[問題]會員列表按下去之後就出錯了…
terry1983
文章: 14
註冊時間: 2004-06-18 01:06
[問題]會員列表按下去之後就出錯了…
文章 terry1983 »
●您的 phpBB2 版本:phpBB (2.0.8
●您的 domain(網域名稱) :http://mosuclub.com/mosubbs/
●您的 phpBB2 連結網址: http://mosuclub.com/mosubbs/
●錯誤代碼:
會員列表按下去之後就出錯了…\r
會出現下面的訊息\r
Parse error: parse error, unexpected T_VARIABLE in /backup/terry/public_html/mosubbs/memberlist.php on line 278
下面是我的程式碼\r
<?php
 *                              memberlist.php
 *   begin                : Friday, May 11, 2001
 *   $Id: memberlist.php,v 1.36.2.9 2004/03/01 15:56:52 psotfx Exp $
define('IN_PHPBB', true);
define('IN_CASHMOD', true);
define('CM_MEMBERLIST', true);
$phpbb_root_path = './';
// Start session management
$userdata = session_pagestart($user_ip, PAGE_VIEWMEMBERS);
init_userprefs($userdata);
// End session management
$start = ( isset($HTTP_GET_VARS['start']) ) ? intval($HTTP_GET_VARS['start']) : 0;
if ( isset($HTTP_GET_VARS['mode']) || isset($HTTP_POST_VARS['mode']) )
	$mode = ( isset($HTTP_POST_VARS['mode']) ) ? htmlspecialchars($HTTP_POST_VARS['mode']) : htmlspecialchars($HTTP_GET_VARS['mode']);
	$mode = 'joined';
if(isset($HTTP_POST_VARS['order']))
	$sort_order = ($HTTP_POST_VARS['order'] == 'ASC') ? 'ASC' : 'DESC';
else if(isset($HTTP_GET_VARS['order']))
	$sort_order = ($HTTP_GET_VARS['order'] == 'ASC') ? 'ASC' : 'DESC';
	$sort_order = 'ASC';
// Memberlist sorting
$mode_types_text = array($lang['Sort_Joined'], $lang['Sort_Username'], $lang['Sort_Location'], $lang['Sort_Posts'], $lang['Sort_Email'],  $lang['Sort_Website'], $lang['Sort_Top_Ten']);
$mode_types = array('joindate', 'username', 'location', 'posts', 'email', 'website', 'topten');
$cm_memberlist->droplists($mode_types_text,$mode_types);
$select_sort_mode = '<select name="mode">';
for($i = 0; $i < count($mode_types_text); $i++)
	$selected = ( $mode == $mode_types[$i] ) ? ' selected="selected"' : '';
	$select_sort_mode .= '<option value="' . $mode_types[$i] . '"' . $selected . '>' . $mode_types_text[$i] . '</option>';
$select_sort_mode .= '</select>';
$select_sort_order = '<select name="order">';
if($sort_order == 'ASC')
	$select_sort_order .= '<option value="ASC" selected="selected">' . $lang['Sort_Ascending'] . '</option><option value="DESC">' . $lang['Sort_Descending'] . '</option>';
	$select_sort_order .= '<option value="ASC">' . $lang['Sort_Ascending'] . '</option><option value="DESC" selected="selected">' . $lang['Sort_Descending'] . '</option>';
$select_sort_order .= '</select>';
// Generate page
$page_title = $lang['Memberlist'];
	'body' => 'memberlist_body.tpl')
make_jumpbox('viewforum.'.$phpEx);
$template->assign_vars(array(
	'L_SELECT_SORT_METHOD' => $lang['Select_sort_method'],
	'L_EMAIL' => $lang['Email'],
	'L_WEBSITE' => $lang['Website'],
	'L_FROM' => $lang['Location'],
	'L_ORDER' => $lang['Order'],
	'L_SORT' => $lang['Sort'],
	'L_SUBMIT' => $lang['Sort'],
	'L_AIM' => $lang['AIM'],
	'L_YIM' => $lang['YIM'],
	'L_MSNM' => $lang['MSNM'],
	'L_ICQ' => $lang['ICQ'],
	'L_JOINED' => $lang['Joined'],
	'L_POSTS' => $lang['Posts'],
	'L_PM' => $lang['Private_Message'],
	'S_MODE_SELECT' => $select_sort_mode,
	'S_ORDER_SELECT' => $select_sort_order,
	'S_MODE_ACTION' => append_sid("memberlist.$phpEx"))
switch( $mode )
	case 'joined':
		$order_by = "user_regdate $sort_order LIMIT $start, " . $board_config['topics_per_page'];
		break;
	case 'username':
		$order_by = "username $sort_order LIMIT $start, " . $board_config['topics_per_page'];
		break;
	case 'location':
		$order_by = "user_from $sort_order LIMIT $start, " . $board_config['topics_per_page'];
		break;
	case 'posts':
