[問題]attach mod 2.4.3 上傳的檔案無法在帖子裡顯示... (以解決~)
魚肝油 寫:
心靈捕手 寫:2. 補充說明, 該 '子分區' 外掛的版本, 名稱以及參考 (下載) 連結
那ㄍ子分區是我好久前下載ㄉ,連結已經不記得是哪一篇ㄌ,我是否可直接將她壓縮傳上來?對那外掛ㄉ作者是否不好?
我先把我已知ㄉ部分告訴您:
檔頭 寫:Title: Attached forums or pseudo sub-forums MOD
Author: niekas <> () http://www.freedomlist.com
Version: 1.0.6 (beta)
這支外掛, 竹貓有人發表過.
http://phpbb-tw.net/phpbb/viewtopic.php?t=38688
不過, 個人不建議安裝此外掛.
因為在官方 phpbb 討論區, 該主題已經被鎖定.
http://www.phpbb.com/phpBB/viewtopic.ph ... 37#1868937
反解此外掛的所有修改程序.
魚肝油
文章: 23
註冊時間: 2006-05-21 16:08
來自: 中華民國~
文章 魚肝油 »
呼~問題終於解決ㄌ..,雖然沒有移除子分區,但還是找到毛病ㄌ,.......與子分區好像沒有關西....
問題與先前提到ㄉ那兩ㄍ檔案無關,而是"functions_post.php"搞ㄉ鬼...之前安裝一ㄍ叫"Redirect_User_Fix 1.0.0"ㄉ外掛,望ㄌ是幹嘛用ㄉ..,用virtul pcㄉ測試論壇一ㄍ一ㄍ安裝,安裝到那ㄍ外掛時附加檔案就不能顯示ㄌ...但是先前發ㄉ帖子還使可以...新發ㄉ就不行,而且我還發現用"預覽"可以顯示出來....就想應該是"post.php"出問題,一時心急沒有想到是"functions_post.php"搞ㄉ鬼...
移除修改部分運作就正常ㄌ..! 感謝兩位大大ㄉ幫忙~thx~
外掛 寫:
## MOD Title:  Redirect User Fix 1.0.0
## MOD Author: Solo Forever < solarent@excite.com > (N/As) http://foreversilent.net
## MOD Author, Secondary: Mav < mav@universalspider.com > (N/As) N/As
## MOD Description:
##			redirect users directly to their message after making a new post, instead of the "Click here to view your message, here for Forum index" message screen.
## MOD Version:		1.0.0
## Installation Level:	Easy
## Installation Time:	1 Minutes
## Files To Edit:
##			includes/functions_post.php
## Included Files:
##			no files included but the mod and it's file within it.
## Author Notes:
##      - We will try our best to give the support if errors should arise.
##      - this MOD can be installed with EasyMOD verion 1.0.13
## MOD History:
##   2005-02-01 - Version 0.1
#-----[ OPEN ]------------------------------------------------
$meta = '<meta http-equiv="refresh" content="1;url=' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=" . $post_id) . '#' . $post_id . '">';
$message = $lang['Stored'] . '<br /><br />' . sprintf($lang['Click_view_message'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=" . $post_id) . '#' . $post_id . '">', '</a>') . '<br /><br />' . sprintf($lang['Click_return_forum'], '<a href="' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id") . '">', '</a>');
#-----[ REPLACE WITH ]----------------------------------------
// $meta = '<meta http-equiv="refresh" content="1;url=' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=" . $post_id) . '#' . $post_id . '">';
// $message = $lang['Stored'] . '<br /><br />' . sprintf($lang['Click_view_message'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=" . $post_id) . '#' . $post_id . '">', '</a>') . '<br /><br />' . sprintf($lang['Click_return_forum'], '<a href="' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id") . '">', '</a>');
