[水怪RPG複雜化委員會]天空鬥技場興建計劃啟動
spythomas
文章: 16
註冊時間: 2003-10-25 11:59
文章 由 spythomas »
想問一下...
如果我要替一個職業加一個技能\r
而該技能是要在施展後加某一屬性兩/三個回合...
那可以達成嗎?
請各位大大教教我~謝謝
and4amy
文章: 40
註冊時間: 2004-06-17 23:39
文章 由 and4amy »
ilove1291 寫:[php]<?php
function UserIsDead($wsql, $wsql2, $uid, $uname, $ulv, $deadtype, $is_npc = false)
global $db;
$ret_msg = '';
if ( $is_npc )
$sql = "select count(*) as dead_count, sum(rpg_level) as dead_level, sum(rpg_max_hp) as dead_money from phpbb_rpg_npc where rpg_cur_hp <= 0 and $wsql";
if ( $row['dead_count'] > 0 )
$sql = "select npc_id from phpbb_rpg_npc where rpg_cur_hp <= 0 and $wsql";
if ( $row2 = $db->sql_fetchrow($result) )
$ret_msg = ' 擊敗: ';
do
$ret_msg .= ($row2['npc_name'] == '' ? '' . $row2['npc_id'] : $row2['npc_name']) . ' ';
while ( $row2 = $db->sql_fetchrow($result) );
$ret_msg .= "關鍵一擊: $deadtype ";
//掉寶率
// $sql = "select count(*) as item_count from phpbb_rpg_items where in_which_store <= 2 and need_level <= $ulv";
// $result = $db->sql_query($sql);
// $row2 = $db->sql_fetchrow($result);
// $item_count = $row2['item_count'] - 1;
// srand((double)microtime()*1000000);
// for ($i = 1; $i <= $row['dead_count']; $i++)
// $sql = "select item_id, item_name from phpbb_rpg_items where in_which_store <= 2 and need_level <= $ulv order by item_id limit " . rand(0, $item_count) . " , 1";
$change = rand(1, 100) ;
$sql = "select count(*) as item_count from phpbb_rpg_items where need_level <= $ulv and item_change >= $change";
$sql = "select item_id, item_name, in_which_store from phpbb_rpg_items where and need_level <= $ulv and item_change >= $change order by item_id limit " . rand(0, $item_count) . " , 1";
switch ($row2['in_which_store']) {
case '0' :
$ret_msg .= "並獲得道具:" . $row2['item_name'] . ' ';
break;
case '1' :
$ret_msg .= "並獲得武器:" . $row2['item_name'] . ' ';
break;
case '2' :
$ret_msg .= "並獲得盔甲:" . $row2['item_name'] . ' ';
break;
case '3' :
$ret_msg .= "並意外領悟:" . $row2['item_name'] . ' ';
break;
case '4' :
$ret_msg .= "並獲得頭飾:" . $row2['item_name'] . ' ';
break;
case '5' :
$ret_msg .= "並獲得足具:" . $row2['item_name'] . ' ';
break;
case '6' :
$ret_msg .= "並獲得披風:" . $row2['item_name'] . ' ';
break;
case '7' :
$ret_msg .= "並獲得盾牌:" . $row2['item_name'] . ' ';
break;
case '8' :
$ret_msg .= "並獲得魔書:" . $row2['item_name'] . ' ';
break;
case '9' :
$ret_msg .= "並獲得飾品:" . $row2['item_name'] . ' ';
break;
$sql = "insert into phpbb_rpg_owns (user_id, item_id) values ($uid, " . $row2['item_id'] . ")";
//掉寶率
}[/color]
都沒出現哩QQ 老師救命
請問上面紅色的部分如果想改為讓他判讀的是rpg_level要如何加進去呢?
我有試著直接改為where need_level <= rpg_level 可是這樣他好像不會判讀
請各位大大教導一下,謝謝
另外,如果想在這段多加進職業的考量,又該如何加進去呢?
