[美化]閃光會員名稱
oO]-[Oo
南宮博士
南宮博士
文章: 512
註冊時間: 2001-11-11 18:09
來自: TAIWAN
[美化]閃光會員名稱
文章 oO]-[Oo »
功能: 將viewtopic裡, 發表人的會員名稱改為閃光文字. 同理也可以應用在其他地方...
## Mod Title: Glowing poster name 閃光會員名稱\r
## Mod Version: 1.0.0
## Author: OOHOO < webdev@phpbb-tw.net > http://phpbb-tw.net/
## Description:  Showing poster name with glowing text.
## Installation Level: (easy)
## Installation Time: 1 Minutes
## Files To Edit: /templates/your_template/viewtopic_body.tpl
## Security Disclaimer: This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
## Author Note: You can adjust glowing setting by yourself.
#-----[ ACTION: 打開 ]------------------------------------------
#-----[ ACTION: 尋找 ]------------------------------------------
<span class="name"><a name="{postrow.U_POST_ID}"></a><b>{postrow.POSTER_NAME}</b></span><br />
#-----[ ACTION: 替換為 ]------------------------------------------
<span style="filter: glow(color=blue,strength=3); height:10px; color:white; padding:1px; font-size : 11px"><a name="{postrow.U_POST_ID}"></a><b>{postrow.POSTER_NAME}</b></span><br />
#-----[ ACTION: 存檔搞定 ]------------------------------------------
# EoM
OOHOO said:
有事Mail給我, 不要P我, 因為根本沒辦法P.
adalf
註冊時間: 2002-04-29 08:42
文章 adalf »
嗯...不錯喔...加了變漂亮了
waitai
文章: 9
註冊時間: 2002-03-18 17:19
文章 waitai »
不錯來試試
oO]-[Oo
南宮博士
南宮博士
文章: 512
來自: TAIWAN
文章 oO]-[Oo »
進階版
## Mod Version: 1.1.0
## Files To Edit: viewtopic.php, /templates/your_template/viewtopic_body.tpl
## History:
## 1.1.0 advanced version, showing glowing color with different level
## 1.0.0 simple version
viewtopic.php
// Go ahead and pull all data for this topic
$sql = "SELECT u.username, u.user_id, u.user_posts, u.user_level, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile, u.user_money, u.user_session_time, u.user_allow_viewonline, p.*,  pt.post_text, pt.post_subject, pt.bbcode_uid
[color=red](註. 這段有幾個MOD會改到, 所以不一定會完全一樣)[/color]
#-----[ ACTION: 在 u.user_posts, 後加入 u.user_level,  ]------------------------------------------
$sql = "SELECT .............  u.user_posts, u.user_level, ..............
[color=red](註. 如果你對code一點概念都沒有, 請小心改)[/color]
	// Again this will be handled by the templating
	// code at some point
#-----[ ACTION: 在上面加入 ]------------------------------------------
	// Username in glowing
	if($postrow[$i]['user_level'] == 1) // Admin
		$glowing_color = '#' . $theme['fontcolor3'];
	else if($postrow[$i]['user_level'] == 2) // Moderator
		$glowing_color = '#' . $theme['fontcolor2'];
	else // normal
		$glowing_color = 'blue';
[color=red](註. 顏色可以自行調整, 如: $glowing_color = '#FF8000';)[/color]
		'MINI_POST_IMG' => $mini_post_img,
		'GLOWING_COLOR' => $glowing_color, // Username in glowing
<span style="filter: glow(color={postrow.GLOWING_COLOR},strength=3); height:10px; color:white; padding:1px; font-size : 11px"><a name="{postrow.U_POST_ID}"></a><b>{postrow.POSTER_NAME}</b></span><br />
# EoM
中等
文章: 54
註冊時間: 2002-04-19 01:11
文章 中等 »
YAYAYAYAYA
一次成功了,好高興好高興^O^
太感謝南宮大大的指導了,我正在希望能把原發表人跟回覆人的顏色區分開說~您真是太細心了,謝謝謝謝^^
中等叩上
嘰哩咕嚕嘰哩咕嚕.........
hr100
文章: 5
註冊時間: 2002-05-08 08:18
文章 hr100 »
恩 有些地方搞不懂耶\r
像這裡 if($postrow[$i]['user_level'] == 1) // Admin
$glowing_color = '#FF0000' . $theme['fontcolor3'];
這句是要指定給系統管理員所代表的顏色嗎?
還是要改['user_level']裡面的東西呢?
oO]-[Oo
南宮博士
南宮博士
文章: 512
來自: TAIWAN
文章 oO]-[Oo »
改成
$glowing_color = '#FF0000';
這是指定顏色, 不然他會用預設的('#' . $theme['fontcolor3'])
hr100
文章: 5
文章 hr100 »
哈哈 可以了唷!!
真是感謝呀
silverwing
文章: 111
註冊時間: 2002-01-15 15:40
來自: 天涯盡頭
文章 silverwing »
我也試成功了,謝謝博士。
oye
註冊時間: 2002-05-01 22:31
文章 oye »
耶~~~我也成功了~~^^
splin
文章: 73
註冊時間: 2002-04-17 20:21
來自: CPalm漢化聯盟
文章 splin »
感謝南宮博士的MOD,謝謝~~
圖檔http://cpalm.org/ , Palm 軟體中文化的專業站台。
kuloo
竹貓好朋友
竹貓好朋友
文章: 142
註冊時間: 2002-01-19 01:29
來自: 就是那個光.......
文章 kuloo »
好帥的ID~~ 8-)
. 文章篇數多與寡 , 非表自身之程度 , 有效助人為優先 , 耐心用心最重要 .
. 問題很多不可恥 , 就怕發問沒規矩 , 入境隨俗最重要 , 自然有人會幫您 .
. 初來乍到無所謂 , 閒聊之間學東西 , 善用搜尋為第一 , 對話用語要適宜 .
綠茶
文章: 7
註冊時間: 2002-05-01 18:58
文章 綠茶 »
嗯~~
一次就成功囉!
真是漂亮\r
感謝南宮博士的進階版
Dreamy
文章: 6
註冊時間: 2002-03-24 20:57
文章 Dreamy »
那麼,如果我想要讓我的簽名檔也出現這樣的發光效果,
該怎麼做呢? :?:
文章 小竹子 »
Dreamy 寫:那麼,如果我想要讓我的簽名檔也出現這樣的發光效果,
該怎麼做呢? :?:
改bbcode
回到「非官方認證外掛」
