checked=\"checked\"";break;
	   default:$gender_no_specify_checked="checked=\"checked\"";
	if ( $error )
			'reg_header' => 'error_body.tpl')
			'ERROR_MESSAGE' => $error_msg)
		$template->assign_var_from_handle('ERROR_BOX', 'reg_header');
		'body' => 'profile_add_body.tpl')
		$template->assign_block_vars('switch_edit_profile', array());
\r
	if ( ($mode == 'register') || ($board_config['allow_namechange']) )
		$template->assign_block_vars('switch_namechange_allowed', array());
		$template->assign_block_vars('switch_namechange_disallowed', array());
	// Let's do an overall check for settings/versions which would prevent
	// us from doing file uploads....
	$ini_val = ( phpversion() >= '4.0.0' ) ? 'ini_get' : 'get_cfg_var';
	$form_enctype = ( @$ini_val('file_uploads') == '0' || strtolower(@$ini_val('file_uploads') == 'off') || phpversion() == '4.0.4pl1' || !$board_config['allow_avatar_upload'] || ( phpversion() < '4.0.3' && @$ini_val('open_basedir') != '' ) ) ? '' : 'enctype="multipart/form-data"';
		'USERNAME' => $username,
		'CUR_PASSWORD' => $cur_password,
		'NEW_PASSWORD' => $new_password,
		'PASSWORD_CONFIRM' => $password_confirm,
		'EMAIL' => $email,
		'YIM' => $yim,
		'ICQ' => $icq,
		'MSN' => $msn,
		'AIM' => $aim,
		'OCCUPATION' => $occupation,
		'LOCATION' => $location,
		'WEBSITE' => $website,
		'SIGNATURE' => str_replace('<br />', "
", $signature),
		'LOCK_GENDER' =>($mode!='register') ? 'DISABLED':'',
		'GENDER' => $gender,
		'GENDER_NO_SPECIFY_CHECKED' => $gender_no_specify_checked,
		'GENDER_MALE_CHECKED' => $gender_male_checked,
		'GENDER_FEMALE_CHECKED' => $gender_female_checked,
		'VIEW_EMAIL_YES' => ( $viewemail ) ? 'checked="checked"' : '',
		'VIEW_EMAIL_NO' => ( !$viewemail ) ? 'checked="checked"' : '',
		'HIDE_USER_YES' => ( !$allowviewonline ) ? 'checked="checked"' : '',
		'HIDE_USER_NO' => ( $allowviewonline ) ? 'checked="checked"' : '',
		'NOTIFY_PM_YES' => ( $notifypm ) ? 'checked="checked"' : '',
		'NOTIFY_PM_NO' => ( !$notifypm ) ? 'checked="checked"' : '',
		'POPUP_PM_YES' => ( $popup_pm ) ? 'checked="checked"' : '',
		'POPUP_PM_NO' => ( !$popup_pm ) ? 'checked="checked"' : '',
		'ALWAYS_ADD_SIGNATURE_YES' => ( $attachsig ) ? 'checked="checked"' : '',
		'ALWAYS_ADD_SIGNATURE_NO' => ( !$attachsig ) ? 'checked="checked"' : '',
		'NOTIFY_REPLY_YES' => ( $notifyreply ) ? 'checked="checked"' : '',
		'NOTIFY_REPLY_NO' => ( !$notifyreply ) ? 'checked="checked"' : '',
		'ALWAYS_ALLOW_BBCODE_YES' => ( $allowbbcode ) ? 'checked="checked"' : '',
		'ALWAYS_ALLOW_BBCODE_NO' => ( !$allowbbcode ) ? 'checked="checked"' : '',
		'ALWAYS_ALLOW_HTML_YES' => ( $allowhtml ) ? 'checked="checked"' : '',
