[Windows]請教高手...無法進入設定頁面?!
h517
註冊時間: 2003-10-11 15:09
文章 h517 »
我按步驟把伺服器端按"start"了
然後在IE輸入IP
接著按"phpMyAdmin Database Manager Version 2.2.6"進入連結
可是卻出現錯誤畫面如下
Warning: Cannot add header information - headers already sent by (output started at d:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in d:\appserv\www\phpmyadmin\\header.inc.php on line 23
Warning: Cannot add header information - headers already sent by (output started at d:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in d:\appserv\www\phpmyadmin\header.inc.php on line 24
Warning: Cannot add header information - headers already sent by (output started at d:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in d:\appserv\www\phpmyadmin\header.inc.php on line 25
Warning: Cannot add header information - headers already sent by (output started at d:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in d:\appserv\www\phpmyadmin\header.inc.php on line 26
Warning: Cannot add header information - headers already sent by (output started at d:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in d:\appserv\www\phpmyadmin\header.inc.php on line 27
Warning: Cannot add header information - headers already sent by (output started at d:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in d:\appserv\www\phpmyadmin\header.inc.php on line 29
錯誤
MySQL 傳回:
Can't connect to MySQL server on 'localhost' (10061)
這是為啥呢?請救救我~~