		$order_by = "user_posts $sort_order LIMIT $start, " . $board_config['topics_per_page'];
		break;
	case 'email':
		$order_by = "user_email $sort_order LIMIT $start, " . $board_config['topics_per_page'];
		break;
	case 'website':
		$order_by = "user_website $sort_order LIMIT $start, " . $board_config['topics_per_page'];
		break;
	case 'topten':
		$order_by = "user_posts $sort_order LIMIT 10";
		break;
		case $cm_memberlist->modecheck($mode):
		$order_by = $cm_memberlist->getfield($mode) . " $sort_order LIMIT $start, " . $board_config['topics_per_page'];
		break;
	default:
		break;
$sql = "SELECT username, user_id, user_viewemail, user_posts, user_regdate, user_from, user_website, user_email, user_icq, user_aim, user_yim, user_msnm, user_avatar, user_avatar_type, user_allowavatar
	FROM " . USERS_TABLE . "
	WHERE user_id <> " . ANONYMOUS . "
	ORDER BY $order_by";
$cm_memberlist->generate_columns($template,$sql,8);
	message_die(GENERAL_ERROR, 'Could not query users', '', __LINE__, __FILE__, $sql);
	$i = 0;
	do
		$username = $row['username'];
		$user_id = $row['user_id'];
		$from = ( !empty($row['user_from']) ) ? $row['user_from'] : ' ';
		$joined = create_date($lang['DATE_FORMAT'], $row['user_regdate'], $board_config['board_timezone']);
		$posts = ( $row['user_posts'] ) ? $row['user_posts'] : 0;
		$poster_avatar = '';
		if ( $row['user_avatar_type'] && $user_id != ANONYMOUS && $row['user_allowavatar'] )
			switch( $row['user_avatar_type'] )
				case USER_AVATAR_UPLOAD:
					$poster_avatar = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $row['user_avatar'] . '" alt="" border="0" />' : '';
					break;
				case USER_AVATAR_REMOTE:
					$poster_avatar = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $row['user_avatar'] . '" alt="" border="0" />' : '';
					break;
				case USER_AVATAR_GALLERY:
					$poster_avatar = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $row['user_avatar'] . '" alt="" border="0" />' : '';
					break;
		if ( !empty($row['user_viewemail']) || $userdata['user_level'] == ADMIN )
			$email_uri = ( $board_config['board_email_form'] ) ? append_sid("profile.$phpEx?mode=email&" . POST_USERS_URL .'=' . $user_id) : 'mailto:' . $row['user_email'];
			$email_img = '<a href="' . $email_uri . '"><img src="' . $images['icon_email'] . '" alt="' . $lang['Send_email'] . '" title="' . $lang['Send_email'] . '" border="0" /></a>';
			$email = '<a href="' . $email_uri . '">' . $lang['Send_email'] . '</a>';
			$email_img = ' ';
			$email = ' ';
		$temp_url = append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$user_id");
		$profile_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_profile'] . '" alt="' . $lang['Read_profile'] . '" title="' . $lang['Read_profile'] . '" border="0" /></a>';
		$profile = '<a href="' . $temp_url . '">' . $lang['Read_profile'] . '</a>';
		$temp_url = append_sid("privmsg.$phpEx?mode=post&" . POST_USERS_URL . "=$user_id");
		$pm_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_pm'] . '" alt="' . $lang['Send_private_message'] . '" title="' . $lang['Send_private_message'] . '" border="0" /></a>';
		$pm = '<a href="' . $temp_url . '">' . $lang['Send_private_message'] . '</a>';
		$www_img = ( $row['user_website'] ) ? '<a href="' . $row['user_website'] . '" target="_userwww"><img src="' . $images['icon_www'] . '" alt="' . $lang['Visit_website'] . '" title="' . $lang['Visit_website'] . '" border="0" /></a>' : '';
		$www = ( $row['user_website'] ) ? '<a href="' . $row['user_website'] . '" target="_userwww">' . $lang['Visit_website'] . '</a>' : '';
		if ( !empty($row['user_icq']) )
