[問題]不能註冊會員(已解決)
天地人
文章: 30
註冊時間: 2004-04-09 07:50
來自: hk
[問題]不能註冊會員(已解決)
文章 天地人 »
●免費空間連結: http://www.members.lycos.co.uk/bolung
上網方式:adsl
●我的 phpBB2 版本:phpBB 2.08
問題是新會員不能註冊
登記會員後,按下送出按鈕時出現以下文字
Fatal error: Cannot redeclare check_image_type() (previously declared in /data/members/free/tripod/uk/b/o/l/bolung/htdocs/includes/usercp_avatar.php:24) in /data/members/free/tripod/uk/b/o/l/bolung/htdocs/includes/usercp_avatar.php on line 24
<?php
*                              template.php
*   $Id: template.php,v 1.10.2.3 2002/12/21 19:09:57 psotfx Exp $
* Template class. By Nathan Codding of the phpBB group.
* The interface was originally inspired by PHPLib templates,
* and the template file formats are quite similar.
class Template { var $classname = "Template";
   // variable that holds all the data we'll be substituting into
   // the compiled templates.
   // This will end up being a multi-dimensional array like this:
   // $this->_tpldata[block.][iteration#][child.][iteration#][child2.][iteration#][variablename] == value
   // if it's a root-level variable, it'll be like this:
   // $this->_tpldata[.][0][varname] == value
   var $_tpldata = array();
   // Hash of filenames for each template handle.
   var $files = array();
   // Root template directory.
   var $root = "";
   // this will hash handle names to the compiled code for that handle.
   var $compiled_code = array();
   // This will hold the uncompiled code for that handle.
   var $uncompiled_code = array();
    * Constructor. Simply sets the root dir.
   function Template($root = ".")
      $this->set_rootdir($root);
    * Destroys this template object. Should be called when you're done with it, in order
    * to clear out the template data so you can load/parse a new template set.
   function destroy()
      $this->_tpldata = array();
    * Sets the template root directory for this Template object.
   function set_rootdir($dir)
      if (!is_dir($dir))
         return false;
      $this->root = $dir;
      return true;
    * Sets the template filenames for handles. $filename_array
    * should be a hash of handle => filename pairs.
   function set_filenames($filename_array)
      if (!is_array($filename_array))
         return false;
      reset($filename_array);
      while(list($handle, $filename) = each($filename_array))
         $this->files[$handle] = $this->make_filename($filename);
      return true;
    * Load the file for the handle, compile the file,
    * and run the compiled code. This will print out
    * the results of executing the template.
   function pparse($handle)
      if (!$this->loadfile($handle))
         die("Template->pparse(): Couldn't load template file for handle $handle");
      // actually compile the template now.
      if (!isset($this->compiled_code[$handle]) || empty($this->compiled_code[$handle]))
         // Actually compile the code now.
         $this->compiled_code[$handle] = $this->compile($this->uncompiled_code[$handle]);
      // Run the compiled code.
      eval($this->compiled_code[$handle]);
      return true;
    * Inserts the uncompiled code for $handle as the
    * value of $varname in the root-level. This can be used
    * to effectively include a template in the middle of another
    * template.
    * Note that all desired assignments to the variables in $handle should be done
    * BEFORE calling this function.
   function assign_var_from_handle($varname, $handle)
         die("Template->assign_var_from_handle(): Couldn't load template file for handle $handle");
      // Compile it, with the "no echo statements" option on.
      $_str = "";
      $code = $this->compile($this->uncompiled_code[$handle], true, '_str');
      // evaluate the variable assignment.
      eval($code);
      // assign the value of the generated variable to the given varname.
      $this->assign_var($varname, $_str);
      return true;
    * Block-level variable assignment. Adds a new block iteration with the given
    * variable assignments. Note that this should only be called once per block
    * iteration.
   function assign_block_vars($blockname, $vararray)
      if (strstr($blockname, '.'))
         // Nested block.
         $blocks = explode('.', $blockname);
         $blockcount = sizeof($blocks) - 1;
         $str = '$this->_tpldata';
         for ($i = 0; $i < $blockcount; $i++)
            $str .= '[\'' . $blocks[$i] . '.\']';
            eval('$lastiteration = sizeof(' . $str . ') - 1;');
            $str .= '[' . $lastiteration . ']';
         // Now we add the block that we're actually assigning to.
