[問題]架站後出現的問題 已解決 謝謝大家
ambrose_1020
文章: 15
註冊時間: 2004-08-28 09:25
來自: 雞籠廟口
文章 ambrose_1020 »
Warning: mysql_connect(): Access denied for user: 'mazda3c_root@localhost' (Using password: YES) in /home/mazda3c/public_html/phpBB2/db/mysql4.php on line 48
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in /home/mazda3c/public_html/phpBB2/db/mysql4.php on line 330
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in /home/mazda3c/public_html/phpBB2/db/mysql4.php on line 331
phpBB : Critical Error
最後由 ambrose_1020 於 2004-08-31 11:58 編輯,總共編輯了 3 次。
●架設主機作業系統:RedHat Linux
●免費空間連結:http://www.mazda3-club.com/phpBB2/
●domain(網域名稱):mazda3-club.com
●上網方式:Hinet ADSL 2M/512K
●浮動IP
●安裝的程式:Apache+MySQL+PHP+Perl+PhpMyAdmin phpBB2
●版本phpBB2.10
aiken
文章: 1514
註冊時間: 2003-11-09 11:02
來自: 大頭真論壇
文章 aiken »
請修改 config.php 內關於MySQL 資料庫的帳號密碼
ambrose_1020
文章: 15
來自: 雞籠廟口
文章 ambrose_1020 »
aiken 寫:Warning: mysql_connect(): Access denied for user: 'mazda3c_root@localhost' (Using password: YES)
※我嘗試更改《config.php》中的帳號密碼卻出現以下的錯誤訊息,請問何解?
Warning: Cannot modify header information - headers already sent by (output started at /home/mazda3c/public_html/phpBB2/config.php:29) in /home/mazda3c/public_html/phpBB2/includes/sessions.php on line 188
Warning: Cannot modify header information - headers already sent by (output started at /home/mazda3c/public_html/phpBB2/config.php:29) in /home/mazda3c/public_html/phpBB2/includes/sessions.php on line 189
Warning: Cannot modify header information - headers already sent by (output started at /home/mazda3c/public_html/phpBB2/config.php:29) in /home/mazda3c/public_html/phpBB2/includes/page_header.php on line 475
Warning: Cannot modify header information - headers already sent by (output started at /home/mazda3c/public_html/phpBB2/config.php:29) in /home/mazda3c/public_html/phpBB2/includes/page_header.php on line 477
Warning: Cannot modify header information - headers already sent by (output started at /home/mazda3c/public_html/phpBB2/config.php:29) in /home/mazda3c/public_html/phpBB2/includes/page_header.php on line 478
●浮動IP
●版本phpBB2.10
messagebox
文章: 981
註冊時間: 2003-02-24 23:34
文章 messagebox »
第3篇的錯誤訊息是指
sessions.php 這檔案嘗試送出檔頭資料失敗~原因~在之前config.php已經有不是檔頭的資料送出(EX.HTML_BODY)
只要不是用\r
int header(string string);
int setcookie(string name, string value, int expire, string path, string domain, int secure);
這兩個函式送出的標準輸出都算是非檔頭~
也就是說~在標準輸出後還嘗試使用上述函式送出檔頭就會有這錯誤訊息~
sessions.php送出的檔頭幾乎是\r
解決方法~檢查config.php是否有不應該出現的標準輸出
ambrose_1020
文章: 15
來自: 雞籠廟口
文章 ambrose_1020 »
messagebox 寫:第3篇的錯誤訊息是指
只要不是用\r
這兩個函式送出的標準輸出都算是非檔頭~
謝謝 以解決!
●浮動IP
●版本phpBB2.10
webspirit
文章: 1354
註冊時間: 2004-02-16 12:01
來自: 精靈國度
文章 webspirit »
解決了只要在原標題後加註已解決就好了
你現在的標題叫後來的人誰看得懂?
ambrose_1020
文章: 15
來自: 雞籠廟口
Re: [問題]架站後出現的問題 已解決 謝謝大家
文章 ambrose_1020 »
ambrose_1020 寫:Warning: mysql_connect(): Access denied for user: 'mazda3c_root@localhost' (Using password: YES) in /home/mazda3c/public_html/phpBB2/db/mysql4.php on line 48
●浮動IP
●版本phpBB2.10
ambrose_1020
文章: 15
來自: 雞籠廟口
文章 ambrose_1020 »
ambrose_1020 寫:
不好意思,我是新人,如有冒犯,請多見諒!
●浮動IP
●版本phpBB2.10
