[問題]作暸Cache后不能上傳附件 急
tiny
文章: 15
註冊時間: 2003-07-04 13:11
文章 tiny »
phpbb版本:2.04 MOD版
對資料庫作暸Cache后,把 phpBB2/contrib/template_db_cache.php這個檔案改名為template.php 放到includes目錄下取代原有的template.php后,上傳附件功能就沒有暸,
謝謝各位,我剛纔擻尋暸沒有髮現答案,痲煩知道的大大告訴我,謝謝
tiny
文章: 15
文章 tiny »
沒有人知道嗎?
要不要我將template.php貼齣來?
tiny
文章: 15
文章 tiny »
大俠們,救救我呀!謝謝
tiny
文章: 15
[求救 ]資料庫作完Cache后的template.php
文章 tiny »
<?php
* template.inc
* email : support@phpbb.com
* $Id: template_db_cache.php,v 1.1.1.1 2003/03/25 05:20:50 wei.gao Exp $
* Template class. By Nathan Codding of the phpBB group.
* The interface was originally inspired by PHPLib templates,
* and the template file formats are quite similar.
class Template {
var $classname = "Template";
// variable that holds all the data we'll be substituting into
// the compiled templates.
// This will end up being a multi-dimensional array like this:
// $this->_tpldata[block.][iteration#][child.][iteration#][child2.][iteration#][variablename] == value
// if it's a root-level variable, it'll be like this:
// $this->_tpldata[.][0][varname] == value
var $_tpldata = array();
\r
// Hash of filenames for each template handle.
var $files = array();
// Root template directory.
var $root = "";
// this will hash handle names to the compiled code for that handle.
var $compiled_code = array();
// This will hold the uncompiled code for that handle.
var $uncompiled_code = array();
* Constructor. Simply sets the root dir.
function Template($root = '.', $_board_config = false, $_db = false)
$this->set_rootdir($root);
$this->db = $_db;
$this->pparse_order = array();
* Destroys this template object. Should be called when you're done with it, in order
* to clear out the template data so you can load/parse a new template set.
function destroy()
$this->_tpldata = array();
* Sets the template root directory for this Template object.
function set_rootdir($dir)
if (!is_dir($dir))
\n return false;
$this->root = $dir;
return true;
* Sets the template filenames for handles. $filename_array
* should be a hash of handle => filename pairs.
function set_filenames($filename_array)
global $table_prefix;
if ( !is_array($filename_array) )
return false;
$template_names = '';
@reset($filename_array);
while ( list($handle, $filename) = @each($filename_array) )
$this->files[$handle] = $this->make_filename($filename);
$template_names .= ( $template_names != '' ) ? ", '" . addslashes($this->files[$handle]) . "'" : "'" . addslashes($this->files[$handle]) . "'";
$sql = "SELECT *
FROM " . $table_prefix . "template_cache
WHERE template_name IN ($template_names)";
if ( $result = $this->db->sql_query($sql) )
while( $row = $this->db->sql_fetchrow($result) )
if( $row['template_cached'] == filemtime($row['template_name']) )
$this->compiled_code[$row['template_handle']] = $row['template_compile'];
$this->echo_compiled[$row['template_handle']] = $row['template_echo'];
$this->db->sql_freeresult();
return true;
* Load the file for the handle, compile the file,
* and run the compiled code. This will print out
* the results of executing the template.
function pparse($handle)
if( empty($this->compiled_code[$handle]) )
if ( !$this->loadfile($handle) )
die("Template->pparse(): Couldn't load template file for handle $handle");
// Actually compile the code now.
$this->echo_compiled[$handle] = 1;
$this->compiled_code[$handle] = $this->compile($this->uncompiled_code[$handle]);
$sql = "REPLACE INTO " . $table_prefix . "template_cache (template_name, template_handle, template_cached, template_compile) VALUES ('" . addslashes($this->files[$handle]) . "', '" . addslashes($handle) . "', " . filemtime($this->files[$handle]) . ", '" . addslashes($this->compiled_code[$handle]) . "')";
if ( !($result = $this->db->sql_query($sql)) )
die("Couldn't insert template into cache!");
$_str = "";
eval($this->compiled_code[$handle]);
if( $_str != "" )
echo $_str;
return true;
* Inserts the uncompiled code for $handle as the
* value of $varname in the root-level. This can be used
* to effectively include a template in the middle of another
* template.
* Note that all desired assignments to the variables in $handle should be done
* BEFORE calling this function.
function assign_var_from_handle($varname, $handle)
$code = $this->compile($this->uncompiled_code[$handle], true, '_str');
$sql = "REPLACE INTO " . $table_prefix . "template_cache (template_name, template_handle, template_echo, template_cached, template_compile) VALUES ('" . addslashes($this->files[$handle]) . "', '" . addslashes($handle) . "', 0, " . filemtime($this->files[$handle]) . ", '" . addslashes($code) . "')";
$code = $this->compiled_code[$handle];
// Compile It, With The "no Echo Statements" Option On.
