[問題]CashMod & Profile Control
ym
文章: 33
註冊時間: 2003-07-17 18:31
文章 ym »
CashMod & Profile Control Panel
原先的Cashmod管理員可在個人資料中增加會員金錢,但裝了Profile Control Panel 後因用了他的 Template 就沒有了顯視,想請問有大大曾修改嗎?
應將 以下profile_view_body.tpl 中的 code應轉放方在那裏!
templates/subSilver/profile_view_body.tpl
		  <td> <b><span class="gen">{INTERESTS}</span></b></td>
		<!-- BEGIN cashrow -->
		  <td valign="middle" align="right" nowrap="nowrap"><span class="gen">{cashrow.CASH_NAME}:</span></td>
		  <td><table border=0><tr><td width="50"><span class="gen"><b>{cashrow.CASH_AMOUNT}</b></span></td>
		<!-- BEGIN switch_donatedisplay -->
		<form style="{display: inline;}" action="{cashrow.S_DONATE_ACTION}" method="post"><td><span class="gen"><input type="submit" value="{cashrow.L_DONATE}" class="liteoption" /> <input type="hidden" name="member_donate" value="1" /><input type="hidden" name="cash_type" value="{cashrow.CASH_TYPE}" /><input name="donate_amount" value="0" size="5" class="post" /> / </span></td><td width="50"><span class="gen"><b>{cashrow.DONATER_CASH}</b></span></td></form>
		<!-- END switch_donatedisplay -->
		<!-- BEGIN switch_admindisplay -->
		<form style="{display: inline;}" action="{cashrow.S_ADMIN_ACTION}" method="post"><td><span class="gen"><input type="submit" value="{cashrow.L_ADD_CASH}" class="liteoption" /> <input type="hidden" name="admin_donate" value="1" /><input type="hidden" name="cash_type" value="{cashrow.CASH_TYPE}" /><input name="admin_amount" value="0" size="5" class="post" /></span></td></form>
		<!-- END switch_admindisplay -->
		  </tr></table></td>
		<!-- END cashrow -->
		<!-- BEGIN switch_exchangeon -->
		  <td valign="top" align="right" nowrap="nowrap"><span class="gen"></span></td>
		  <form style="{display: inline;}" action="{U_EXCHANGE}" method="post"><td><input type="submit" value="{L_EXCHANGE}" class="liteoption" /></td></form>
		<!-- END switch_exchangeon -->
Profile Control Panel 和 CashMod 的工能很好用,想信有很多朋友也會安裝的,
煩請熱心的大大想想辦法,我試過了但做不到
Pooh2003
文章: 13
註冊時間: 2003-06-05 12:26
來自: Macau
文章 Pooh2003 »
我都有這個問題~
.::藍色的天空::.
文章: 587
註冊時間: 2003-09-14 17:29
來自: 我不知道
Re: [問題]CashMod & Profile Control
文章 .::藍色的天空::. »
ym 寫:CashMod & Profile Control Panel
		  </tr></table></td>
到後台的 Fields definition 改吧。
i-Web System 隨坊出來耶
新聞:
遊戲區開幕啦! 打造隨城最強的遊戲王國!
宣傳車出動! 賣力宣傳隨坊吧!
版主召募!版主魂激發!
中文好好學,不要方言通天飛
i-Web System 正式版上架測試!
sisomy
文章: 39
註冊時間: 2002-09-11 22:19
文章 sisomy »
請問後台要怎麼在Fields definition增加cash mod的東西
我有user_points和user_money
應該是需要增加兩個
但是不知道是不是哪裡加錯\r
老是出不來
可否教導一下應該怎麼加入^^||
