[外掛]Filter memberlist 1.0.8
銀薰
文章: 48
註冊時間: 2003-05-10 00:28
文章 由 銀薰 »
## EasyMod 0.0.10a compliant
## MOD Title: 		Filter member list
## MOD Author: 		Shannado <sven@shannado.nl> (Sven) http://www.shannado.nl/forumorg
## MOD Description: With this MOD an user is able to filter the memberslist.
## MOD Version: 	1.0.8
## Installation Level: 	Easy
## Installation Time: 	10 - 20 Minutes
## Files To Edit: 		memberlist.php,
##						lang_main.php,
##						memberlist_body.tpl
## Included Files: N/A
## Author Notes:
##	When you don't like the extra selectbox AND you don't mind that user only can filter on 'Username'
##	Then you don't put '{L_MEMBERLIST_FILTER_SEL} {S_FILTER_SELECT} ' in the memberlist_body.tpl
##	By default the MOD filters on Username.
##	Change  $lang['Memberlist_filter'] = "keyword (wildcards allowed) "; into
##		$lang['Memberlist_filter'] = "username (wildcards allowed) ";
##	An user is able to filter on email, but if a user has set his email on hidden, then the user
##	will not show up in the list, if the filter matches the criteria. This does not concern if the user is an ADMIN
## MOD History:
## 01-01-2002 - 0.9.0 beta
##	- Beta
## 01-01-2002 - 0.9.1 beta
##	- The pagination will not take into account the filter used,
##	  and as a result the pagination will be created based on the total members.
##	  Thanks goto JamesB for finding the bug and making the solution for this bug
## 01-01-2002 - 0.9.5 beta
##	- Text stays in the textarea when you hit the sort button or clicking for the next page
##	- User is able to filter on Username, location, email OR website
## 01-01-2002 - 0.9.6 beta
##	- When nothing matches the critera a message will be show
## 01-01-2002 - 0.9.7 beta
##	- Forgot to change some code in the HOWTO
## 01-01-2002 - 1.0.0 FINAL
##	- Final
##	- No changes
## 01-01-2002 - 1.0.1 FINAL
##	- Some minor code cosmetic updates
## 01-01-2002 - 1.0.2 FINAL
##	- Add rank to the filter
## 01-01-2002 - 1.0.3 FINAL
##	- Fixed small typos
## 01-01-2002 - 1.0.4 FINAL
## 01-01-2002 - 1.0.5 FINAL
## 01-01-2002 - 1.0.6 FINAL
##	- Made phpBB v2.0.2 complaint and EasyMod 0.0.7 complaint
## 01-01-2002 - 1.0.7 FINAL
##	- Made phpBB v2.0.4 complaint and fixed a small bug
## 05-12-2003 - 1.0.8 FINAL
##	- Made phpBB v2.0.6 complaint and EasyMod 0.0.10a complaint
##	- Adjusted to the new Template
language/lang_english/lang_main.php
// That's all, Folks!
// Filter memberslist MOD
$lang['Memberlist_filter'] = 'keyword (wildcards allowed) ';
$lang['Memberlist_filter_sel'] = 'Choose filter: ';
$lang['Click_return_memberlist'] = 'Click %sHere%s to return to the memberlist';
$lang['Memberlist_filter'] = '關鍵字';
$lang['Memberlist_filter_sel'] = '查詢方式:';
$lang['Click_return_memberlist'] = '點選 %s這裡%s 回到會員列表';
memberlist.php
\n//
// Memberlist sorting
// Filter Memberlist MOD - BEGIN
$filter_mode_types_text = array($lang['Sort_Username'], $lang['Sort_Location'], $lang['Sort_Email'],  $lang['Sort_Website'], $lang['Poster_rank']);
$filter_mode_types = array('username', 'location', 'email', 'website', 'rank');
$select_filter_mode = '<select name="filter_mode">';
for($i = 0; $i < count($filter_mode_types_text); $i++)
	$selected = ( $filter_mode == $filter_mode_types[$i] ) ? ' selected="selected"' : '';
	$select_filter_mode .= "<option value=\"" . $filter_mode_types[$i] . "\"$selected>" . $filter_mode_types_text[$i] . "</option>";
$select_filter_mode .= '</select>';
// Filter Memberlist MOD - END
// Generate page
if ( isset($HTTP_POST_VARS['filter']) || isset($HTTP_GET_VARS['filter']) )