$_str = "";
// evaluate the variable assignment.
eval($code);
// assign the value of the generated variable to the given varname.
$this->assign_var($varname, $_str);
return true;
* Block-level variable assignment. Adds a new block iteration with the given
* variable assignments. Note that this should only be called once per block
* iteration.
function assign_block_vars($blockname, $vararray)
if (strstr($blockname, '.'))
// Nested block.
$blocks = explode('.', $blockname);
$blockcount = sizeof($blocks) - 1;
$str = '$this->_tpldata';
for ($i = 0; $i < $blockcount; $i++)
$str .= '[\'' . $blocks[$i] . '.\']';
eval('$lastiteration = sizeof(' . $str . ') - 1;');
$str .= '[' . $lastiteration . ']';
// Now we add the block that we're actually assigning to.
// We're adding a new iteration to this block with the given
// variable assignments.
$str .= '[\'' . $blocks[$blockcount] . '.\'][] = $vararray;';
// Now we evaluate this assignment we've built up.
eval($str);
// Top-level block.
// Add a new iteration to this block with the variable assignments
// we were given.
$this->_tpldata[$blockname . '.'][] = $vararray;
return true;
* Root-level variable assignment. Adds to current assignments, overriding
* any existing variable assignment with the same name.
function assign_vars($vararray)
reset ($vararray);
while (list($key, $val) = each($vararray))
$this->_tpldata['.'][0][$key] = $val;
return true;
function assign_var($varname, $varval)
$this->_tpldata['.'][0][$varname] = $varval;
return true;
* Generates a full path+filename for the given filename, which can either
* be an absolute name, or a name relative to the rootdir for this Template
* object.
function make_filename($filename)
// Check if it's an absolute or relative path.
if (substr($filename, 0, 1) != '/')
$filename = $this->root . '/' . $filename;
if (!file_exists($filename))
die("Template->make_filename(): Error - file $filename does not exist");
return $filename;
* If not already done, load the file for the given handle and populate
* the uncompiled_code[] hash with its code. Do not compile.
function loadfile($handle)
// If the file for this handle is already loaded and compiled, do nothing.
if ( !empty($this->uncompiled_code[$handle]) )
return true;
// If we don't have a file assigned to this handle, die.
if (!isset($this->files[$handle]))
die("Template->loadfile(): No file specified for handle $handle");
$filename = $this->files[$handle];
$str = implode("", @file($filename));
if (empty($str))
die("Template->loadfile(): File $filename for handle $handle is empty");
$this->uncompiled_code[$handle] = $str;
return true;
* Compiles the given string of code, and returns
* the result in a string.
* If "do_not_echo" is true, the returned code will not be directly
* executable, but can be used as part of a variable assignment
* for use in assign_code_from_handle().
function compile($code, $do_not_echo = false, $retvar = '')
// replace \ with \\\ and then ' with \'.
$code = str_replace('\\\', '\\\\\\\', $code);
$code = str_replace('\'', '\\\\\'', $code);
// change template varrefs into PHP varrefs
// This one will handle varrefs WITH namespaces
$varrefs = array();
preg_match_all('#\{(([a-z0-9\-_]+?\.)+?)([a-z0-9\-_]+?)\}#is', $code, $varrefs);
$varcount = sizeof($varrefs[1]);
for ($i = 0; $i < $varcount; $i++)
$namespace = $varrefs[1][$i];
$varname = $varrefs[3][$i];
$new = $this->generate_block_varref($namespace, $varname);
$code = str_replace($varrefs[0][$i], $new, $code);
// This will handle the remaining root-level varrefs
$code = preg_replace('#\{([a-z0-9\-_]*?)\}#is', '\' . ( ( isset($this->_tpldata[\'.\'][0][\'\1\']) ) ? $this->_tpldata[\'.\'][0][\'\1\'] : \'\' ) . \'', $code);
// Break it up into lines.
$code_lines = explode("
", $code);
$block_nesting_level = 0;
$block_names = array();
$block_names[0] = ".";
// Second: prepend echo ', append ' . "
"; to each line.
$line_count = sizeof($code_lines);
for ($i = 0; $i < $line_count; $i++)
$code_lines[$i] = chop($code_lines[$i]);
if (preg_match('#<!-- BEGIN (.*?) -->#', $code_lines[$i], $m))
$n[0] = $m[0];
$n[1] = $m[1];
// Added: dougk_ff7-Keeps templates from bombing if begin is on the same line as end.. I think. :)
if ( preg_match('#<!-- END (.*?) -->#', $code_lines[$i], $n) )
$block_nesting_level++;
$block_names[$block_nesting_level] = $m[1];
if ($block_nesting_level < 2)
// Block is not nested.
$code_lines[$i] = '$_' . $a[1] . '_count = ( isset($this->_tpldata[\'' . $n[1] . '.\']) ) ? sizeof($this->_tpldata[\'' . $n[1] . '.\']) : 0;';
$code_lines[$i] .= "
" . 'for ($_' . $n[1] . '_i = 0; $_' . $n[1] . '_i < $_' . $n[1] . '_count; $_' . $n[1] . '_i++)';
// This block is nested.