謝謝幫忙
夜楓
文章: 131
註冊時間: 2003-05-16 21:19
文章 由 夜楓 »
水怪複雜化委員會
http://www.kuloo.com/phpBB2
怎麼變成色情網站了XD
●架設主機作業系統:Windows XP SP2
●快速架站程式:appserv2.4.4a
●您的上網方式:Hinet 12M/1M
●phpBB2 版本:phpBB 2.0.20
mantohu
文章: 66
註冊時間: 2004-11-30 17:49
來自: 新竹市大學路1001號
文章 由 mantohu »
夜楓 寫:水怪複雜化委員會
怎麼變成色情網站了XD
沒錯 .... = =
是淪陷成風化場所了喔...(死)
ilove1291
文章: 171
註冊時間: 2003-04-19 22:44
文章 由 ilove1291 »
好久沒看到這篇文章了耶@@
水怪rpg複雜化委員會因為出入分子太複雜了 所以變成色情網站了 :-?
下次來搞水怪adr委員會好了 (要連長準放假) ;-)
bu
文章: 443
註冊時間: 2003-02-23 12:46
來自: 25° 4′N 121° 29′E
文章 由 bu »
kuloo.com 已經失守
被色站用去了
*譯文資料在phpBB 技術文件
*bu.femto-size
*和我聯絡,請寄 or Google Talk 圖檔
mantohu
文章: 66
來自: 新竹市大學路1001號
文章 由 mantohu »
請問有人有之前http://www.kuloo.com/phpBB2/
裡面的教學文章或檔案嗎...
Orz 跪求 ~~
bu
文章: 443
文章 由 bu »
找找看 imOrz.com 的站長吧 ^^"
他就是以前 kuloo.com 的站長
*譯文資料在phpBB 技術文件
*bu.femto-size
mantohu
文章: 66
來自: 新竹市大學路1001號
文章 由 mantohu »
ilove1291 寫:做好取代掉 images/eol/npc/ 裡面的圖就好嚕
請問我抓了之後 存成gif 檔, 但是因為是抓下來的 會有預設背景白色\r
造成跑rpg的時候看不到 人物後背景\r
請問一下該如何解決呢 QQ
換個方法問 要麼把jpg 圖轉成去背景的gif呢 QQ (我是用photoimpact 10)
DL
文章: 717
註冊時間: 2005-03-05 15:29
文章 由 DL »
有什麼已實際弄了出來可以安裝的嗎?
kevinant
文章: 9
註冊時間: 2003-07-19 09:18
文章 由 kevinant »
水怪 Discuz 版::加上了控制台(把程式寫活了),沒做phpbb的
http://202.181.134.28/~nico/music/test/rpg.zip
請大家幫忙澈是吧 (還不是正式版)....
不知道委員會飛哪了/........不過歡迎到bbs.04gd.com成立新的委員會
DL
文章: 717
文章 由 DL »
換成phpbb的死對頭?不要命了?:-P
還有喔...請問你得到了所有原作者同意了嗎?
StickyKid
文章: 1019
註冊時間: 2003-01-31 10:32
來自: Taichung, Taiwan
文章 由 StickyKid »
洨?葉子™© !GOLDEN BALL 說:
PAIKANG呀
[gnakiap]鍛練心臟強度... 說:
竹貓有人把水怪RPG改成Discuz版的呢\r
XD
然後又有人提到此問題 說要問問原作者
沒關係啊
恩~
PAIKANG說沒問題就沒問題囉 :mrgreen:
DL
文章: 717
文章 由 DL »
原來是這樣...
可為什麼貼這個東東在竹貓?
kevinant
文章: 9
文章 由 kevinant »
DL 寫:換成phpbb的死對頭?不要命了?:-P
Because I wanted to make game more complicate than it is.
And Discuz Forum is also better environment to develop MODs
I used PHPBB before, but to tell u the truth It has too much bugs/holes which i can exploit and coulodbe easily hacked ( don't want to reveal them) . That's why I switched to Discuz. Discuz is much more safer forum to use.
