下載後發現有不了解的地方,還請解答!! 內容如下:
## MOD Title: Fading Links
## MOD Author: Unknown (Scotty) <scotty@phpbb2-users.de> www.phpbb2-users.de
## MOD Author, Secondary: AbelaJohnB <abela@phpbb.com> (John B. Abela) http://www.JohnAbela.Com/
## MOD Author, Secondary: Chance <don@w3site.us> (Don E. Blackwell) http://w3sites.us/
## MOD Description: Allows your hyperlinks to change color with mouseover javascript.
## MOD Version: 2.0.2
## Installation Level: Easy
## Installation Time: ~1 Minutes
## Files To Edit:
## templates/subSilver/overall_header.tpl
## Included Files:
## fade.js
## Author Notes:
## There are many versions of the script in this MOD available on the web
## I do not take credit for the core code that creates the various effects
## I've merely added to the script to provide additional features requested by
## various users.
## To install this MOD, just copy the fade.js file to your phpBB templates directory and
## make the necessary modifications (below) to each of your themes.
## MOD History:
## 2004-04-07 - Version 2.0.2
## - Fixed more fade bugs
## - Made changes to MOD template to make it valid
## 2004-04-04 - Version 2.0.0 / 2.0.1
## - Found and fixed minor bug causing some things to fade that shouldn't after submission
## - Tested compatible with phpBB 2.0.8a
## - Tested with EasyMOD alpha 0.0.11a
## - Added cross-browser compatibility for standard fade effect
## - Added multiple classes ability (ie set the fade colors for alternate links)
## - Provided users guide for easy usage
## 2003-08-08 - Version 1.0.2
## - Tested compatible with phpBB 2.0.6
## - Tested compatible with EasyMOD alpha 0.0.10a
## - Color declarations now modular for use with varying styles
## 2003-07-19 - Version 1.0.1
## - Updated For phpBB 2.0.5
## Unknown
## - Initial Release
copy fade.js to templates/fade.js
<!-- END switch_enable_pm_popup -->
<script language="javaScript"> [color=red]←是否需求修改?[/color]
fadeClasses = new Array(""); // Determines which classes get which colors [color=red]←是否需求修改?[/color]
startColors = new Array("{T_BODY_LINK}"); // MouseOut link colors [color=red]←是否需求修改轉換顏色?[/color]
endColors = new Array("{T_BODY_HLINK}"); // MouseOver link color [color=red]←是否需求修改轉換顏色?[/color]
stepIn = 20; // delay when fading in [color=red]←是否需求修改?[/color]
stepOut = 20; // delay when fading out [color=red]←是否需求修改?[/color]
autoFade = true;
sloppyClass = true;
</script>
<script src="templates/chunkstyle/fade.js"></script>
# EoM
