[問題] Forum Information 時間計算錯誤
雪曼
文章: 7
註冊時間: 2005-09-03 12:07
來自: 雪曼星
文章 雪曼 »
問題外掛:Forum Information
參考連結:http://www.phpbb-tw.net/phpbb/viewtopic.php?t=33832
使用版本:2.0.18
網站位置:恕無法提供
如圖:
他的秒數飆到300.... :-o
以前在0.17的時候還OK
但到0.18就會這樣\r
以下為原文:
## MOD Title: Forum Information
## MOD Author: lowjoel <webmaster@joelsplace.sg> Joel Low - http://joelsplace.sg/
## MOD Description: Displays the Number of script queries executed, GZIP
## compression information and page execution time.
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: 3 Minutes
## Files To Edit:  extension.inc,
##                 language/lang_english/lang_main.php,
##                 includes/page_tail.php,
##                 templates/subSilver/overall_footer.tpl
## MOD History:
##     2005-03-17  - Version 1.0.1
##          - Updated installation instructions
##          - Created folder hierachy for easy extraction
##     2005-03-12  - Version 1.0.0
##          - Original release
## Author Notes:
extension.inc
$starttime = 0;
$starttime = time();
// That's all, Folks!
//-------------------------- MOD: Forum Information MOD --------------------------
$lang['L_GZIP_ENABLED'] = 'GZIP: Enabled';
$lang['L_GZIP_DISABLED'] = 'GZIP: Disabled';
$lang['L_GENERATION_TIME'] = 'Generation Time: %s  Seconds';
$lang['L_MYSQL_QUERIES'] = 'Queries: %s';
//-------------------------- End MOD: Forum Information MOD --------------------------
$template->pparse('overall_footer');
//delete
//$template->pparse('overall_footer');
echo "\x1f\x8b\x08\x00\x00\x00\x00\x00";
   echo $gzip_contents;
   echo pack('V', $gzip_crc);
   echo pack('V', $gzip_size);
$endtime = microtime();
$endtime = explode(" ", microtime());
$endtime = $endtime[1] + $endtime[0];
$gentime = round(($endtime - $starttime), 5);
$template->assign_vars(array(
  'L_GENERATION_TIME' => sprintf($lang['L_GENERATION_TIME'], $gentime),
  'L_NUMBER_QUERIES' => sprintf($lang['L_MYSQL_QUERIES'],  $db->num_queries),
  'L_GZIP_ON' =>  ($board_config['gzip_compress']) ? $lang['L_GZIP_ENABLED'] : $lang['L_GZIP_DISABLED'],
{TRANSLATION_INFO}
<br /> {L_GZIP_ON}&nbsp;&nbsp; {L_NUMBER_QUERIES}&nbsp;&nbsp; {L_GENERATION_TIME}
# EoM
竹貓點擊率最高的連結---->
雪曼
文章: 7
來自: 雪曼星
文章 雪曼 »
不好意思
我在http://www.phpbb.com/phpBB/viewtopic.ph ... 05#1685905這篇文章找到了解決方法
在此代貼
extension.inc
$starttime=time();
#-----[ REPLACE WITH ]---------------------------------------------
list($usec, $sec) = explode(" ", microtime());
$starttime= ((float)$usec + (float)$sec);
竹貓點擊率最高的連結---->
過山雲
文章: 390
註冊時間: 2002-09-05 20:11
來自: 東都.承天府.萬年縣治.拱辰門北
文章 過山雲 »
來源已不可考
搜尋沒找到\r
所以補上相關繁體中文語系部分
$lang['L_GZIP_ENABLED'] = 'GZIP壓縮: 啟用';
$lang['L_GZIP_DISABLED'] = 'GZIP壓縮: 沒啟用';
$lang['L_GENERATION_TIME'] = '頁面產生速度: %s 秒';
$lang['L_MYSQL_QUERIES'] = '資料庫查詢: %s 次';