		'ALWAYS_ALLOW_HTML_NO' => ( !$allowhtml ) ? 'checked="checked"' : '',
		'ALWAYS_ALLOW_SMILIES_YES' => ( $allowsmilies ) ? 'checked="checked"' : '',
		'ALWAYS_ALLOW_SMILIES_NO' => ( !$allowsmilies ) ? 'checked="checked"' : '',
		'ALLOW_AVATAR' => $board_config['allow_avatar_upload'],
		'AVATAR' => $avatar_img,
		'AVATAR_SIZE' => $board_config['avatar_filesize'],
		'LANGUAGE_SELECT' => language_select($user_lang, 'language'),
		'STYLE_SELECT' => style_select($user_style, 'style'),
		'TIMEZONE_SELECT' => tz_select($user_timezone, 'timezone'),
		'DATE_FORMAT' => $user_dateformat,
		'HTML_STATUS' => $html_status,
		'BBCODE_STATUS' => sprintf($bbcode_status, '<a href="' . append_sid("faq.$phpEx?mode=bbcode") . '" target="_phpbbcode">', '</a>'),
		'SMILIES_STATUS' => $smilies_status,
		'L_CURRENT_PASSWORD' => $lang['Current_password'],
		'L_NEW_PASSWORD' => ( $mode == 'register' ) ? $lang['Password'] : $lang['New_password'],
		'L_CONFIRM_PASSWORD' => $lang['Confirm_password'],
		'L_CONFIRM_PASSWORD_EXPLAIN' => ( $mode == 'editprofile' ) ? $lang['Confirm_password_explain'] : '',
		'L_PASSWORD_IF_CHANGED' => ( $mode == 'editprofile' ) ? $lang['password_if_changed'] : '',
		'L_PASSWORD_CONFIRM_IF_CHANGED' => ( $mode == 'editprofile' ) ? $lang['password_confirm_if_changed'] : '',
		'L_SUBMIT' => $lang['Submit'],
		'L_RESET' => $lang['Reset'],
		'L_ICQ_NUMBER' => $lang['ICQ'],
		'L_MESSENGER' => $lang['MSNM'],
		'L_YAHOO' => $lang['YIM'],
		'L_WEBSITE' => $lang['Website'],
		'L_AIM' => $lang['AIM'],
		'L_LOCATION' => $lang['Location'],
		'L_OCCUPATION' => $lang['Occupation'],
		'L_BOARD_LANGUAGE' => $lang['Board_lang'],
		'L_BOARD_STYLE' => $lang['Board_style'],
		'L_TIMEZONE' => $lang['Timezone'],
		'L_DATE_FORMAT' => $lang['Date_format'],
		'L_DATE_FORMAT_EXPLAIN' => $lang['Date_format_explain'],
		'L_YES' => $lang['Yes'],
		'L_NO' => $lang['No'],
		'L_INTERESTS' => $lang['Interests'],
		'L_GENDER' =>$lang['Gender'],
		'L_GENDER_MALE' =>$lang['Male'],
		'L_GENDER_FEMALE' =>$lang['Female'],
		'L_GENDER_NOT_SPECIFY' =>$lang['No_gender_specify'],
		'L_ALWAYS_ALLOW_SMILIES' => $lang['Always_smile'],
		'L_ALWAYS_ALLOW_BBCODE' => $lang['Always_bbcode'],
		'L_ALWAYS_ALLOW_HTML' => $lang['Always_html'],
		'L_HIDE_USER' => $lang['Hide_user'],
		'L_ALWAYS_ADD_SIGNATURE' => $lang['Always_add_sig'],
		'L_AVATAR_PANEL' => $lang['Avatar_panel'],
		'L_AVATAR_EXPLAIN' => sprintf($lang['Avatar_explain'], $board_config['avatar_max_width'], $board_config['avatar_max_height'], (round($board_config['avatar_filesize'] / 1024))),
		'L_UPLOAD_AVATAR_FILE' => $lang['Upload_Avatar_file'],
		'L_UPLOAD_AVATAR_URL' => $lang['Upload_Avatar_URL'],
