[問題]Chinese coding [Req Help]
gsnradio
註冊時間: 2004-04-21 03:37
來自: United Kingdom
文章 gsnradio »
Hi sorry dont know chinese, but i was asked in my clan to put chinese in our forum
Gamer Sport Cast Network
Anyway, my problem is i can see chinese and use the chinese interface. But when we try to type in the topic it will not show any chinese characters.
But it shows #&231; #&1234
So, i need some help on correcting this problem...
Please accept my apologies if i sent to the wrong forum or category...
Best regards and looking forward for your reply
All rights reserved to Gamers SportCast Network, (2004). This site is powered by Canaca 圖檔
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
To make Chinese character display correctly in topic, you need to modify a few PHP files. We have guides to how to do this, but it is in Chinese. I'm not sure if I am permitted to translate the document.
If you want, I can edit the files (from vanilla phpBB) for you and give you when I'm done
What phpBB version do you want to use?
~Mac
大佬
文章: 260
註冊時間: 2003-11-30 13:38
來自: Kluang,Johor,Malaysia
文章 大佬 »
Mac , 那些多國語言修正是在安裝完phpbb后才改的嗎?
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
●您的 phpBB2 版本:phpBB 2.0.8
