[Windows]安裝AppServ for winXp問題
駱蕭豪
註冊時間: 2004-03-01 10:14
文章 駱蕭豪 »
:oops: 我是個新手,我看著書上第二章操作,apache環境架起來,但進入phpMyAdmin Database Manager Version 2.2.6就出現如下:
我無法在完成接下來的步驟,請問是那裡出錯??請給予指導、謝謝!
歡迎使用 phpMyAdmin 2.2.6
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 23
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 24
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 25
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 26
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 27
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 29
錯誤
MySQL 傳回:
Can't connect to MySQL server on 'localhost' (10061)
幻狼神威
文章: 389
註冊時間: 2002-10-29 01:54
來自: 薔薇幻境
文章 幻狼神威 »
照順序檢查:
  1. 常駐程式那一列有沒有一個紅綠燈?
    YES → 到下一題、No → Stop
  2. 有的話紅綠燈是紅的還是綠的?
  3. 如果是綠的,那你MySQL的帳號密碼是否和phpMyAdmin一樣?
    YES → 結束、No → Stop
如果到Stop,表示你的Mysql沒設好。
如果你做到結束,那請你再照發文格式詳細的描述一次你的問題....^^"
[必看] phpBB 架站討論區發文規則與發問格式
學好phpBB的訣竅:
   ↑蘿莉不在此限.......XD"
小熊豬
註冊時間: 2004-03-01 20:43
文章 小熊豬 »
謝謝版主~~問題解泱了
真的粉謝謝~qq
