[問題]phpMyAdmin 2.5.1問題
pireer
文章: 44
註冊時間: 2004-02-17 09:43
來自: 風城
文章 pireer »
各位大大.我是php新手.想請問一個問題.
安裝mysql4.0.17forwin之後.
在安裝phpMyAdmin 2.5.1
ie輸入http://192.168.1.3/phpMyAdmin-2.5.1/index.php.
出現:
錯誤
MySQL 傳回:
Access denied for user: 'root@pireer' (Using password: YES)
設定如下
$cfg['Servers'][$i]['host'] = '192.168.1.3'; // MySQL hostname
$cfg['Servers'][$i]['port'] = ''; // MySQL port - leave blank for default port
$cfg['Servers'][$i]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfg['Servers'][$i]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')
$cfg['Servers'][$i]['compress'] = FALSE; // Use compressed protocol for the MySQL connection
// (requires PHP >= 4.3.0)
$cfg['Servers'][$i]['controluser'] = ''; // MySQL control user settings
// (this user must have read-only
$cfg['Servers'][$i]['controlpass'] = ''; // access to the "mysql/user"
// and "mysql/db" tables)
$cfg['Servers'][$i]['auth_type'] = 'config'; // Authentication method (config, http or cookie based)?
$cfg['Servers'][$i]['user'] = 'root'; // MySQL user
$cfg['Servers'][$i]['password'] = '123456'; // MySQL password (only needed
我也有依照之前文章做設定.可以登入.但phpMyAdmin會出現權限不夠.請大大們幫幫忙..感激不盡.謝謝
幻狼神威
文章: 389
註冊時間: 2002-10-29 01:54
來自: 薔薇幻境
Re: [問題]phpMyAdmin 2.5.1問題
文章 幻狼神威 »
pireer 寫: 錯誤
MySQL 傳回:
帳號密碼錯誤......
pireer 寫: $cfg['Servers'][$i]['user'] = 'root'; // MySQL user
應該是要改這兩行吧.......
[必看] phpBB 架站討論區發文規則與發問格式
學好phpBB的訣竅:
   ↑蘿莉不在此限.......XD"