// Generate a namespace string for this block.
$namespace = implode('.', $block_names);
\n // strip leading period from root level..
$namespace = substr($namespace, 2);
// Get a reference to the data array for this block that depends on the
// current indices of all parent blocks.
$varref = $this->generate_block_data_ref($namespace, false);
// Create the for loop code to iterate over this block.
$code_lines[$i] = '$_' . $a[1] . '_count = ( isset(' . $varref . ') ) ? sizeof(' . $varref . ') : 0;';
// We have the end of a block.
unset($block_names[$block_nesting_level]);
$block_nesting_level--;
$code_lines[$i] .= '} // END ' . $n[1];
$m[0] = $n[0];
$m[1] = $n[1];
// We have the start of a block.
$code_lines[$i] = '$_' . $m[1] . '_count = ( isset($this->_tpldata[\'' . $m[1] . '.\']) ) ? sizeof($this->_tpldata[\'' . $m[1] . '.\']) : 0;';
" . 'for ($_' . $m[1] . '_i = 0; $_' . $m[1] . '_i < $_' . $m[1] . '_count; $_' . $m[1] . '_i++)';
\n $code_lines[$i] = '$_' . $m[1] . '_count = ( isset(' . $varref . ') ) ? sizeof(' . $varref . ') : 0;';
else if (preg_match('#<!-- END (.*?) -->#', $code_lines[$i], $m))
$code_lines[$i] = '} // END ' . $m[1];
// We have an ordinary line of code.
if (!$do_not_echo)
$code_lines[$i] = 'echo \'' . $code_lines[$i] . '\' . "\\
$code_lines[$i] = '$' . $retvar . '.= \'' . $code_lines[$i] . '\' . "\\
// Bring it back into a single string of lines of code.
$code = implode("
", $code_lines);
return $code ;
* Generates a reference to the given variable inside the given (possibly nested)
* block namespace. This is a string of the form:
* ' . $this->_tpldata['parent'][$_parent_i]['$child1'][$_child1_i]['$child2'][$_child2_i]...['varname'] . '
* It's ready to be inserted into an "echo" line in one of the templates.
* NOTE: expects a trailing "." on the namespace.
function generate_block_varref($namespace, $varname)
// Strip the trailing period.
$namespace = substr($namespace, 0, strlen($namespace) - 1);
// Get a reference to the data block for this namespace.
$varref = $this->generate_block_data_ref($namespace, true);
// Prepend the necessary code to stick this in an echo line.
// Append the variable reference.
$varref .= '[\'' . $varname . '\']';
$varref = '\' . ( ( isset(' . $varref . ') ) ? ' . $varref . ' : \'\' ) . \'';
\r
return $varref;
* Generates a reference to the array of data values for the given
* (possibly nested) block namespace. This is a string of the form:
* $this->_tpldata['parent'][$_parent_i]['$child1'][$_child1_i]['$child2'][$_child2_i]...['$childN']
* If $include_last_iterator is true, then [$_childN_i] will be appended to the form shown above.
* NOTE: does not expect a trailing "." on the blockname.
function generate_block_data_ref($blockname, $include_last_iterator)
// Get an array of the blocks involved.
$blocks = explode(".", $blockname);
$varref = '$this->_tpldata';
// Build up the string with everything but the last child.
$varref .= '[\'' . $blocks[$i] . '.\'][$_' . $blocks[$i] . '_i]';
// Add the block reference for the last child.
$varref .= '[\'' . $blocks[$blockcount] . '.\']';
// Add the iterator for the last child if requried.
if ($include_last_iterator)
$varref .= '[$_' . $blocks[$blockcount] . '_i]';
return $varref;
tiny
文章: 15
文章 tiny »
是因為我說得不夠明白嗎??
tiny
文章: 15
[問題]嬭到我作錯什么暸嗎?
文章 tiny »
:-? 怎么沒人理我?小竹子幫幫我!!!
不勝感激!! :cry:
Mowd
文章: 326
註冊時間: 2002-06-26 01:17
來自: 台北
文章 Mowd »
第一,你為什麼要這樣做?
第二,試著把原來的檔案換回去試試看
tiny
文章: 15
文章 tiny »
大大呀,對資料庫作暸Cache速度就快拉呀!有誰會對一個很慢的論壇感興趣呢?
可能是我問的不明白嗎?
我將template.php改會來,問題是解決勒可是好慢呀!!
Mowd
文章: 326
來自: 台北
文章 Mowd »
因為上傳附件的功能可能修改到了原來的檔案,所以你把另外的檔案覆蓋過去後就會出現無法上傳附件的情形。
看看上傳附件的mod對template.php這個檔案做了哪些修改,把新的檔案也改一下試試看。
tiny
文章: 15
文章 tiny »
Mowd謝謝妳的提醒,我現在來看看,自己能否解決問題,因為我的PHP很菜!