         // We're adding a new iteration to this block with the given
         // variable assignments.
         $str .= '[\'' . $blocks[$blockcount] . '.\'][] = $vararray;';
         // Now we evaluate this assignment we've built up.
         eval($str);
         // Top-level block.
         // Add a new iteration to this block with the variable assignments
         // we were given.
         $this->_tpldata[$blockname . '.'][] = $vararray;
      return true;
    * Root-level variable assignment. Adds to current assignments, overriding
    * any existing variable assignment with the same name.
   function assign_vars($vararray)
      reset ($vararray);
      while (list($key, $val) = each($vararray))
         $this->_tpldata['.'][0][$key] = $val;
      return true;
   function assign_var($varname, $varval)
      $this->_tpldata['.'][0][$varname] = $varval;
      return true;
    * Generates a full path+filename for the given filename, which can either
    * be an absolute name, or a name relative to the rootdir for this Template
    * object.
   function make_filename($filename)
      // Check if it's an absolute or relative path.
      if (substr($filename, 0, 1) != '/')
             $filename = phpbb_realpath($this->root . '/' . $filename);
      if (!file_exists($filename))
         die("Template->make_filename(): Error - file $filename does not exist");
      return $filename;
    * If not already done, load the file for the given handle and populate
    * the uncompiled_code[] hash with its code. Do not compile.
   function loadfile($handle)
      // If the file for this handle is already loaded and compiled, do nothing.
      if (isset($this->uncompiled_code[$handle]) && !empty($this->uncompiled_code[$handle]))
         return true;
      // If we don't have a file assigned to this handle, die.
      if (!isset($this->files[$handle]))
         die("Template->loadfile(): No file specified for handle $handle");
      $filename = $this->files[$handle];
\n      $str = implode("", @file($filename));
      if (empty($str))
         die("Template->loadfile(): File $filename for handle $handle is empty");
      $this->uncompiled_code[$handle] = $str;
      return true;
    * Compiles the given string of code, and returns
    * the result in a string.
    * If "do_not_echo" is true, the returned code will not be directly
    * executable, but can be used as part of a variable assignment
    * for use in assign_code_from_handle().
   function compile($code, $do_not_echo = false, $retvar = '')
      // replace \ with \\\ and then ' with \'.
      $code = str_replace('\\\', '\\\\\\\', $code);
      $code = str_replace('\'', '\\\\\'', $code);
      // change template varrefs into PHP varrefs
      // This one will handle varrefs WITH namespaces
      $varrefs = array();
      preg_match_all('#\{(([a-z0-9\-_]+?\.)+?)([a-z0-9\-_]+?)\}#is', $code, $varrefs);
      $varcount = sizeof($varrefs[1]);
      for ($i = 0; $i < $varcount; $i++)
         $namespace = $varrefs[1][$i];
         $varname = $varrefs[3][$i];
         $new = $this->generate_block_varref($namespace, $varname);
         $code = str_replace($varrefs[0][$i], $new, $code);
      // This will handle the remaining root-level varrefs
      $code = preg_replace('#\{([a-z0-9\-_]*?)\}#is', '\' . ( ( isset($this->_tpldata[\'.\'][0][\'\1\']) ) ? $this->_tpldata[\'.\'][0][\'\1\'] : \'\' ) . \'', $code);
      // Break it up into lines.
      $code_lines = explode("
", $code);
      $block_nesting_level = 0;
      $block_names = array();
      $block_names[0] = ".";
      // Second: prepend echo ', append ' . "
"; to each line.
      $line_count = sizeof($code_lines);
      for ($i = 0; $i < $line_count; $i++)
         $code_lines[$i] = chop($code_lines[$i]);
         if (preg_match('#<!-- BEGIN (.*?) -->#', $code_lines[$i], $m))
            $n[0] = $m[0];
            $n[1] = $m[1];
            // Added: dougk_ff7-Keeps templates from bombing if begin is on the same line as end.. I think.
            if ( preg_match('#<!-- END (.*?) -->#', $code_lines[$i], $n) )
               $block_nesting_level++;
               $block_names[$block_nesting_level] = $m[1];
               if ($block_nesting_level < 2)
                  // Block is not nested.
