我不知道這篇文章是啥時po的...
不過現在要錢啦~>.<~
真是的.....好貴>.<
[分享]可以用POP3 收 Yahoo Mail!
友誼第一
Computer-Madman
- 星球普通子民
- 文章: 1
- 註冊時間: 2005-02-20 11:45
- 來自: Taipei
- 聯繫:
hmsheen 寫:
不好意思~我還是不會用\r
因為我有去抓了YahooPOPs! (在toget下載的)
可是我不知道怎麼設定OE
哪位高人可以教我一下呢?
感激不盡
以下是設置程序:
原想張貼中文,但自己翻得不順,所以就將原文貼上~
YPOPs! and Outlook Express 6
1. Select "Accounts..." from the "Tools" menu.
2. Click "Add" button and select "Mail...".
3. Enter your name and click "Next".
4. Enter your email address and click "Next".
5. Set "My incoming mail server is a" to POP3.
6. Set "Incoming (POP3, IMAP or HTTP) mail server" to "127.0.0.1".
7. Set "Outgoing (SMTP) mail server" to "127.0.0.1" and click "Next". (Verify that SMTP is enabled in YPOPs.)
8. Set "Account name:" to your Yahoo! login.
9. Set "Password:" to you Yahoo! password and hit "Next".
10. Hit "Finish".
11. Click on new account named "127.0.0.1" and hit "Properties".
12. Rename account to "YPOPs" or something nice.
13. Select "Servers" tab.
14. Check "My server requires authentication".
15. Select "Advanced" tab.
16. Change "Server Timeouts" to Long - 5 minutes.
17. You may wish to select "Leave a copy of messages on server". This way the messages will not be deleted from Yahoo! when you download them.
18. You may wish to select "Remove from server when deleted from 'Deleted Items'". This way when you delete a message in OE and empty the trash it's deleted from Yahoo! as well.
NOTE: This instruction set was provided by Angus Graham.
