論壇外掛 Forum Sponsor (增加廣告於特定版面)出現錯誤訊息?
paojen168
文章: 9
註冊時間: 2009-08-26 16:02
文章 paojen168 »
按照論壇外掛 Forum Sponsor (增加廣告於特定版面)安裝完畢。
在acp-> 論壇贊助商/廣告 右側欄位輸入文字送出後,就出現錯誤訊息如下,另外"版面規則"右側欄位輸入文字,也出現同樣訊息。
是自己那裡沒做好? :((
好心版主請指點一下。謝謝!!
一般性錯誤
SQL ERROR [ mysql4 ]
Unknown column 'forum_sponsor' in 'field list' [1054]
SQL
UPDATE phpbb_forums SET forum_sponsor = '', forum_sponsor_uid = '', forum_sponsor_options = 7, forum_sponsor_bitfield = '', forum_sponsor_html = 0, parent_id = 0, forum_type = 1, forum_status = 0, forum_parents = '', forum_name = '新客戶優惠', forum_link = '', forum_desc = '', forum_desc_uid = '', forum_desc_options = 7, forum_desc_bitfield = '', forum_rules = 'test', forum_rules_uid = '', forum_rules_options = 7, forum_rules_bitfield = '', forum_rules_link = '', forum_image = '', forum_style = 0, display_subforum_list = 1, display_on_index = 1, forum_topics_per_page = 0, enable_indexing = 1, enable_icons = 0, enable_prune = 0, prune_days = 7, prune_viewed = 7, prune_freq = 1, forum_flags = 32 WHERE forum_id = 25
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal->sql_error()
FILE: includes/acp/acp_forums.php
LINE: 1302
CALL: dbal_mysql->sql_query()
LINE: 239
CALL: acp_forums->update_forum_data()
FILE: includes/functions_module.php
LINE: 507
CALL: acp_forums->main()
FILE: adm/index.php
LINE: 74
CALL: p_master->load_active()
●主機作業系統:vista
●上網方式:ADSL
●安裝的程式:MySql
●phpBB 版本:phpBB 3.0.4
●phpBB 網址:
●測試用賬戶︰
●測試用密碼︰
Re: 論壇外掛 Forum Sponsor (增加廣告於特定版面)出現錯誤訊息?
paojen168 寫:按照論壇外掛 Forum Sponsor (增加廣告於特定版面)安裝完畢。
是自己那裡沒做好? :((
好心版主請指點一下。謝謝!!
一般性錯誤
SQL
BACKTRACE
LINE: 174
LINE: 1302
LINE: 239
LINE: 507
FILE: adm/index.php
LINE: 74
●主機作業系統:vista
●上網方式:ADSL
●安裝的程式:MySql
●phpBB 網址:
●測試用賬戶︰
●測試用密碼︰
您沒有執行該外掛的 "install.php".
paojen168
文章: 9
文章 paojen168 »
回報:
學生反覆多次安裝INSTALL.PHP後,錯誤情形不變。
今日,將includes/acp/acp_forums.php 改成原先版本,後台ACP就可正常運作。
殘念!! :-?
paojen168 寫:回報:
殘念!! :-?
將檔案還原回去, 當然不會出錯;
不過, 這麼做您不是白忙一場嗎?
請補充說明:
您如何 "反覆多次安裝INSTALL.PHP"?
paojen168
文章: 9
文章 paojen168 »
1.將install.php上傳至主機root/install.php。
2.在網址列輸入 http:網址/install.php
3.之後出現acp介面,上面顯示說我不是管理者不能進入之類的話。
4.我登入acp後,在版面最下方的欄位輸入資料,送出後,就出現錯誤訊息。(安裝install後有將這個刪除)
:-D 我將它還原,是因為安裝后,在"新建版面"時也會出現錯誤訊息。為了讓論壇能正常運作,所以將程式先還原成原來版本。
paojen168 寫:1.將install.php上傳至主機root/install.php。
若依您的描述, 則您的資料庫更新並未完成.
正常程序如下:
1. 以論壇創始者身分, 登入論壇.
2. "在網址列輸入 http:網址/install.php" 後, 按 "ENTER" 執行資料庫更新. (執行成功後, 刪除 install.php)
3. 登入 ACP, 進行相關設定.
paojen168
文章: 9
文章 paojen168 »
正常程序如下:
1. 以論壇創始者身分, 登入論壇.
3. 登入 ACP, 進行相關設定.
按照版主指示程序1.2操作,ENTER後,出現"只有系統管理員可以閱讀此頁面"。(有刪除 install.php)
接著,執行3,結果出現相同錯誤。
另外,在acp選"系統",出現"Language file ./../language/zh_cmn_hant/install.php couldn't be opened.",不知道二者有沒有關連? :-P
paojen168 寫:
正常程序如下:
1. 以論壇創始者身分, 登入論壇.
3. 登入 ACP, 進行相關設定.
接著,執行3,結果出現相同錯誤。
依測試, 的確如您所言.
此版的 install.php 不適用於 phpBB 3.0.5, 必須進 phpMyAdmin 執行 SQL 命令.
http://phpbb-tw.net/phpbb/viewtopic.php ... 72#p273572
paojen168
文章: 9
文章 paojen168 »
版主謝謝了!!
資料庫操作不是很熟悉,怕操作不慎"全毀",決定先擱置此外掛。 :-D
再次感恩!!
paojen168 寫:版主謝謝了!!
再次感恩!!
無論如何, 安裝外掛前, 備份檔案或資料庫, 是必要的程序.
