[外掛]那位好心人可以帮我?
jikey
文章: 90
註冊時間: 2003-09-18 00:49
[外掛]那位好心人可以帮我?
文章 jikey »
##   Hack Title:   db_update generator
##   Hack Version:   1.0.2
##   Author:      Freakin' Booty ;-P & Antony Bailey
##   Description:  Creates a form into which you enter your SQL and a db_update.php file is then created. You can
##		   either copy/paste the file, or download it onto your computer.
##   Compatibility:  2.0.6
##   Installation Level: Easy
##   Installation Time: 2 minutes
##   Files To Edit: 1
##      language/lang_english/lang_main.php
##   Included Files: 5
##      db_generator.php
##      admin/admin_db_generator.php
##      language/lang_english/db_generator.tpl
##      templates/subSilver/db_generator_body.tpl
##      templates/subSilver/admin/admin_db_generator.tpl
##	History:
##	0.0.1:	Initial code.
##	0.0.2:	Template fixed up and a few new bits added.
##	0.0.3:	Language variables added to language files, make it easier for translation.
##	0.0.4:	Added the possibility to download the db_update.php file - mainly to add ease-of-use and to prevent
##		people getting "headers already sent" errors. You can now specify your own table prefix - needed if
##		the generator is not on your own server.
##	0.0.5:	Fixed one language variable in the template.
##	0.0.6:	The default table prefix is now added in the field by default.
##	0.0.7:  The default table prefix, is now pulled from your phpBB config.php file, making the utility easier for a user.
##	0.0.8:	Cleaned up the db_update.php template.
##	0.0.8:	Added the admin panel option.
##	0.0.9:	Fixed a little spelling error.
##	0.1.0:	The table prefix is no longer retrieved from your forum, nor are you able to put it in. However,
##		the default prefix in the SQL you enter, will be replaced with an equivalent that enables you to use it
##		on any phpBB, regardless of the table prefix used there.
##		Fixed up the code a little, for it to be more efficient.
##      1.0.0:  Fixed admin bug. And taken to 1.0.0 for release. Change copyright link to sourceforge.net
##      1.0.1:  Updated RapidDr3am.SlackSlash.net to RapidDr3am.net
##      1.0.2:  Fixed a parse error my mistake thanks Kipper. ;)
##   Author Notes:
##      Notes.
##   Support:      http://www.phpbbsupport.co.uk
##   Copyright:      ?003 db_update generator 1.0.2 - Freakin' Booty ;-P & Antony Bailey
##   You downloaded this hack from phpBBSupport.co.uk, as such this is not a official phpBB hack.
##   This means that support can not be found for this at phpBB.com, so please visit http://www.phpbbsupport.co.uk
那位好心人可以帮我翻译这一小段。
// db_update generator
$lang['Db_update_generator'] = 'db_update generator';
$lang['Instructions'] = 'Instructions';
$lang['SQL_instructions'] = 'This piece of software will create PHP files that will allow you to update your database using your browser. There are a few things you must look after when you insert an SQL in the box below.<br />First of all, make sure that every SQL query is ending with a semicolon (;). If not, the file created will be faulty. Next, ensure that the tables have the "phpbb_" prefix. This will automatically be replaced with a little piece of code that enabled you to use the db_update.php file on any forum regardless of what the table prefix is set to.';
$lang['Enter_SQL'] = 'Enter SQL';
$lang['Enter_SQL_explain'] = 'MySQL is the world\'s most popular open source database, recognized for its speed and reliability.';
$lang['Output_SQL'] = 'SQL Output';
$lang['Output_SQL_explain'] = 'Copy and paste the text from the textarea on the right into a blank file. Save the file as <u>db_update.php</u> and upload it to your server. Run it once by accessing with your browser.<br /><br />Alternatively, click the download button to download the file directly to your computer (recommended).';
$lang['Download'] = 'Download';
谢谢~~~感恩~~~
寒冰軒
文章: 417
註冊時間: 2003-11-06 23:24
來自: 阿婆A灶腳
Re: [外掛]那位好心人可以帮我?
文章 寒冰軒 »
jikey 寫:
那位好心人可以帮我翻译这一小段。
谢谢~~~感恩~~~
這段應該是加到*php檔中的程式碼\r
安裝說明文件應該都有寫到\r
要安裝在那兒吧
~§ 架站系統:WindowsXP §~
~§ 架站程式:Appserv2.4.4a §~
~§ 使用網路:giga ADSL §~
~§ 論壇版本: 2.0.18 §~
申明檔
3.還是想不通嗎? 那可以到地下十八樓找你的答案。