		'L_UPLOAD_AVATAR_URL_EXPLAIN' => $lang['Upload_Avatar_URL_explain'],
		'L_AVATAR_GALLERY' => $lang['Select_from_gallery'],
		'L_SHOW_GALLERY' => $lang['View_avatar_gallery'],
		'L_LINK_REMOTE_AVATAR' => $lang['Link_remote_Avatar'],
		'L_LINK_REMOTE_AVATAR_EXPLAIN' => $lang['Link_remote_Avatar_explain'],
		'L_DELETE_AVATAR' => $lang['Delete_Image'],
		'L_CURRENT_IMAGE' => $lang['Current_Image'],
		'L_SIGNATURE' => $lang['Signature'],
		'L_SIGNATURE_EXPLAIN' => sprintf($lang['Signature_explain'], $board_config['max_sig_chars']),
		'L_NOTIFY_ON_REPLY' => $lang['Always_notify'],
		'L_NOTIFY_ON_REPLY_EXPLAIN' => $lang['Always_notify_explain'],
		'L_NOTIFY_ON_PRIVMSG' => $lang['Notify_on_privmsg'],
		'L_POPUP_ON_PRIVMSG' => $lang['Popup_on_privmsg'],
		'L_POPUP_ON_PRIVMSG_EXPLAIN' => $lang['Popup_on_privmsg_explain'],
		'L_PREFERENCES' => $lang['Preferences'],
		'L_PUBLIC_VIEW_EMAIL' => $lang['Public_view_email'],
		'L_ITEMS_REQUIRED' => $lang['Items_required'],
		'L_REGISTRATION_INFO' => $lang['Registration_info'],
		'L_PROFILE_INFO' => $lang['Profile_info'],
		'L_PROFILE_INFO_NOTICE' => $lang['Profile_info_warn'],
		'L_EMAIL_ADDRESS' => $lang['Email_address'],
		'S_ALLOW_AVATAR_UPLOAD' => $board_config['allow_avatar_upload'],
		'S_ALLOW_AVATAR_LOCAL' => $board_config['allow_avatar_local'],
		'S_ALLOW_AVATAR_REMOTE' => $board_config['allow_avatar_remote'],
		'S_HIDDEN_FIELDS' => $s_hidden_fields,
		'S_FORM_ENCTYPE' => $form_enctype,
		'S_PROFILE_ACTION' => append_sid("profile.$phpEx"))
	// This is another cheat using the block_var capability
	// of the templates to 'fake' an IF...ELSE...ENDIF solution
	// it works well :)
	if ( $mode != 'register' )
		if ( $userdata['user_allowavatar'] && ( $board_config['allow_avatar_upload'] || $board_config['allow_avatar_local'] || $board_config['allow_avatar_remote'] ) )
			$template->assign_block_vars('switch_avatar_block', array() );
			if ( $board_config['allow_avatar_upload'] && file_exists(@phpbb_realpath('./' . $board_config['avatar_path'])) )
				if ( $form_enctype != '' )
					$template->assign_block_vars('switch_avatar_block.switch_avatar_local_upload', array() );
				$template->assign_block_vars('switch_avatar_block.switch_avatar_remote_upload', array() );
			if ( $board_config['allow_avatar_remote'] )
				$template->assign_block_vars('switch_avatar_block.switch_avatar_remote_link', array() );
			if ( $board_config['allow_avatar_local'] && file_exists(@phpbb_realpath('./' . $board_config['avatar_gallery_path'])) )
				$template->assign_block_vars('switch_avatar_block.switch_avatar_local_gallery', array() );
檔案:templates\subSilver\agreement.tpl