if ( $mode != 'editpost' )
$user_id = ( $mode == 'reply' || $mode == 'newtopic' ) ? $userdata['user_id'] : $post_data['poster_id'];
update_post_stats($mode, $post_data, $forum_id, $topic_id, $post_id, $user_id);
if ($error_msg == '' && $mode != 'poll_delete')
user_notification($mode, $post_data, $post_info['topic_title'], $forum_id, $topic_id, $post_id, $notify_user);
if ( $mode == 'newtopic' || $mode == 'reply' )
$tracking_topics = ( !empty($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) : array();
$tracking_forums = ( !empty($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) : array();
if ( count($tracking_topics) + count($tracking_forums) == 100 && empty($tracking_topics[$topic_id]) )
asort($tracking_topics);
unset($tracking_topics[key($tracking_topics)]);
$tracking_topics[$topic_id] = time();
setcookie($board_config['cookie_name'] . '_t', serialize($tracking_topics), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
redirect(append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=" . $post_id) . '#' . $post_id, true);
#-----[ SAVE/CLOSE ALL FILES ]--------------------------------
# EoM
這外掛是要做啥ㄉ啊??好久前下載ㄉ現在都忘光ㄌ = = :oops:
對ㄌ,心靈捕手大大之前有提到:
心靈捕手 寫:檢視 viewtopic_body.tpl 修改的語法有些問題, 但不影響附加檔案顯示.
雖然您說不影響,但我還是很在意是哪邊修改的語法有些問題ㄟ..?
能否告訴我,並教我怎ㄇ改ㄇ?
感謝歐~
By魚肝油~
歡迎參觀我的論壇!!
~倉木麻衣~
文章: 1405
註冊時間: 2004-03-21 21:00
文章 ~倉木麻衣~ »
Redirect User Fix 這個對目前的phpBB版本而言是不需要安裝
先前版本的phpBB在重導向的部份有些問題存在, 所以才會有這個外掛出現
另外, 能不能拜託不要大量使用注音文?
看的很痛苦, 而且這裡也有許多非台灣地區的會員, 請尊重別人的閱讀權 ;-)
謝絕所有私人訊息詢問外掛相關問題
竹貓禁止發表含破解相關的軟體, 違者砍文
不要跟我講別的地方都可以發, 為什麼竹貓就不行
免費不等於破解, 傻傻的搞不清楚
魚肝油
文章: 23
來自: 中華民國~
文章 魚肝油 »
~倉木麻衣~ 寫:另外, 能不能拜託不要大量使用注音文?
抱歉..平時即時通上習慣又一時沒注意,造成各位困擾,真是抱歉.. :oops:
By魚肝油~
歡迎參觀我的論壇!!
魚肝油 寫:呼~問題終於解決ㄌ..,雖然沒有移除子分區,但還是找到毛病ㄌ,.......與子分區好像沒有關西....
外掛 寫:
對ㄌ,心靈捕手大大之前有提到:
能否告訴我,並教我怎ㄇ改ㄇ?
感謝歐~
抱歉! 沒有細看您之前貼出已安裝外掛列表. :oops:
這個問題我已經在 竹貓 提醒過網友了.
http://phpbb-tw.net/phpbb/viewtopic.php?p=213171#213171
關於 viewtopic_body.tpl 的修改, 提供您參考:
#-----[ FIND ]-----
		<div class="post-text">
			{postrow.MESSAGE}<br /><br />
			<span class="gensmall">{postrow.EDITED_MESSAGE}</span>
</span>{postrow.ATTACHMENTS}<span class="post-text">
			{postrow.SIGNATURE}
		</div>
			{postrow.SIGNATURE}
		</div>
魚肝油
文章: 23
來自: 中華民國~
文章 魚肝油 »
心靈捕手 寫:這個問題我已經在 竹貓 提醒過網友了.
原來,可能我下載時沒注意吧..= =
心靈捕手 寫:關於 viewtopic_body.tpl 的修改, 提供您參考:
#-----[ FIND ]-----
			{postrow.SIGNATURE}
		</div>
			{postrow.SIGNATURE}
		</div>
感謝~
By魚肝油~
歡迎參觀我的論壇!!
