[問題]安裝過程中發生錯誤?
jackylam
文章: 16
註冊時間: 2003-12-26 21:20
[問題]安裝過程中發生錯誤?
文章 jackylam »
i am going to install phpbb
after clicking "install" in /install.php
it shows "安裝過程中發生錯誤
在嘗試更新資料庫時發生錯誤
Table 'phpbb_vote_voters' already exists
what's matter?
my phpmyadmin already had some data here...
thanks a lot
aiken
文章: 1514
註冊時間: 2003-11-09 11:02
來自: 大頭真論壇
文章 aiken »
Table already exists
you can delete your MySQL database, first
then, install again
jackylam
文章: 16
文章 jackylam »
aiken 寫:Table already exists
then, install again
delete all data in my sql database???
aiken
文章: 1514
來自: 大頭真論壇
文章 aiken »
jackylam 寫:
then, install again
what's the problem?
jackylam
文章: 16
文章 jackylam »
aiken said i can delete your MySQL database, first
then, install again
so i want to ask am i delete all data or only delete Table 'phpbb_vote_voters' ????
thanks
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
if you want to reinstall everything, yes, delete the whole database
~Mac
jackylam
文章: 16
文章 jackylam »
Mac 寫:if you want to reinstall everything, yes, delete the whole database
\n
~Mac
if i don't want to reinstall everything, what should i do?
thanks all frankly answering my stupid question~~
thanks a lot
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 Mac »
So what do you want then?
Your first topic didn't really mention any details, you only said you want to install phpBB?
Why are you using a database that is not empty?
~Mac
