## MOD Title: Meeting
## MOD Author: OXPUS < webmaster@oxpus.de > (Karsten Ude) http://www.oxpus.de
## MOD Description: Implement a meeting managemant for example to initiate a board meeting with your users
## MOD Version: 1.3.7
## Installation Level: Easy
## Installation Time: 5-10 Minutes
## Files To Edit: 8
## admin/index.php
## includes/constants.php
## includes/page_header.php
## language/lang_english/lang_admin.php
## language/lang_german/lang_admin.php
## common.php
## viewonline.php
## templates/subSilver/overall_header.tpl
## Included Files: 11
## admin/admin_meeting.php
## language/lang_english/lang_meeting.php
## language/lang_german/lang_meeting.php
## templates/subSilver/meeting_comment_body.tpl
## templates/subSilver/meeting_detail_body.tpl
## templates/subSilver/meeting_edit_body.tpl
## templates/subSilver/meeting_viewlist_body.tpl
## templates/subSilver/admin/meeting_config_body.tpl
## templates/subSilver/admin/meeting_manage_body.tpl
## meeting.php
## meeting_manage.php
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
## MOD History:
## 2006-03-17 - Version 1.3.7
## - ADD Enable BBCode, Smilies and HTML for Meeting Description
## - ADD Enable BBCode, Smilies and HTML for Meeting Comments
## - DELETE templates/.../admin/meeting_edit_body.tpl.
## For update look into the folder updates
## 2006-02-04 - Version 1.3.6
## - ADD Permissions for creating meetings by user
## - ADD Enable/Disable Email Notify on Sign on/off / change promise to board adress and/or meeting owner
## 2006-01-10 - Version 1.3.5
## - FIX Quoting on several fields
## For update just replace the files meeting_manage.php and admin/admin_meeting.php
## 2006-01-10 - Version 1.3.4
## - FIX Timezone for edit via ACP
## - FIX Datebase update script (missing sql-statements)
## For update just replace the file admin/admin_meeting.php
## 2006-01-05 - Version 1.3.3
## - ADD Allow Users to delete their own meetings
## - ADD Allow Users to delete their own meeting comments
## 2006-01-04 - Version 1.3.2
## - FIX Several bugs on comments
## For update replace the files meeting.php and templates/subSilver/meeting_detail_body.tpl
## 2006-01-03 - Version 1.3.1
## - FIX Time issue on display Meeting Details
## - FIX Editing Meeting By User
## For update replace the files meeting.php and meeting_manage.php
## 2005-12-30 - Version 1.3.0
## - ADD Multiple Comments per User
## 2005-07-12 - Version 1.2.1
## - FIX table errors on template files
## For update look replace all .tpl-Files from this package
## 2005-07-04 - Version 1.2.0
## - ADD Editing meeting by meeting founder and (if set in ACP) by each user
## - ADD Enter meeting list with query for active meetings (the list may be empty at startup!)
## - ADD Setting start value and intervall for assign drop down for each meeting
## 2005-06-06 - Version 1.1.3
## - FIX User access for enter and edit meeting
## 2005-04-13 - Version 1.1.2
## - FIX Meeting update bug on ACP modul..
## 2005-04-06 - Version 1.1.1
## - FIX Displaying link for entering new meeting by users if no meeting exists.
## For update just replace the file meeting.php
## 2005-04-05 - Version 1.1.0
## - ADD Users can add/edit meetings. The admin can enable/disable this options.
## - ADD Usernames which have created and last edited the meetings
## For update look into the folder updates!