	$filter = ( isset($HTTP_POST_VARS['filter']) ) ? $HTTP_POST_VARS['filter'] : $HTTP_GET_VARS['filter'];
	if (empty($filter) )
		$sql_filter = '';
		$username_filter = "*". $filter . "*";
		$username_filter = preg_replace('/\*/', '%', trim(strip_tags($username_filter)));
		if ( isset($HTTP_GET_VARS['filter_mode']) || isset($HTTP_POST_VARS['filter_mode']) )
			$filter_mode = ( isset($HTTP_POST_VARS['filter_mode']) ) ? $HTTP_POST_VARS['filter_mode'] : $HTTP_GET_VARS['filter_mode'];
			switch( $filter_mode )
				case 'username':
					$sql_filter = " AND username LIKE '" . str_replace("\'", "''", $username_filter) . "'";
					break;
				case 'location':
					$sql_filter = " AND user_from LIKE '" . str_replace("\'", "''", $username_filter) . "'";
					break;
				case 'email':
					if ($userdata['user_level'] == ADMIN )
						$sql_filter = " AND user_email LIKE '" . str_replace("\'", "''", $username_filter) . "'";
						$sql_filter = " AND user_viewemail != '0' AND user_email LIKE '" . str_replace("\'", "''", $username_filter) . "'";
					break;
				case 'website':
					$sql_filter = " AND user_website LIKE '" . str_replace("\'", "''", $username_filter) . "'";
					break;
				case 'rank':
					$sql_filter = " AND r.rank_title LIKE '" . str_replace("\'", "''", $username_filter) . "'";
					break;
				default:
					break;
	$sql_filter = '';
	'L_POSTS' => $lang['Posts'],
	'FILTER' => $filter,
	'L_MEMBERLIST_FILTER' => $lang['Memberlist_filter'],
	'L_MEMBERLIST_FILTER_SEL' => $lang['Memberlist_filter_sel'],
	'S_FILTER_SELECT' => $select_filter_mode,
$sql = "SELECT username
, user_allowavatar
, r.rank_title
	FROM " . USERS_TABLE . "
	WHERE user_id <> " . ANONYMOUS . "
	USERS_TABLE . "
 LEFT JOIN " . RANKS_TABLE . " r ON r.rank_id = user_rank
 $sql_filter
	$db->sql_freeresult($result);
	$message = $lang['No_match'] . '<br /><br />' . sprintf($lang['Click_return_memberlist'], '<a href="' . append_sid('memberlist.'.$phpEx) . '">', '</a>' );
		WHERE user_id <> " . ANONYMOUS;
		FROM " . USERS_TABLE . " LEFT JOIN " . RANKS_TABLE . " r
		WHERE user_id <> " . ANONYMOUS . " $sql_filter";
	$pagination = generate_pagination("memberlist.$phpEx?mode=$mode&order=$sort_order", $total_members, $board_config['topics_per_page'], $start). ' ';
	&filter=$filter&filter_mode=$filter_mode
templates/subSilver/memberlist_body.tpl
<form method="post" action="{S_MODE_ACTION}">
  <table width="100%" cellspacing="2" cellpadding="2" border="0" align="center">
	  <td align="left"><span class="nav"><a href="{U_INDEX}" class="nav">{L_INDEX}</a></span></td>
	  <td align="right" nowrap="nowrap"><span class="genmed">{L_SELECT_SORT_METHOD}: {S_MODE_SELECT}  {L_ORDER} {S_ORDER_SELECT}
		<input type="submit" name="submit" value="{L_SUBMIT}" class="liteoption" />
		</span></td>
  </table>
		<td align="right" nowrap="nowrap" colspan="2"><span class="genmed">{L_SELECT_SORT_METHOD}: {S_MODE_SELECT}  {L_ORDER} {S_ORDER_SELECT}  </span></td>
		<td align="left" valign="bottom"><span class="nav"><a href="{U_INDEX}" class="nav">{L_INDEX}</a></span></td>
		<td align="right" nowrap="nowrap"><span class="genmed">{L_MEMBERLIST_FILTER_SEL} {S_FILTER_SELECT} {L_MEMBERLIST_FILTER}<input type="text" style="width: 150px" name="filter" class="post" size="28" value="{FILTER}" />
		</span></td>
	</form>
  </table>
</table></form>
</table>
# EoM
問題外掛:(例:快速回覆)
參考連結:(連結至外掛發表區的主題)
使用版本:(例:phpBB 2.0.2)
網站位置:(例:http://phpbb-tw.net)
(這裡描述您遇到的狀況)
補充:
(若是需要,請列出您曾裝過的外掛名稱)
回到「非官方認證外掛」