                  $code_lines[$i] = '$_' . $n[1] . '_count = ( isset($this->_tpldata[\'' . $n[1] . '.\']) ) ?  sizeof($this->_tpldata[\'' . $n[1] . '.\']) : 0;';
                  $code_lines[$i] .= "
" . 'for ($_' . $n[1] . '_i = 0; $_' . $n[1] . '_i < $_' . $n[1] . '_count; $_' . $n[1] . '_i++)';
                  // This block is nested.
                  // Generate a namespace string for this block.
                  $namespace = implode('.', $block_names);
                  // strip leading period from root level..
                  $namespace = substr($namespace, 2);
                  // Get a reference to the data array for this block that depends on the
                  // current indices of all parent blocks.
                  $varref = $this->generate_block_data_ref($namespace, false);
                  // Create the for loop code to iterate over this block.
                  $code_lines[$i] = '$_' . $n[1] . '_count = ( isset(' . $varref . ') ) ? sizeof(' . $varref . ') : 0;';
               // We have the end of a block.
               unset($block_names[$block_nesting_level]);
               $block_nesting_level--;
               $code_lines[$i] .= '} // END ' . $n[1];
               $m[0] = $n[0];
               $m[1] = $n[1];
               // We have the start of a block.
                  $code_lines[$i] = '$_' . $m[1] . '_count = ( isset($this->_tpldata[\'' . $m[1] . '.\']) ) ? sizeof($this->_tpldata[\'' . $m[1] . '.\\']) : 0;';
" . 'for ($_' . $m[1] . '_i = 0; $_' . $m[1] . '_i < $_' . $m[1] . '_count; $_' . $m[1] . '_i++)';
                  $code_lines[$i] = '$_' . $m[1] . '_count = ( isset(' . $varref . ') ) ? sizeof(' . $varref . ') : 0;';
         else if (preg_match('#<!-- END (.*?) -->#', $code_lines[$i], $m))
            $code_lines[$i] = '} // END ' . $m[1];
            // We have an ordinary line of code.
            if (!$do_not_echo)
               $code_lines[$i] = 'echo \'' . $code_lines[$i] . '\' . "\\
               $code_lines[$i] = '$' . $retvar . '.= \'' . $code_lines[$i] . '\' . "\\
      // Bring it back into a single string of lines of code.
      $code = implode("
", $code_lines);
      return $code   ;
    * Generates a reference to the given variable inside the given (possibly nested)
    * block namespace. This is a string of the form:
    * ' . $this->_tpldata['parent'][$_parent_i]['$child1'][$_child1_i]['$child2'][$_child2_i]...['varname'] . '
    * It's ready to be inserted into an "echo" line in one of the templates.
    * NOTE: expects a trailing "." on the namespace.
   function generate_block_varref($namespace, $varname)
      // Strip the trailing period.
      $namespace = substr($namespace, 0, strlen($namespace) - 1);
      // Get a reference to the data block for this namespace.
      $varref = $this->generate_block_data_ref($namespace, true);
      // Prepend the necessary code to stick this in an echo line.
      // Append the variable reference.
      $varref .= '[\'' . $varname . '\']';
      $varref = '\' . ( ( isset(' . $varref . ') ) ? ' . $varref . ' : \'\' ) . \'';
      return $varref;
    * Generates a reference to the array of data values for the given
    * (possibly nested) block namespace. This is a string of the form:
    * $this->_tpldata['parent'][$_parent_i]['$child1'][$_child1_i]['$child2'][$_child2_i]...['$childN']
    * If $include_last_iterator is true, then [$_childN_i] will be appended to the form shown above.
    * NOTE: does not expect a trailing "." on the blockname.
   function generate_block_data_ref($blockname, $include_last_iterator)
      // Get an array of the blocks involved.
      $blocks = explode(".", $blockname);
      $varref = '$this->_tpldata';
      // Build up the string with everything but the last child.
         $varref .= '[\'' . $blocks[$i] . '.\'][$_' . $blocks[$i] . '_i]';
      // Add the block reference for the last child.
      $varref .= '[\'' . $blocks[$blockcount] . '.\']';
      // Add the iterator for the last child if requried.
      if ($include_last_iterator)
         $varref .= '[$_' . $blocks[$blockcount] . '_i]';
      return $varref;
各位前輩可否告知在下是那裡發生了問題
,謝謝
_______________________________
已安裝的mod
cash mod
生日mod
走馬燈
人氣指數
股市外掛 <<<未解決
下載中心
好站連結
shoutbox MOD>>>還有很多.......
