[問題]PHPBB Installation Problem
DeYao
註冊時間: 2003-09-12 10:47
文章 DeYao »
Hello Dear Friends,
I'm unable to login to my lycos account using FTP software (WS_FTP and CuteFTP). So I just can use WebFTP to upload the PHPBB 2.06 to Lycos.co.uk(free hosting) . I had upload whole structure and never change the file name and structure.
After that, I go to the installation page, I ensure that everything I type is correct:
Database Type: MySQL 3.x
Installation Method: Install
Database Server Hostname / DSN: localhost
Your Database Name: username_uk_db
Database Password:
Prefix for tables in database: phpbb_
Domain name: members.lycos.co.uk
Server Port: 80
Script path: /username/forum/
When I click "Start Install" , the error message displayed:
phpBB : Critical Error
All my dear friends, can you help me?
Thank you very very much!
jackyilk
文章: 538
註冊時間: 2002-07-21 18:55
來自: 台灣
文章 jackyilk »
Can you talk Chinese??
文章 小竹子 »
有可能是您連線到該站台過慢問題,基本上只要沒填寫錯誤就應該可以連上!
