lycos really drives me crazy~~
我用fontpage把我的phpbb 都上傳上去了
http://members.lycos.co.uk/chijessica/
Disk space used:8 MB used of 50 MB allocated
我把所有相關文章都看過一遍 但我還是不知到為啥\r
也一些又有看沒懂
我開起
http://members.lycos.co.uk/chijessica/i ... nstall.php
都說
The page cannot be found
It may no longer exist.
It may have moved to another web address.
It may be a restricted area.
Please check your spelling to make sure you've typed the correct web address. One wrong character can prompt a "The page cannot be found" message.
Lycos Tripod UK Team
我到php4u
Manage your database
Add, remove and view your records using our simple database management interface.
Your database information:Name: chijessica_uk_db
Username: chijessica
Password: no password needed
Host: localhost
我按進去Manage your database
它會出現一個小window
那裡是可以幹麻的
我看了許多的文章 說可以在那網頁上上傳 納在哪裡呢?
還是 我用 ftp 上傳到 我ㄉphp 裡\r
我用smart php 上傳 過 也是和在fontpage 上傳到的地方一樣\r
我知道我這個問題出現很多次\r
但我真的 試過在試過~
希望 你們能協住我完成 我ㄉphp
謝謝你们
[問題]LYCOS!!!!!!help!!!
