使用版本:phpBB 2.0.21
網站位置: http://www.catswhispering.com/index.php
此外掛安裝完.在文章頁面.會有一排英文.點選英文進入發郵件畫面.
我想改成在文章頁面顯示圖示.點選圖示進入發郵件畫面.
請問該怎麼改....謝謝(正常安裝不用圖示時沒問題)
已參考此篇文章作修改
http://phpbb-tw.net/phpbb/viewtopic.php ... 9%E5%AF%84
但好像還是錯誤.以下是出來的效果
http://www.catswhispering.com/viewtopic.php?t=16
## Hack Title: Email topic to friend
## Hack Version: 1.0.0
## Author: Freakin' Booty ;-P
## Website: http://freakingbooty.no-ip.com
## Description: This hack allows you to send a friend a topic that you think s/he will
## find interesting. You can also use it to notify other members about topics
## while they are away and only want to read specific topics (vacation, ...).
## Starting this version, you can also write a personalised message in the
## email.
## Compatibility: 2.0.4 and later
## Installation Level: Easy
## Installation Time: 5 minutes
## Files To Edit: 4
## viewtopic.php
## includes/constants.php
## language/lang_english/lang_main.php
## template/subSilver/viewtopic_body.tpl
## Included Files: 4
## db_update.php
## emailtopic.php
## language/lang_english/email/email_topic.tpl
## templates/subSilver/email_topic_body.tpl
## History:
## 1.0.1 Fixed a minor bug where the emailed link to the topic was not correct
## 1.0.0 Updated to work with older versions of phpBB.
## Added the much wanted comments field.
## 0.2 Fixed a little bug, where the idrinkbox (another mod of me) function was
## called from the php page.
## 0.1 Initial release
## Author Notes:
## Ah, my first release after I have been off for I don't know how long, but too long it
## was. I hope I can keep it going again from now on.
## Support: http://www.phpbbhacks.com/forums
## Copyright: ?004 Email topic to friend 1.0.0 - Freakin' Booty ;-P
## You downloaded this hack from phpBBHacks.com, the #1 source for phpBB related downloads.
## Please visit http://www.phpbbhacks.com/forums for support.
## This hack is released under the GPL License.
## This hack can be freely used, but not distributed, without permission.
## Intellectual Property is retained by the hack author(s) listed above.
#-----[ COPY ]--------------------------------------------
# This file updates the database. Run it once by typing in its URL in your browser.
# Delete it _immediately_ after all database alterations are successfull.
db_update.php => db_update.php
# Copy or create a language file for every language you have installed
# Copy or create a template file for every template you have installed
emailtopic.php => emailtopic.php
language/lang_english/email/email_topic.tpl => language/lang_english/email/email_topic.tpl
templates/subSilver/email_topic_body.tpl => templates/subSilver/email_topic_body.tpl
#-----[ OPEN ]--------------------------------------------
viewtopic.php
#-----[ FIND ]--------------------------------------------
// If we've got a hightlight set pass it on to pagination,
// I get annoyed when I lose my highlight after the first page.
#-----[ BEFORE, ADD ]-------------------------------------
// Add Email topic to friend
$s_email_topic = '';
if($userdata['session_logged_in'])
$action = ($post_id) ? POST_POST_URL . "=$post_id" : POST_TOPIC_URL . "=$topic_id&start=$start";
$s_email_topic = '<a href="' . append_sid("emailtopic.$phpEx?$action") . '">' . $lang['Email_topic'] . '</a>';
'S_WATCH_TOPIC' => $s_watching_topic,
'S_EMAIL_TOPIC' => $s_email_topic,
define('TOPICS_TABLE', $table_prefix.'topics');
#-----[ AFTER, ADD ]--------------------------------------
define('TOPICS_EMAIL_TABLE', $table_prefix.'topics_email');
# Edit this file for every language you have installed
// That's all, Folks!
// Email topic to friend
$lang['Email_topic'] = 'Email topic to a friend';
$lang['Email_topic_settings'] = 'Email topic information';
$lang['Friend_name'] = "Friend's name";
$lang['Friend_email'] = "Friend's email";
$lang['Message'] = 'Message';
$lang['Message_explain'] = 'The message can only contain 255 characters. HTML is not allowed.';
$lang['Email_max_exceeded'] = 'Sorry, but you have already sent %d emails in the past %d hours';
$lang['No_friend_specified'] = "You have not specified your friend's name or email address";
$lang['Friend_name_too_long'] = 'The name you specified is too long.';
$lang['Friend_email_too_long'] = 'The email address you specified is too long.';
$lang['Message_too_long'] = 'The message you entered is too long.';
# Edit this file for every template you have installed
{S_WATCH_TOPIC}
<br />{S_EMAIL_TOPIC}
#-----[ SAVE & CLOSE ALL FILES ]--------------------------
