[Linux]Chinese language
eyal
註冊時間: 2003-07-08 16:36
文章 eyal »
Hi all, sorry if this has been asked before.. but I would like to enable my phpbb board to accept Chinese language input for both the topic subject and the body of the message. If anyone out there can help then that would be appreciated.
Thanks!
Eyal
beowolf
竹貓好朋友
竹貓好朋友
文章: 267
註冊時間: 2002-04-11 21:23
來自: 竹貓東京分局
文章 beowolf »
all you need to do is put our chinese language pack into your phpbb.
then you can type and read chinese.
but if you just want to use your english language.
you might wana to try to open your lang_main.php and
change the encoding from ISO-8859-1 to BIG5
but it might be strange .
if you need further help . just let us know.
good luck!
圖檔2014新作-達人聯盟
斷斷續續玩了12年的phpbb. 真的看不上別的論壇啊..