<table border="0" cellpadding="0" cellspacing="0" class="tbn">
<td class="tbnl" rowspan="3"><img src="images/spacer.gif" alt="" width="76" height="39" /></td>
<td height="17"></td>
<td class="tbnbot"><span class="nav"><a href="{U_INDEX}" class="nav">{L_INDEX}</a></span></td>
<td class="tbnr"><img src="images/spacer.gif" alt="" width="39" height="22" /></td>
</table>
<br />
<table border="0" cellpadding="0" cellspacing="0" class="tbt"><tr><td class="tbtl"><img src="images/spacer.gif" alt="" width="22" height="22" /></td><td class="tbtbot"><span class="genmed">{SITENAME} - {REGISTRATION}</span></td><td class="tbtr"><img src="images/spacer.gif" alt="" width="124" height="22" /></td></tr></table>
<table class="forumline" width="100%" cellspacing="1" cellpadding="3" border="0">
		<td class="row1" align="center"><table width="80%" cellspacing="2" cellpadding="2" border="0" align="center">
				<td><span class="genmed"><br />{AGREEMENT}<br /><br /><br /><div align="center"><a href="{U_AGREE}" class="genmed">{AGREE}</a><br /><br /><a href="{U_INDEX}" class="genmed">{DO_NOT_AGREE}</a></div><br /></span></td>
		</table></td>
</table>
<table border="0" cellpadding="0" cellspacing="0" class="tbl"><tr><td class="tbll"><img src="images/spacer.gif" alt="" width="8" height="4" /></td><td class="tblbot"><img src="images/spacer.gif" alt="" width="8" height="4" /></td><td class="tblr"><img src="images/spacer.gif" alt="" width="8" height="4" /></td></tr></table>
最後由 阿瑞Arick 於 2004-09-08 21:19 編輯,總共編輯了 1 次。
問題狂
文章: 1947
註冊時間: 2004-06-28 17:13
文章 問題狂 »
你的連結弄錯了...
怎麼變成"index.php'了呢?
阿瑞Arick
文章: 5
文章 阿瑞Arick »
不好意思麻煩你可以再講詳細一點嗎?謝謝^^||
有私人的問題請 PM 給我,要多多回文喔^^
動機不明
喝咖啡的綠皮猴
喝咖啡的綠皮猴
文章: 1179
註冊時間: 2002-03-06 20:37
來自: GOP (重啟)
文章 動機不明 »
我想問題狂的意思是,怎麼按下 [註冊] 後,只出現 (我不同意以上條文) 而已 XD (然後連結跑到 index.php 那裡去)
你好像連檢查有否 未滿13 這個功能都沒有喔...
開啟 agreement.tpl
取代為\r
<td><span class="genmed"><br />{AGREEMENT}<br /><br /><br /><div align="center">[color=red]<a href="{U_AGREE_OVER13}" class="genmed">{AGREE_OVER_13}</a><br /><br /><a href="{U_AGREE_UNDER13}" class="genmed">{AGREE_UNDER_13}</a>[/color]<br /><br /><a href="{U_INDEX}" class="genmed">{DO_NOT_AGREE}</a></div><br /></span></td>
藍天的風格應該是有自己修改過功能,所以不適合套用在 官方提供的版本 上... :roll:
問題狂
文章: 1947
文章 問題狂 »
呵呵...剛剛有點匆忙..沒有交代的很清楚...@@|||
阿瑞Arick
文章: 5
文章 阿瑞Arick »
感謝您的幫忙:D
問題已經解決了,謝謝哦^^
oklazone
文章: 5
註冊時間: 2004-10-05 21:54
文章 oklazone »
●架設主機作業系統:winxp
●您的 phpBB2 版本:phpBB 2.2.0
●您的 domain(網域名稱) :adamlv.no-ip.org
●您的 phpBB2 連結網址: http://adamlv.no-ip.org/phpbb/
這是我安裝的軟體appserv-win32-2.2.0
抱歉,我是一個新手,以前都沒碰過這些東西,對於討論區完全沒概念,因為目前有需要所以架了一個討論區,我已經有照上述的方式改了一些檔案,可是『會員註冊』的地方還是只有我不同意以以上條款之類的字樣,無法讓人註冊,可否麻煩已解決這個問題的人,再敘述詳細些,謝謝
