重新修改簡易子版面1.3版中的說明 Admin\admin_forums.php 的其中一段
若您安裝過的外掛,有更改過admin/admin_forums.php的內容
在admin/admin_forums.php的修改過程中
請注意: 您是否有因為加入其他外掛, 而更動 $sql = "UPDATE " . FORUMS_TABLE . " 後頭的語法
請參考以下修改方式
SET forum_name = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', cat_id = " . intval($HTTP_POST_VARS[POST_CAT_URL]) . ", forum_desc = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', forum_status = " . intval($HTTP_POST_VARS['forumstatus']) . ", prune_enable = " . intval($HTTP_POST_VARS['prune_enable']) . "
WHERE forum_id = " . intval($HTTP_POST_VARS[POST_FORUM_URL]);
#-----[ BEFORE ADD 之前, 加上 ]--------------------------------
# ps. 請注意: 您如果有加入其他外掛, 則自行更動 $sql = "UPDATE " . FORUMS_TABLE . " 後頭的語法!!
//forum_sub start
$forum_set=$HTTP_POST_VARS[POST_CAT_URL];
if(empty($forum_set))
message_die(GENERAL_ERROR, "設定錯誤");
$sql = "select count(forum_sub) as id from " . FORUMS_TABLE . " WHERE forum_sub = " . intval($HTTP_POST_VARS[POST_FORUM_URL]);
$get_sub_Id = $db->sql_fetchrow($result);
if($get_sub_Id[id]>0)
message_die(GENERAL_ERROR, "此版面有其他子版面相連,無法設定成子版面");
$temp=split(",",$forum_set);
$c=intval($temp[0]);
$forum_sub=intval($temp[1]);
$HTTP_POST_VARS['forumname']=str_replace("<","",$HTTP_POST_VARS['forumname']);
$HTTP_POST_VARS['forumdesc']=str_replace("<","",$HTTP_POST_VARS['forumdesc']);
if(intval($HTTP_POST_VARS[POST_FORUM_URL])== $forum_sub)
$sort_sub=intval($temp[2]);
SET forum_name = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', forum_desc = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', forum_status = " . intval($HTTP_POST_VARS['forumstatus']) . ", prune_enable = " . intval($HTTP_POST_VARS['prune_enable']) . "
}else
if(intval($temp[1])>0)
$sort_sub=intval($temp[2])+1;
}else
$main_sub=intval($temp[3]);
#-----[ AFTER, ADD 之後, 加上 ]---------------------------------
message_die(GENERAL_ERROR, "Couldn't update forum information", "", __LINE__, __FILE__, $sql);
//forum_sub end
#-----[ IN LINE FIND 繼續在這一行尋找 ]------------------------
#-----[ REPLACE WITH 替換 ]-----------------------------------
$c
#-----[ IN LINE AFTER, ADD 在指定之後, 加上 ]----------------
,forum_sub=".$forum_sub.",sort_sub=".$sort_sub.",main_sub=".$main_sub."
再改成UTF-8後已經正常...
