[問題]how to fix this?
ryu
註冊時間: 2004-03-05 17:04
文章 ryu »
Could not update user table
SQL Error : 1054 Unknown column 'user_nickname' in 'field list'
UPDATE phpbb_users SET user_nickname = '', user_realname = '', user_viewwebsite = '1', user_viewmessanger = '1', user_viewreal = '1', user_website = '', user_icq = '', user_aim = '', user_msnm = '', user_yim = '', user_gender = '0', user_birthday = '0', user_from = '', user_from_flag = 'blank.gif', user_occ = '', user_interests = '', user_home_phone = '', user_home_fax = '', user_work_phone = '', user_work_fax = '', user_cellular = '', user_pager = '', user_last_birthday = 0 WHERE user_id = 2
Line : 144
File : /home/ryuwong/domains/ryuwong.hkjzone.com/public_html/profilcp/profilcp_profil_base.php
how to fix ?
Martinet
文章: 850
註冊時間: 2003-06-09 21:58
文章 Martinet »
It is important to read the announcements first before you ask qustions...
to solve your problem :
http://phpbb-tw.net/phpbb/viewtopic.php ... C%CA%BA%D9
reinstall the [includes/usercp_register.php ] part
I suggest you to follow the [replace]postscripts , rather then [replace] itself
Good luck ;)
messagebox
文章: 981
註冊時間: 2003-02-24 23:34
文章 messagebox »
你的資料表裏找不到user_nickname這欄位
william91
文章: 642
註冊時間: 2003-04-16 20:53
來自: 牛牛農場
文章 william91 »
你應該未新增SQL的部份
另外,外掛問題請到外掛區問,也請依照發問格式
間中上來走走吧~