## 2005-04-01 - Version 1.0.8
## - FIX summertime issue while submitting a meeting
## For update replace the file admin/admin_meeting.php
## 2005-03-06 - Version 1.0.7
## - FIX counting and permissions on meetings
## For update replace the file meeting.php and reinstall the part for includes/page_header.php
## 2005-01-21 - Version 1.0.6
## - FIX timeformat on saving meeting
## For update just replace the files meeting.php and admin/admin_meeting.php
## 2005-01-10 - Version 1.0.5
## - ADD number of joined users on meeting list
## For update just replace the files meeting.php and meeting_viewlist_body.tpl
## 2004-10-17 - Version 1.0.4
## - Fix link integration in board navigation
## 2004-08-06 - Version 1.0.3
## - Fix quote in meeting comments
## For update replace meeting.php
## 2004-07-25 - Version 1.0.2
## - Fix statictic on meeting detail
## - Fix delete comments on drop meeting
## For update replace admin/admin_meeting.php and meeting.php
## 2004-07-22 - Version 1.0.1
## - Fix some layout errors.
## For update replace all files comming with this mod.
## 2004-07-12 - Version 1.0.0
## - First release
CREATE TABLE phpbb_meeting_comment (
comment_id MEDIUMINT(8) AUTO_INCREMENT,
meeting_id MEDIUMINT(8) unsigned NOT NULL,
user_id MEDIUMINT(8) DEFAULT '0' NOT NULL,
meeting_comment TEXT NOT NULL,
meeting_edit_time INT(11) DEFAULT '0' NOT NULL,
bbcode_uid varchar(10) NOT NULL DEFAULT '',
PRIMARY KEY (comment_id));
CREATE TABLE phpbb_meeting_data (
meeting_time INT(11) DEFAULT '0' NOT NULL,
meeting_until INT(11) DEFAULT '0' NOT NULL,
meeting_location VARCHAR(255) NOT NULL,
meeting_subject VARCHAR(255) NOT NULL,
meeting_desc TEXT NOT NULL,
meeting_link VARCHAR(255) NOT NULL,
meeting_places MEDIUMINT(8) DEFAULT '0' NOT NULL,
meeting_by_user MEDIUMINT(8) DEFAULT '0' NOT NULL,
meeting_edit_by_user MEDIUMINT(8) DEFAULT '0' NOT NULL,
meeting_start_value MEDIUMINT(8) DEFAULT '0' NOT NULL,
meeting_recure_value MEDIUMINT(8) DEFAULT '5' NOT NULL,
meeting_notify tinyint(1) NOT NULL DEFAULT '0',
PRIMARY KEY (meeting_id));
CREATE TABLE phpbb_meeting_user (
meeting_sure TINYINT(4) DEFAULT '0' NOT NULL);
CREATE TABLE phpbb_meeting_usergroup (
meeting_group MEDIUMINT(8) NOT NULL);
CREATE TABLE phpbb_meeting_config (
config_name VARCHAR(255) NOT NULL DEFAULT '',
config_value VARCHAR(255) NOT NULL DEFAULT '',
PRIMARY KEY (config_name)
INSERT INTO phpbb_meeting_config (config_name, config_value) VALUES ('allow_user_enter_meeting', '0');
INSERT INTO phpbb_meeting_config (config_name, config_value) VALUES ('allow_user_edit_meeting', '0');
INSERT INTO phpbb_meeting_config (config_name, config_value) VALUES ('allow_user_delete_meeting', '0');
INSERT INTO phpbb_meeting_config (config_name, config_value) VALUES ('allow_user_delete_meeting_comments', '0');
INSERT INTO phpbb_meeting_config (config_name, config_value) VALUES ('create_meeting', '1');
INSERT INTO phpbb_meeting_config (config_name, config_value) VALUES ('meeting_notify', '1');
UPDATE phpbb_meeting_data SET meeting_by_user = 2, meeting_edit_by_user = 2;
ALTER TABLE phpbb_groups ADD COLUMN allow_create_meeting TINYINT(1) DEFAULT '0' NOT NULL;
copy admin/admin_meeting.php to admin/admin_meeting.php
copy language/lang_english/lang_meeting.php to language/lang_english/lang_meeting.php
copy language/lang_german/lang_meeting.php to language/lang_german/lang_meeting.php
copy templates/subSilver/meeting_comment_body.tpl to templates/subSilver/meeting_comment_body.tpl
copy templates/subSilver/meeting_detail_body.tpl to templates/subSilver/meeting_detail_body.tpl
copy templates/subSilver/meeting_edit_body.tpl to templates/subSilver/meeting_edit_body.tpl
copy templates/subSilver/meeting_viewlist_body.tpl to templates/subSilver/meeting_viewlist_body.tpl
copy templates/subSilver/admin/meeting_config_body.tpl to templates/subSilver/admin/meeting_config_body.tpl
copy templates/subSilver/admin/meeting_manage_body.tpl to templates/subSilver/admin/meeting_manage_body.tpl
copy meeting.php to meeting.php
copy meeting_manage.php to meeting_manage.php跟職業的統計
我在phpbb_meeting_data加了meeting_dru&meeting_rog
phpbb_meeting_user加了user_class
我的想法是選了一個職業後user_class(紀錄該用戶選擇的職業)
如選擇了DRU
則meeting_dru值+1
請問在PHP裡我該如寫
還有設定的時間跟設定後的時間差了13小時...
請問有人知道哪邊有問題嗎?
MOD原始載點
http://www.phpbbhacks.com/download/3343
