●快速架站程式:Appserv v2.3.0(安裝在自己電腦上)
●您的上網方式:ADSL+IP分享器
●您的 phpBB2 版本:phpBB 2.0.8
●安裝過程:
自從我成功建立論壇之後,先去把論壇內的註冊功能搞定,接著更改[教學]phpMyAdmin 也搞定之後 想依照 這篇 ttsmarco兄的轉址教學進行轉址,但是,改好以後就出錯了
大意是說我論壇整個裝完之後,設定好phpmyadmin的帳號與密碼之後,接下來想把首頁直接使用轉只轉到phpBB2/index.php就不行了
有改到的檔案
php.ini -->設定smtp主機 可發註冊信(ok)
phpMyAdmin\config.inc.php -->設定完成帳號密碼(ok)
<?php
/* $Id: config.inc.php,v 1.204.2.1 2003/10/10 14:24:24 nijel Exp $ */
// vim: expandtab sw=4 ts=4 sts=4:
* phpMyAdmin Configuration File
*\r
* All directives are explained in Documentation.html
* Sets the php error reporting - Please do not change this line!
if (!isset($old_error_reporting)) {
error_reporting(E_ALL);
@ini_set('display_errors', '1');
* Your phpMyAdmin url
* Complete the variable below with the full url ie
* http://www.your_web.net/path_to_your_phpMyAdmin_directory/
* It must contain characters that are valid for a URL, and the path is
* case sensitive on some Web servers, for example Unix-based servers.
* In most cases you can leave this variable empty, as the correct value
* will be detected automatically. However, we recommend that you do
* test to see that the auto-detection code works in your system. A good
* test is to browse a table, then edit a row and save it. There will be
* an error message if phpMyAdmin cannot auto-detect the correct value.
* If the auto-detection code does work properly, you can set to TRUE the
* $cfg['PmaAbsoluteUri_DisableWarning'] variable below.
$cfg['PmaAbsoluteUri'] = 'http://123.abc/phpMyAdmin/';
* Disable the default warning about $cfg['PmaAbsoluteUri'] not being set
* You should use this if and ONLY if the PmaAbsoluteUri auto-detection
* works perfectly.
$cfg['PmaAbsoluteUri_DisableWarning'] = FALSE;
* Disable the default warning that is displayed on the DB Details Structure page if
* any of the required Tables for the relationfeatures could not be found
$cfg['PmaNoRelation_DisableWarning'] = FALSE;
* The 'cookie' auth_type uses blowfish algorithm to encrypt the password. If
* at least one server configuration uses 'cookie' auth_type, enter here a
* passphrase that will be used by blowfish.
$cfg['blowfish_secret'] = '';
* Server(s) configuration
$i = 0;
// The $cfg['Servers'] array starts with $cfg['Servers'][1]. Do not use $cfg['Servers'][0].
// You can disable a server config entry by setting host to ''.
$i++;
$cfg['Servers'][$i]['host'] = 'localhost'; // MySQL hostname or IP address
$cfg['Servers'][$i]['port'] = ''; // MySQL port - leave blank for default port
$cfg['Servers'][$i]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfg['Servers'][$i]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')
$cfg['Servers'][$i]['compress'] = FALSE; // Use compressed protocol for the MySQL connection
// (requires PHP >= 4.3.0)
$cfg['Servers'][$i]['controluser'] = '我的帳號'; // MySQL control user settings
// (this user must have read-only
$cfg['Servers'][$i]['controlpass'] = '我的密碼'; // access to the "mysql/user"
// and "mysql/db" tables)
$cfg['Servers'][$i]['auth_type'] = 'http'; // Authentication method (config, http or cookie based)?
$cfg['Servers'][$i]['user'] = ''; // MySQL user
$cfg['Servers'][$i]['password'] = ''; // MySQL password (only needed
// with 'config' auth_type)
$cfg['Servers'][$i]['only_db'] = ''; // If set to a db-name, only
// this db is displayed
// at left frame
// It may also be an array
// of db-names
$cfg['Servers'][$i]['verbose'] = ''; // Verbose name for this host - leave blank to show the hostname\r
$cfg['Servers'][$i]['pmadb'] = ''; // Database used for Relation, Bookmark and PDF Features
// (see scripts/create_tables.sql)
// - leave blank for no support
// DEFAULT: 'phpmyadmin'
$cfg['Servers'][$i]['bookmarktable'] = ''; // Bookmark table
// - leave blank for no bookmark support
// DEFAULT: 'pma_bookmark'
$cfg['Servers'][$i]['relation'] = ''; // table to describe the relation between links (see doc)
// - leave blank for no relation-links support
// DEFAULT: 'pma_relation'
$cfg['Servers'][$i]['table_info'] = ''; // table to describe the display fields
// - leave blank for no display fields support
// DEFAULT: 'pma_table_info'
$cfg['Servers'][$i]['table_coords'] = ''; // table to describe the tables position for the PDF schema
// - leave blank for no PDF schema support
// DEFAULT: 'pma_table_coords'
$cfg['Servers'][$i]['pdf_pages'] = ''; // table to describe pages of relationpdf
// - leave blank if you don't want to use this
// DEFAULT: 'pma_pdf_pages'
$cfg['Servers'][$i]['column_info'] = ''; // table to store column information
// - leave blank for no column comments/mime types
// DEFAULT: 'pma_column_info'
$cfg['Servers'][$i]['history'] = ''; // table to store SQL history
// - leave blank for no SQL query history
// DEFAULT: 'pma_history'
$cfg['Servers'][$i]['verbose_check'] = TRUE; // set to FALSE if you know that your pma_* tables
// are up to date. This prevents compatibility
// checks and thereby increases performance.
$cfg['Servers'][$i]['AllowDeny']['order'] // Host authentication order, leave blank to not use
$cfg['Servers'][$i]['AllowDeny']['rules'] // Host authentication rules, leave blank for defaults
= array();
header("Location: http://123.abc.net/phpBB2/index.php");
?>phpBB : Critical Error
以上敘述不知清不清楚,若還需提供什麼參考資料,我再提供,謝謝