			$icq_status_img = '<a href="http://wwp.icq.com/' . $row['user_icq'] . '#pager"><img src="http://web.icq.com/whitepages/online?icq=' . $row['user_icq'] . '&img=5" width="18" height="18" border="0" /></a>';
			$icq_img = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $row['user_icq'] . '"><img src="' . $images['icon_icq'] . '" alt="' . $lang['ICQ'] . '" title="' . $lang['ICQ'] . '" border="0" /></a>';
			$icq =  '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $row['user_icq'] . '">' . $lang['ICQ'] . '</a>';
			$icq_status_img = '';
			$icq_img = '';
			$icq = '';
		$aim_img = ( $row['user_aim'] ) ? '<a href="aim:goim?screenname=' . $row['user_aim'] . '&message=Hello+Are+you+there?"><img src="' . $images['icon_aim'] . '" alt="' . $lang['AIM'] . '" title="' . $lang['AIM'] . '" border="0" /></a>' : '';
		$aim = ( $row['user_aim'] ) ? '<a href="aim:goim?screenname=' . $row['user_aim'] . '&message=Hello+Are+you+there?">' . $lang['AIM'] . '</a>' : '';
		$msn_img = ( $row['user_msnm'] ) ? '<a href="' . $temp_url . '"><img src="' . $images['icon_msnm'] . '" alt="' . $lang['MSNM'] . '" title="' . $lang['MSNM'] . '" border="0" /></a>' : '';
		$msn = ( $row['user_msnm'] ) ? '<a href="' . $temp_url . '">' . $lang['MSNM'] . '</a>' : '';
		$yim_img = ( $row['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $row['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
		$yim = ( $row['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $row['user_yim'] . '&.src=pg">' . $lang['YIM'] . '</a>' : '';
		$temp_url = append_sid("search.$phpEx?search_author=" . urlencode($username) . "&showresults=posts");
		$search_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_search'] . '" alt="' . $lang['Search_user_posts'] . '" title="' . $lang['Search_user_posts'] . '" border="0" /></a>';
		$search = '<a href="' . $temp_url . '">' . $lang['Search_user_posts'] . '</a>';
		$template->assign_block_vars('memberrow', array(
			'ROW_NUMBER' => $i + ( $HTTP_GET_VARS['start'] + 1 ),
			'ROW_CLASS' => $row_class,
			'USERNAME' => $username,
			'FROM' => $from,
			'JOINED' => $joined,
			'POSTS' => $posts,
			'AVATAR_IMG' => $poster_avatar,
			'PROFILE_IMG' => $profile_img,
			'PROFILE' => $profile,
			'SEARCH_IMG' => $search_img,
			'SEARCH' => $search,
			'PM_IMG' => $pm_img,
			'PM' => $pm,
			'EMAIL_IMG' => $email_img,
			'EMAIL' => $email,
			'WWW_IMG' => $www_img,
			'WWW' => $www,
			'ICQ_STATUS_IMG' => $icq_status_img,
			'ICQ_IMG' => $icq_img,
			'ICQ' => $icq,
			'AIM_IMG' => $aim_img,
			'AIM' => $aim,
			'MSN_IMG' => $msn_img,
			'MSN' => $msn,
			'YIM_IMG' => $yim_img,
			'YIM' => $yim,
			'U_VIEWPROFILE' => append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$user_id"))
		$cm_memberlist->listing($template,$row
		$i++;
	$db->sql_freeresult($result);
if ( $mode != 'topten' || $board_config['topics_per_page'] < 10 )
	$sql = "SELECT count(*) AS total
		WHERE user_id <> " . ANONYMOUS;
		message_die(GENERAL_ERROR, 'Error getting total users', '', __LINE__, __FILE__, $sql);
	if ( $total = $db->sql_fetchrow($result) )
		$total_members = $total['total'];
		$pagination = generate_pagination("memberlist.$phpEx?mode=$mode&order=$sort_order", $total_members, $board_config['topics_per_page'], $start). ' ';
	$pagination = ' ';
	$total_members = 10;
	'PAGINATION' => $pagination,
	'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / $board_config['topics_per_page'] ) + 1 ), ceil( $total_members / $board_config['topics_per_page'] )),
	'L_GOTO_PAGE' => $lang['Goto_page'])
$template->pparse('body');
最後由 terry1983 於 2004-06-23 13:39 編輯,總共編輯了 1 次。
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
