[外掛] Show Search Bot
bc010843
文章: 333
註冊時間: 2004-10-13 18:33
文章 bc010843 »
外掛連結
問題:
小弟找不到下面這段語法
includes/bbcode.php
      if ( $row['session_ip'] != $prev_ip )
         $username = $lang['Guest'];
phpbb 2.0.18
os linux
style icg
快速程式 無\r
PHPBB:2.0.20
OS:LINUX
風格: ICG
快速程式:無
上網方式:Hinet 8m/640
架設環境:竹貓空間
bc010843
文章: 333
文章 bc010843 »
另外有英文好的人嗎?有些字翻不太順
<?php
 *                             lang_bot_admin.php
 *   begin                : Sunday, February 13, 2005
 *   copyright            : (C) 2004 Adam Marcus
 *   email                : adam_marcus@btinternet.com
$lang['Manage_Bots'] = "Manage Bots";
$lang['Bot_Explain'] = "Bots (also known as crawlers) are automated agents most commonly used to index information on the internet. Very few of these bots support sessions and can therefore fail to index your site correctly. Here you can define the assigning of session ids to these bots to solve this problem.";
$lang['Pending_Bots'] = "Pending Bots";
$lang['Pending_Explain'] = "Listed below are users that matched some but not all of your bot criteria. In other words the user only matched either the user agent or ip. The mismatched data is the highlighted next to the bot name. You can choose to either add this info which will then appear as part of that bots criteria or ignore it.";
$lang['Bot_Agent'] = "Bot agent";
$lang['Bot_Name'] = "漫遊器名稱";
$lang['Bots'] = "bots";
$lang['Agent_Match'] = "Agent match";
$lang['Bot_Ip'] = "Bot IP";
$lang['Bot_Style'] = "Bot style";
\n$lang['Last_Visit'] = "最後來訪";
$lang['Visits'] = "次數";
$lang['Pages'] = "頁數";
$lang['Never'] = "無";
$lang['Options'] = "?#93;定";
$lang['Result'] = "Result";
$lang['Ok'] = "Ok";
$lang['Mark'] = "Mark";
$lang['Ignore'] = "Ignore";
$lang['Add'] = "Add";
$lang['Submit'] = "Submit";
$lang['Delete'] = "Delete";
$lang['Reset'] = "Reset";
$lang['Edit'] = "Edit";
$lang['ip'] = "ip";
$lang['agent'] = "agent";
$lang['No_Bots'] = "Sorry there are currently no bots in the database!";
$lang['No_Pending_Bots'] = "Sorry there are currently no pending bots in the database!";
$lang['Bot_Added_Or_Modified'] = "Bot information successfully added/ignored.";
$lang['Bot_Result_Explain'] = "Here you can see the result of your query.";
$lang['Bot_Settings_Changed'] = "Bot settings successfully modified/added.";
$lang['Bot_Edit_Or_Add_Explain'] = "Here you can either add or modify an existing bot entry. You are able to supply either a matching user agent or a range of ip's to use.";
$lang['Bot_Name_Explain'] = "Used for your use only.";
$lang['Bot_Agent_Explain'] = "A matching user agent. Partial matches are allowed. Seperate agents with a single '|'.";
$lang['Bot_Ip_Explain'] = "Partial matches are allowed. Seperate IP addresses with a single '|'.";
$lang['Bot_Style_Explain'] = "Style bot sees when visiting your site.";
$lang['Error_No_Agent_Or_Ip'] = "You have no supplied a vaild user agent or ip.";
$lang['Error_No_Bot_Name'] = "You have not supplied a bot name.";
PHPBB:2.0.20
OS:LINUX
風格: ICG
快速程式:無
上網方式:Hinet 8m/640
架設環境:竹貓空間
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
就我所知,這個外掛的問題還相當多,實在不建議你用它
~Mac
bc010843
文章: 333
文章 bc010843 »
請教Mac
您說的問題是指第一篇文章外掛嗎?因為第二篇另一個mod
PHPBB:2.0.20
OS:LINUX
風格: ICG
快速程式:無
上網方式:Hinet 8m/640
架設環境:竹貓空間
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 Mac »
bc010843 寫:請教Mac
就是這篇你說找不到程式的 Show Search Bot
~Mac
文章 依夢兒 »
同性質的外掛,我使用的是這個:
http://www.phpbb.com/phpBB/viewtopic.php?t=328388
感覺還不錯。
