[心得]虛擬形象2.20 提升執行效能
ETERNAL
文章: 297
註冊時間: 2002-01-23 11:23
[心得]虛擬形象2.20 提升執行效能
文章 ETERNAL »
安裝虛擬形象時
在viewtopic.php裡面有一段\r
				$sql="SELECT * FROM week9_userdata where userid = ".$postrow[$i]['user_id']." and dafaultuse = '1' and (face_fitherd = '$sex' or face_fitherd = 't')";
					message_die(GENERAL_ERROR, 'Could not query week9_userdata', '', __LINE__, __FILE__, $sql);
				while ($usercaifu = $db->sql_fetchrow($result))
					$tempi = $usercaifu[classid];
					$cookiearray[$tempi] = $usercaifu[facepicid];
					$face_weardate = floor($usercaifu[face_wear] - (time() - $usercaifu[buydata])/8640);
					if ($face_weardate <= 0)
						$db->sql_query("UPDATE week9_userdata SET dafaultuse = '3' WHERE userid=".$postrow[$i]['user_id']." and facepicid = '$usercaifu[facepicid]' and classid= '$usercaifu[classid]' and dafaultuse='1'");
						if($usercaifu[classid] == 8||$usercaifu[classid]==9||$usercaifu[classid]==11||$usercaifu[classid]==13||$usercaifu[classid]==14||$usercaifu[classid]==18)
							$userupid = $upid;
							$userupid = "0";
						$weararray[$tempi] = $userupid;
						$weararray[$tempi] = $face_weardate;
				$db->sql_freeresult($result);
這段於法由於是放在顯示主題所回覆內容的迴圈裡面\r
該討論主題內,會員使用的虛擬形象越多,會造成越多的query
改進的方法如下
在檔案內找尋
$postrow = array();
後面加上
$postrow_userid = array();
找尋
		$postrow[] = $row;
後面加上
		$postrow_userid[]=$row['user_id'];
找尋
   sync('topic', $topic_id);
   message_die(GENERAL_MESSAGE, $lang['No_posts_topic']);
後面加上
$sql="SELECT userid,classid,facepicid FROM week9_userdata where userid in (".implode(',',$postrow_userid).") and dafaultuse = '1' order by  userid";
	message_die(GENERAL_ERROR, "Could not query week9_userdata.", '', __LINE__, __FILE__, $sql);
unset($postrow_userid);
$face_user = array();
	$face_user[$row['userid']][]=$row;
找尋
							$userupid = $upid;
							$userupid = "0";
替換成
				for($face_count=0;$face_count<count($face_user[$postrow[$i]['user_id']]);$face_count++)
					$tempi = $face_user[$postrow[$i]['user_id']][$face_count]['classid'];
					$cookiearray[$tempi] = $face_user[$postrow[$i]['user_id']][$face_count]['facepicid'];
				$userface = implode("-", $cookiearray);
#####到此修改結束#####
接著你可能會問下面段跑哪去了
							$userupid = $upid;
							$userupid = "0";
這段式判斷你身上的衣服是否過期
我覺得舊衣櫃這功能很無聊,強迫人換衣服
所以就把這功能拿掉了
若你想把這功能加上去\r
改法也很簡單(但是我沒測試過)
改成
在\r
之後加上
	$face_weardate = floor($face_user[$postrow[$i]['user_id']][$face_count][face_wear] - (time() - $face_user[$postrow[$i]['user_id']][$face_count][buydata])/8640);
						$db->sql_query("UPDATE week9_userdata SET dafaultuse = '3' WHERE userid=".$postrow[$i]['user_id']." and facepicid = '$face_user[$postrow[$i]['user_id']][$face_count][facepicid]' and classid= '$face_user[$postrow[$i]['user_id']][$face_count][classid]' and dafaultuse='1'");
						if($face_user[$postrow[$i]['user_id']][$face_count][classid] == 8||$face_user[$postrow[$i]['user_id']][$face_count][classid]==9||$face_user[$postrow[$i]['user_id']][$face_count][classid]==11||$face_user[$postrow[$i]['user_id']][$face_count][classid]==13||$face_user[$postrow[$i]['user_id']][$face_count][classid]==14||$face_user[$postrow[$i]['user_id']][$face_count][classid]==18)
							$userupid = $upid;
							$userupid = "0";
水色論壇 http://www.et99.net
簡德賢分享
taicomjp
文章: 32
註冊時間: 2004-08-19 00:00
文章 taicomjp »
$userupid = $upid;
$userupid = "0";
加上去之後不能跑
應該沒有貼錯\r
沒加這段可以跑
加了就變空白頁
也就是錯誤頁
